Помогите с хеш функцией MD5 | ☑ | ||
Alex_MA
29.09.11
Всем доброго дня!
Функция MD5(КодируемаяСтрока, Хэш) ЗначениеВозврата = Истина; Попытка //http://pajhome.org.uk/crypt/md5/index.html ScrptCtrl = Новый COMОбъект("MSScriptControl.ScriptControl"); ScrptCtrl.Language = "JScript"; ScrptCtrl.AddCode(" |/* | * A JavaScript implementation of the RSA Data Security, Inc. MD5 Message | * Digest Algorithm, as defined in RFC 1321. | * Version 2.1 Copyright (C) Paul Johnston 1999 - 2002. | * Other contributors: Greg Holt, Andrew Kepert, Ydnar, Lostinet | * Distributed under the BSD License | * See http://pajhome.org.uk/crypt/md5 for more info. | */ | |/* | * Configurable variables. You may need to tweak these to be compatible with | * the server-side, but the defaults work in most cases. | */ |var hexcase = 0; /* hex output format. 0 - lowercase; 1 - uppercase */ |var b64pad = """"; /* base-64 pad character. ""="" for strict RFC compliance */ |var chrsz = 8; /* bits per input character. 8 - ASCII; 16 - Unicode */ | |/* | * These are the functions youll usually want to call | * They take string arguments and return either hex or base-64 encoded strings | */ |function hex_md5(s){ return binl2hex(core_md5(str2binl(s), s.length * chrsz));} |function b64_md5(s){ return binl2b64(core_md5(str2binl(s), s.length * chrsz));} |function str_md5(s){ return binl2str(core_md5(str2binl(s), s.length * chrsz));} |function hex_hmac_md5(key, data) { return binl2hex(core_hmac_md5(key, data)); } |function b64_hmac_md5(key, data) { return binl2b64(core_hmac_md5(key, data)); } |function str_hmac_md5(key, data) { return binl2str(core_hmac_md5(key, data)); } | |/* | * Perform a simple self-test to see if the VM is working | */ |function md5_vm_test() |{ | return hex_md5(""abc"") == ""900150983cd24fb0d6963f7d28e17f72""; |} | |/* | * Calculate the MD5 of an array of little-endian words, and a bit length | */ |function core_md5(x, len) |{ | /* append padding */ | x[len >> 5] |= 0x80 << ((len) % 32); | x[(((len + 64) >>> 9) << 4) + 14] = len; | | var a = 1732584193; | var b = -271733879; | var c = -1732584194; | var d = 271733878; | | for(var i = 0; i < x.length; i += 16) | { | var olda = a; | var oldb = b; | var oldc = c; | var oldd = d; | | a = md5_ff(a, b, c, d, x[i+ 0], 7 , -680876936); | d = md5_ff(d, a, b, c, x[i+ 1], 12, -389564586); | c = md5_ff(c, d, a, b, x[i+ 2], 17, 606105819); | b = md5_ff(b, c, d, a, x[i+ 3], 22, -1044525330); | a = md5_ff(a, b, c, d, x[i+ 4], 7 , -176418897); | d = md5_ff(d, a, b, c, x[i+ 5], 12, 1200080426); | c = md5_ff(c, d, a, b, x[i+ 6], 17, -1473231341); | b = md5_ff(b, c, d, a, x[i+ 7], 22, -45705983); | a = md5_ff(a, b, c, d, x[i+ 8], 7 , 1770035416); | d = md5_ff(d, a, b, c, x[i+ 9], 12, -1958414417); | c = md5_ff(c, d, a, b, x[i+10], 17, -42063); | b = md5_ff(b, c, d, a, x[i+11], 22, -1990404162); | a = md5_ff(a, b, c, d, x[i+12], 7 , 1804603682); | d = md5_ff(d, a, b, c, x[i+13], 12, -40341101); | c = md5_ff(c, d, a, b, x[i+14], 17, -1502002290); | b = md5_ff(b, c, d, a, x[i+15], 22, 1236535329); | | a = md5_gg(a, b, c, d, x[i+ 1], 5 , -165796510); | d = md5_gg(d, a, b, c, x[i+ 6], 9 , -1069501632); | c = md5_gg(c, d, a, b, x[i+11], 14, 643717713); | b = md5_gg(b, c, d, a, x[i+ 0], 20, -373897302); | a = md5_gg(a, b, c, d, x[i+ 5], 5 , -701558691); | d = md5_gg(d, a, b, c, x[i+10], 9 , 38016083); | c = md5_gg(c, d, a, b, x[i+15], 14, -660478335); | b = md5_gg(b, c, d, a, x[i+ 4], 20, -405537848); | a = md5_gg(a, b, c, d, x[i+ 9], 5 , 568446438); | d = md5_gg(d, a, b, c, x[i+14], 9 , -1019803690); | c = md5_gg(c, d, a, b, x[i+ 3], 14, -187363961); | b = md5_gg(b, c, d, a, x[i+ 8], 20, 1163531501); | a = md5_gg(a, b, c, d, x[i+13], 5 , -1444681467); | d = md5_gg(d, a, b, c, x[i+ 2], 9 , -51403784); | c = md5_gg(c, d, a, b, x[i+ 7], 14, 1735328473); | b = md5_gg(b, c, d, a, x[i+12], 20, -1926607734); | | a = md5_hh(a, b, c, d, x[i+ 5], 4 , -378558); | d = md5_hh(d, a, b, c, x[i+ 8], 11, -2022574463); | c = md5_hh(c, d, a, b, x[i+11], 16, 1839030562); | b = md5_hh(b, c, d, a, x[i+14], 23, -35309556); | a = md5_hh(a, b, c, d, x[i+ 1], 4 , -1530992060); | d = md5_hh(d, a, b, c, x[i+ 4], 11, 1272893353); | c = md5_hh(c, d, a, b, x[i+ 7], 16, -155497632); | b = md5_hh(b, c, d, a, x[i+10], 23, -1094730640); | a = md5_hh(a, b, c, d, x[i+13], 4 , 681279174); | d = md5_hh(d, a, b, c, x[i+ 0], 11, -358537222); | c = md5_hh(c, d, a, b, x[i+ 3], 16, -722521979); | b = md5_hh(b, c, d, a, x[i+ 6], 23, 76029189); | a = md5_hh(a, b, c, d, x[i+ 9], 4 , -640364487); | d = md5_hh(d, a, b, c, x[i+12], 11, -421815835); | c = md5_hh(c, d, a, b, x[i+15], 16, 530742520); | b = md5_hh(b, c, d, a, x[i+ 2], 23, -995338651); | | a = md5_ii(a, b, c, d, x[i+ 0], 6 , -198630844); | d = md5_ii(d, a, b, c, x[i+ 7], 10, 1126891415); | c = md5_ii(c, d, a, b, x[i+14], 15, -1416354905); | b = md5_ii(b, c, d, a, x[i+ 5], 21, -57434055); | a = md5_ii(a, b, c, d, x[i+12], 6 , 1700485571); | d = md5_ii(d, a, b, c, x[i+ 3], 10, -1894986606); | c = md5_ii(c, d, a, b, x[i+10], 15, -1051523); | b = md5_ii(b, c, d, a, x[i+ 1], 21, -2054922799); | a = md5_ii(a, b, c, d, x[i+ 8], 6 , 1873313359); | d = md5_ii(d, a, b, c, x[i+15], 10, -30611744); | c = md5_ii(c, d, a, b, x[i+ 6], 15, -1560198380); | b = md5_ii(b, c, d, a, x[i+13], 21, 1309151649); | a = md5_ii(a, b, c, d, x[i+ 4], 6 , -145523070); | d = md5_ii(d, a, b, c, x[i+11], 10, -1120210379); | c = md5_ii(c, d, a, b, x[i+ 2], 15, 718787259); | b = md5_ii(b, c, d, a, x[i+ 9], 21, -343485551); | | a = safe_add(a, olda); | b = safe_add(b, oldb); | c = safe_add(c, oldc); | d = safe_add(d, oldd); | } | return Array(a, b, c, d); | |} | |/* | * These functions implement the four basic operations the algorithm uses. | */ |function md5_cmn(q, a, b, x, s, t) |{ | return safe_add(bit_rol(safe_add(safe_add(a, q), safe_add(x, t)), s),b); |} |function md5_ff(a, b, c, d, x, s, t) |{ | return md5_cmn((b & c) | ((~b) & d), a, b, x, s, t); |} |function md5_gg(a, b, c, d, x, s, t) |{ | return md5_cmn((b & d) | (c & (~d)), a, b, x, s, t); |} |function md5_hh(a, b, c, d, x, s, t) |{ | return md5_cmn(b ^ c ^ d, a, b, x, s, t); |} |function md5_ii(a, b, c, d, x, s, t) |{ | return md5_cmn(c ^ (b | (~d)), a, b, x, s, t); |} | |/* | * Calculate the HMAC-MD5, of a key and some data | */ |function core_hmac_md5(key, data) |{ | var bkey = str2binl(key); | if(bkey.length > 16) bkey = core_md5(bkey, key.length * chrsz); | | var ipad = Array(16), opad = Array(16); | for(var i = 0; i < 16; i++) | { | ipad[i] = bkey[i] ^ 0x36363636; | opad[i] = bkey[i] ^ 0x5C5C5C5C; | } | | var hash = core_md5(ipad.concat(str2binl(data)), 512 + data.length * chrsz); | return core_md5(opad.concat(hash), 512 + 128); |} | |/* | * Add integers, wrapping at 2^32. This uses 16-bit operations internally | * to work around bugs in some JS interpreters. | */ |function safe_add(x, y) |{ | var lsw = (x & 0xFFFF) + (y & 0xFFFF); | var msw = (x >> 16) + (y >> 16) + (lsw >> 16); | return (msw << 16) | (lsw & 0xFFFF); |} | |/* | * Bitwise rotate a 32-bit number to the left. | */ |function bit_rol(num, cnt) |{ | return (num << cnt) | (num >>> (32 - cnt)); |} | |/* | * Convert a string to an array of little-endian words | * If chrsz is ASCII, characters >255 have their hi-byte silently ignored. | */ |function str2binl(str) |{ | var bin = Array(); | var mask = (1 << chrsz) - 1; | for(var i = 0; i < str.length * chrsz; i += chrsz) | bin[i>>5] |= (str.charCodeAt(i / chrsz) & mask) << (i%32); | return bin; |} | |/* | * Convert an array of little-endian words to a string | */ |function binl2str(bin) |{ | var str = """"; | var mask = (1 << chrsz) - 1; | for(var i = 0; i < bin.length * 32; i += chrsz) | str += String.fromCharCode((bin[i>>5] >>> (i % 32)) & mask); | return str; |} | |/* | * Convert an array of little-endian words to a hex string. | */ |function binl2hex(binarray) |{ | var hex_tab = hexcase ? ""0123456789ABCDEF"" : ""0123456789abcdef""; | var str = """"; | for(var i = 0; i < binarray.length * 4; i++) | { | str += hex_tab.charAt((binarray[i>>2] >> ((i%4)*8+4)) & 0xF) + | hex_tab.charAt((binarray[i>>2] >> ((i%4)*8 )) & 0xF); | } | return str; |} | |/* | * Convert an array of little-endian words to a base-64 string | */ |function binl2b64(binarray) |{ | var tab = ""ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/""; | var str = """"; | for(var i = 0; i < binarray.length * 4; i += 3) | { | var triplet = (((binarray[i >> 2] >> 8 * ( i %4)) & 0xFF) << 16) | | (((binarray[i+1 >> 2] >> 8 * ((i+1)%4)) & 0xFF) << 8 ) | | ((binarray[i+2 >> 2] >> 8 * ((i+2)%4)) & 0xFF); | for(var j = 0; j < 4; j++) | { | if(i * 8 + j * 6 > binarray.length * 32) str += b64pad; | else str += tab.charAt((triplet >> 6*(3-j)) & 0x3F); | } | } | return str; |} |"); Хэш = ""; Хэш = ScrptCtrl.Run("hex_md5", КодируемаяСтрока); Исключение ЗначениеВозврата = Ложь; Сообщить(ОписаниеОшибки(), СтатусСообщения.ОченьВажное); КонецПопытки; ScrptCtrl = ""; Возврат ЗначениеВозврата; КонецФункции // MD5() Работает вроде нормально, как только начал проверять строки типа: "туту, тата, пользователь, пароль" - начинает не правильно вычислять хеш. В чем здес проблема ? |
vde69
29.09.11
где-то спионерил и чуток доработал
Функция Из_Число_В_16(Знач Значение) Результат = ""; Пока Значение > 0 Цикл Остат = Значение % 16; Значение = (Значение - Остат) / 16; Результат = Сред("0123456789ABCDEF", Остат + 1, 1) + Результат КонецЦикла; Возврат Результат КонецФункции Функция ХэшБлоками(Строка, ДлинаБлока = 10, hash = 0, M = 31, TABLE_SIZE = 18446744073709551616) НачПозиция = 1; ДлинаСтроки = СтрДлина(Строка); Пока НачПозиция <= ДлинаСтроки Цикл СтрокаБлока = Сред(Строка, НачПозиция, ДлинаБлока); Для к = 1 По СтрДлина(СтрокаБлока) Цикл hash = M * hash + КодСимвола(СтрокаБлока, к) КонецЦикла; hash = hash % TABLE_SIZE; НачПозиция = НачПозиция + ДлинаБлока КонецЦикла; Возврат hash КонецФункции Функция ПолучитьХешТаблицы (ТЗ) Экспорт Результат = ""; // работаем с копией _ТЗ = ТЗ.Скопировать(); // приведем порядок ТЗ к единообразию // это исключит проблеммы с разным порядком элементов _ТЗ.Колонки.Добавить("СтрокаДляХеш"); Для каждого эл Из _ТЗ Цикл эл.СтрокаДляХеш = СокрЛП(эл.Объект.УникальныйИдентификатор()); КонецЦикла; _ТЗ.Сортировать ("СтрокаДляХеш"); // теперь строим строку для хеширования СтрокаСпискаДаных = ""; Для каждого эл Из _ТЗ Цикл СтрокаСпискаДаных = СтрокаСпискаДаных + эл.СтрокаДляХеш + ";"; КонецЦикла; //ВнешняяКомпонента = Новый COMОбъект("CAPICOM.HashedData"); //ВнешняяКомпонента.Algorithm = 3; //ВнешняяКомпонента.Hash(СтрокаСпискаДаных); //Результат = ВнешняяКомпонента.Value; //ВнешняяКомпонента = Неопределено; // // на 64х сервере работать не будет, нужно что-то придумать другое // типа: // //Dim sha As New SHA1CryptoServiceProvider() //Dim result As Byte() = sha.ComputeHash(dataArray) // // Пока сделал встроеным языком // Результат = Из_Число_В_16(ХэшБлоками(СтрокаСпискаДаных, 5381, 33)); Возврат Результат; КонецФункции |
Alex_MA
29.09.11
(1)работает все Ок?
vde69
29.09.11
(2) у меня работает
vde69
29.09.11
(2) CAPICOM.HashedData - гарантировано работает, просто у меня 64х сервер и там не пашет
fisher
29.09.11
А через восьмерочный криптографический интерфейс не взлетит?
Кто вообще имел с ним реальный опыт? |
vde69
29.09.11
(5) там обязательно требуется сертификат
Maxus43
29.09.11
(5) сертификат надо тудыть вставлять
v8: 1c 8.2 МенеджерКриптографии |
Alex_MA
29.09.11
(3)что то у тебя там лишка закоментированно, ибо такими строчками кода не отделаешься хешируя строку. имхо
fisher
29.09.11
(6) А это проблема? Я в этом деле не спец просто.
vde69
29.09.11
строка хешируется Результат = Из_Число_В_16(ХэшБлоками(СтрокаСпискаДаных, 5381, 33)) ---------------------------------------------------- или 100% работает если CAPICOM.DLL совместима с текущей ОС ВнешняяКомпонента = Новый COMОбъект("CAPICOM.HashedData"); ВнешняяКомпонента.Algorithm = 3; ВнешняяКомпонента.Hash(СтрокаСпискаДаных); Результат = ВнешняяКомпонента.Value; |
Alex_MA
29.09.11
(10)CAPICOM.DLL для x64 и x32 как я понимаю разная и еще завязана на вид ОС. так ?
Alex_MA
29.09.11
Функция Захешировать(Хеш) ВнешняяКомпонента = Новый COMОбъект("CAPICOM.HashedData"); ВнешняяКомпонента.Algorithm = 3; ВнешняяКомпонента.Hash(СтрокаСпискаДаных); РезультатCAPICOM = ВнешняяКомпонента.Value; //А дальше переведем просто в hex Возврат Из_Число_В_16(РезультатCAPICOM ); //Веренет hex md5 КонецФункции Функция Из_Число_В_16(Знач Значение) Результат = ""; Пока Значение > 0 Цикл Остат = Значение % 16; Значение = (Значение - Остат) / 16; Результат = Сред("0123456789ABCDEF", Остат + 1, 1) + Результат КонецЦикла; Возврат Результат КонецФункции Все правильно сделал ? |
Alex_MA
29.09.11
ВнешняяКомпонента = Новый COMОбъект("CAPICOM.HashedData"); ВнешняяКомпонента.Algorithm = 3; ВнешняяКомпонента.Hash(Хеш); РезультатCAPICOM = ВнешняяКомпонента.Value; //А дальше переведем просто в hex Возврат Из_Число_В_16(РезультатCAPICOM ); //Веренет hex md5 КонецФункции Функция Из_Число_В_16(Знач Значение) Результат = ""; Пока Значение > 0 Цикл Остат = Значение % 16; Значение = (Значение - Остат) / 16; Результат = Сред("0123456789ABCDEF", Остат + 1, 1) + Результат КонецЦикла; Возврат Результат КонецФункции |
vde69
29.09.11
ВнешняяКомпонента = Новый COMОбъект("CAPICOM.HashedData"); ВнешняяКомпонента.Algorithm = 3; ВнешняяКомпонента.Hash(Хеш); Р = ВнешняяКомпонента.Value; ВнешняяКомпонента=неопределено; Возврат Р; КонецФункции |
vde69
29.09.11
под 32х - работает под 64х мне не удалось запустить |
Vetal_978
29.09.11
А кто выступает криптопровайдером? CAPICOM не оно? Что-то типа КриптоПРО надоть?
vde69
29.09.11
(16) CAPICOM достаточно
skunk
29.09.11
Alex_MA
29.09.11
(17) написал след. код:
Функция Захешировать(Хеш) ВнешняяКомпонента = Новый COMОбъект("CAPICOM.HashedData"); ВнешняяКомпонента.Algorithm = 3; ВнешняяКомпонента.Hash(Хеш); РезультатCAPICOM = ВнешняяКомпонента.Value; //А дальше переведем просто в hex Сообщить(РезультатCAPICOM); КонецФункции Процедура Кнопка2Нажатие(Элемент) Захешировать(СокрЛП(ПарольВхода) ); КонецПроцедуры ввожу "туту" Результат "810503098561BE851BAFCD0FEC24C2FE" - он не корректный |
Alex_MA
29.09.11
(18)твоя обработка вернула md5("туту")=6e1412fca31cbd35d0f50f12fcc70b0f, это не правильно, можешь проверить:
http://pajhome.org.uk/crypt/md5/index.html |
vde69
29.09.11
(19) кто сказал, что он не корректный?
ты хочешь сказать что РОДНАЯ КРИПТО библиотека мелкомягких выдает некоректный результат? есть много вариантов 1. - сайт левый и выдает фигню 2. - на сайте проблеммы с кодировкой русских букв 3. - на сайте кодируется бинарная строка (то есть коды сисмволов) и т.д. |
skunk
29.09.11
(20)ну вставь туда код из скрипта ... если тебе нужен 2.2 ...
skunk
29.09.11
(21)версий мд5 несколько ... последня 2.2 ... сыр скрипта на яве для данной версии доступен по ссылке из (20) ...
vde69
29.09.11
в капикоме реализованы алгоритмы хеширования
CAPICOM_HASH_ALGORITHM_SHA1 SHA1 hashing algorithm. CAPICOM_HASH_ALGORITHM_MD2 MD2 hashing algorithm. CAPICOM_HASH_ALGORITHM_MD4 MD4 hashing algorithm. CAPICOM_HASH_ALGORITHM_MD5 MD5 hashing algorithm. CAPICOM_HASH_ALGORITHM_SHA_256 SHA-256 hash algorithm. CAPICOM 2.0.0.3 and earlier: This value is not supported. Windows XP, Windows 2000: This value is not supported. CAPICOM_HASH_ALGORITHM_SHA_384 SHA-384 hash algorithm. CAPICOM 2.0.0.3 and earlier: This value is not supported. Windows XP, Windows 2000: This value is not supported. CAPICOM_HASH_ALGORITHM_SHA_512 SHA-512 hash algorithm. CAPICOM 2.0.0.3 and earlier: This value is not supported. Windows XP, Windows 2000: This value is not supported. http://msdn.microsoft.com/en-us/library/aa382443(v=VS.85).aspx |
Alex_MA
29.09.11
(24)да, уже глянул, спасибо. Кстати, все что написано в (21) вряд ли. Т.к. проверял и этой ф-ей:
http://php.net/manual/ru/function.md5.php На сайтах и php ф-я выдают одинаковые значения. |
vde69
29.09.11
(25) сам алгоритм один, разные значения констатн и длинна получаемого хеша, поищи может их можно в крипторовайдере менять...
вообще сам много чего облазил, реализаций полно и далеко не все совместимы, а тебе вообще зачем? может тебе ЭЦП нужно а не хеш? |
Alex_MA
29.09.11
Дело в том, что пишу web сервис, авторизация использует в том числе и хеш функцию. Однако, ф-я md5 на php никак не хочет сходиться с ф-ей и (18) и (19). Что делать ?
vde69
29.09.11
(27) нафига при авторизации хешь функция?
абсолютно без разницы что ты передаешь на сервер хеш или открытый пароль, если перехватят - этого достаточно для генерации корректного запроса. если хочешь обесопасится от перехвата - ssl спасет тебя, (сначало обмен открытыми сеансовыми ключами и потом шифрование всего трафика ими) |
Alex_MA
29.09.11
(28)у меня еще есть загыгулистая формула :)
Alex_MA
29.09.11
можно из кода 1С обратиться к php функции ?
andrewks
29.09.11
Vetal_978
29.09.11
Народ, а как сгенерить самопальный сертификат? Чем это можно сделать?
Rebelx
29.09.11
openssl
Vetal_978
29.09.11
(33) спасибо, получилось
Alex_MA
30.09.11
пытаюсь встроить js сырец в код 1С, но почему то возникает ошибка:
{Форма.Форма.Форма(8)}: Ошибка при вызове метода контекста (AddCode): Произошла исключительная ситуация (Ошибка компиляции Microsoft JScript): Синтаксическая ошибка Вот код: функция стрМД5(стрЗначение) экспорт Ответ = неопределено; попытка олеСкрипт = новый COMОбъект("MSScriptControl.ScriptControl"); олеСкрипт.Language = "JScript"; олеСкрипт.AddCode(" |var hexcase = 0; |var b64pad = """"; |var chrsz = 8; | |function hex_md5(s) |{ | return binl2hex(core_md5(str2binl(s), s.length * chrsz)); |} | |function b64_md5(s) |{ | return binl2b64(core_md5(str2binl(s), s.length * chrsz)); |} | |function str_md5(s) |{ | return binl2str(core_md5(str2binl(s), s.length * chrsz)); |} | |function hex_hmac_md5(key, data) |{ | return binl2hex(core_hmac_md5(key, data)); |} | |function b64_hmac_md5(key, data) |{ | return binl2b64(core_hmac_md5(key, data)); |} | |function str_hmac_md5(key, data) |{ | return binl2str(core_hmac_md5(key, data)); |} | |function md5_vm_test() |{ | return hex_md5(""abc"") == ""900150983cd24fb0d6963f7d28e17f72""; |} | |function core_md5(x, len) |{ | x[len >> 5] |= 0x80 << ((len) % 32); | x[(((len + 64) >>> 9) << 4) + 14] = len; | var a = 1732584193; | var b = -271733879; | var c = -1732584194; | var d = 271733878; | for(var i = 0; i < x.length; i += 16) | { | var olda = a; | var oldb = b; | var oldc = c; | var oldd = d; | a = md5_ff(a, b, c, d, x[i+ 0], 7 , -680876936); | d = md5_ff(d, a, b, c, x[i+ 1], 12, -389564586); | c = md5_ff(c, d, a, b, x[i+ 2], 17, 606105819); | b = md5_ff(b, c, d, a, x[i+ 3], 22, -1044525330); | a = md5_ff(a, b, c, d, x[i+ 4], 7 , -176418897); | d = md5_ff(d, a, b, c, x[i+ 5], 12, 1200080426); | c = md5_ff(c, d, a, b, x[i+ 6], 17, -1473231341); | b = md5_ff(b, c, d, a, x[i+ 7], 22, -45705983); | a = md5_ff(a, b, c, d, x[i+ 8], 7 , 1770035416); | d = md5_ff(d, a, b, c, x[i+ 9], 12, -1958414417); | c = md5_ff(c, d, a, b, x[i+10], 17, -42063); | b = md5_ff(b, c, d, a, x[i+11], 22, -1990404162); | a = md5_ff(a, b, c, d, x[i+12], 7 , 1804603682); | d = md5_ff(d, a, b, c, x[i+13], 12, -40341101); | c = md5_ff(c, d, a, b, x[i+14], 17, -1502002290); | b = md5_ff(b, c, d, a, x[i+15], 22, 1236535329); | a = md5_gg(a, b, c, d, x[i+ 1], 5 , -165796510); | d = md5_gg(d, a, b, c, x[i+ 6], 9 , -1069501632); | c = md5_gg(c, d, a, b, x[i+11], 14, 643717713); | b = md5_gg(b, c, d, a, x[i+ 0], 20, -373897302); | a = md5_gg(a, b, c, d, x[i+ 5], 5 , -701558691); | d = md5_gg(d, a, b, c, x[i+10], 9 , 38016083); | c = md5_gg(c, d, a, b, x[i+15], 14, -660478335); | b = md5_gg(b, c, d, a, x[i+ 4], 20, -405537848); | a = md5_gg(a, b, c, d, x[i+ 9], 5 , 568446438); | d = md5_gg(d, a, b, c, x[i+14], 9 , -1019803690); | c = md5_gg(c, d, a, b, x[i+ 3], 14, -187363961); | b = md5_gg(b, c, d, a, x[i+ 8], 20, 1163531501); | a = md5_gg(a, b, c, d, x[i+13], 5 , -1444681467); | d = md5_gg(d, a, b, c, x[i+ 2], 9 , -51403784); | c = md5_gg(c, d, a, b, x[i+ 7], 14, 1735328473); | b = md5_gg(b, c, d, a, x[i+12], 20, -1926607734); | a = md5_hh(a, b, c, d, x[i+ 5], 4 , -378558); | d = md5_hh(d, a, b, c, x[i+ 8], 11, -2022574463); | c = md5_hh(c, d, a, b, x[i+11], 16, 1839030562); | b = md5_hh(b, c, d, a, x[i+14], 23, -35309556); | a = md5_hh(a, b, c, d, x[i+ 1], 4 , -1530992060); | d = md5_hh(d, a, b, c, x[i+ 4], 11, 1272893353); | c = md5_hh(c, d, a, b, x[i+ 7], 16, -155497632); | b = md5_hh(b, c, d, a, x[i+10], 23, -1094730640); | a = md5_hh(a, b, c, d, x[i+13], 4 , 681279174); | d = md5_hh(d, a, b, c, x[i+ 0], 11, -358537222); | c = md5_hh(c, d, a, b, x[i+ 3], 16, -722521979); | b = md5_hh(b, c, d, a, x[i+ 6], 23, 76029189); | a = md5_hh(a, b, c, d, x[i+ 9], 4 , -640364487); | d = md5_hh(d, a, b, c, x[i+12], 11, -421815835); | c = md5_hh(c, d, a, b, x[i+15], 16, 530742520); | b = md5_hh(b, c, d, a, x[i+ 2], 23, -995338651); | a = md5_ii(a, b, c, d, x[i+ 0], 6 , -198630844); | d = md5_ii(d, a, b, c, x[i+ 7], 10, 1126891415); | c = md5_ii(c, d, a, b, x[i+14], 15, -1416354905); | b = md5_ii(b, c, d, a, x[i+ 5], 21, -57434055); | a = md5_ii(a, b, c, d, x[i+12], 6 , 1700485571); | d = md5_ii(d, a, b, c, x[i+ 3], 10, -1894986606); | c = md5_ii(c, d, a, b, x[i+10], 15, -1051523); | b = md5_ii(b, c, d, a, x[i+ 1], 21, -2054922799); | a = md5_ii(a, b, c, d, x[i+ 8], 6 , 1873313359); | d = md5_ii(d, a, b, c, x[i+15], 10, -30611744); | c = md5_ii(c, d, a, b, x[i+ 6], 15, -1560198380); | b = md5_ii(b, c, d, a, x[i+13], 21, 1309151649); | a = md5_ii(a, b, c, d, x[i+ 4], 6 , -145523070); | d = md5_ii(d, a, b, c, x[i+11], 10, -1120210379); | c = md5_ii(c, d, a, b, x[i+ 2], 15, 718787259); | b = md5_ii(b, c, d, a, x[i+ 9], 21, -343485551); | a = safe_add(a, olda); | b = safe_add(b, oldb); | c = safe_add(c, oldc); | d = safe_add(d, oldd); | } | return Array(a, b, c, d); |} | |function md5_cmn(q, a, b, x, s, t) |{ | return safe_add(bit_rol(safe_add(safe_add(a, q), safe_add(x, t)), s),b); |} | |function md5_ff(a, b, c, d, x, s, t) |{ | return md5_cmn((b & c) | ((~b) & d), a, b, x, s, t); |} | |function md5_gg(a, b, c, d, x, s, t) |{ | return md5_cmn((b & d) | (c & (~d)), a, b, x, s, t); |} | |function md5_hh(a, b, c, d, x, s, t) |{ | return md5_cmn(b ^ c ^ d, a, b, x, s, t); |} | |function md5_ii(a, b, c, d, x, s, t) |{ | return md5_cmn(c ^ (b | (~d)), a, b, x, s, t); |} | |function core_hmac_md5(key, data) |{ | var bkey = str2binl(key); | if(bkey.length > 16) bkey = core_md5(bkey, key.length * chrsz); | var ipad = Array(16), opad = Array(16); | for(var i = 0; i < 16; i++) | { | ipad[i] = bkey[i] ^ 0x36363636; | opad[i] = bkey[i] ^ 0x5C5C5C5C; | } | var hash = core_md5(ipad.concat(str2binl(data)), 512 + data.length * chrsz); | return core_md5(opad.concat(hash), 512 + 128); |} | |function safe_add(x, y) |{ | var lsw = (x & 0xFFFF) + (y & 0xFFFF); | var msw = (x >> 16) + (y >> 16) + (lsw >> 16); | return (msw << 16) | (lsw & 0xFFFF); |} | |function bit_rol(num, cnt) |{ | return (num << cnt) | (num >>> (32 - cnt)); |} | |function str2binl(str) |{ | var bin = Array(); | var mask = (1 << chrsz) - 1; | for(var i = 0; i < str.length * chrsz; i += chrsz) | bin[i>>5] |= (str.charCodeAt(i / chrsz) & mask) << (i%32); | return bin; |} | |function binl2str(bin) |{ | var str = """"; | var mask = (1 << chrsz) - 1; | for(var i = 0; i < bin.length * 32; i += chrsz) | str += String.fromCharCode((bin[i>>5] >>> (i % 32)) & mask); | return str; |} | |function binl2hex(binarray) |{ | var hex_tab = hexcase ? ""0123456789ABCDEF"" : ""0123456789abcdef""; | var str = """"; | for(var i = 0; i < binarray.length * 4; i++) | { | str += hex_tab.charAt((binarray[i>>2] >> ((i%4)*8+4)) & 0xF) + | hex_tab.charAt((binarray[i>>2] >> ((i%4)*8 )) & 0xF); | } | return str; |} | |function binl2b64(binarray) |{ | var tab = ""ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/""; | var str = """"; | for(var i = 0; i < binarray.length * 4; i += 3) | { | var triplet = (((binarray[i >> 2] >> 8 * ( i %4)) & 0xFF) << 16) | | (((binarray[i+1 >> 2] >> 8 * ((i+1)%4)) & 0xFF) << 8 ) | | ((binarray[i+2 >> 2] >> 8 * ((i+2)%4)) & 0xFF); | for(var j = 0; j < 4; j++) | { | if(i * 8 + j * 6 > binarray.length * 32) str += b64pad; | else str += tab.charAt((triplet >> 6*(3-j)) & 0x3F); | } | } | return str; |} |"); Ответ = олеСкрипт.Run("hex_md5", стрЗначение); исключение Сообщить(ОписаниеОшибки(), СтатусСообщения.ОченьВажное); конецпопытки; возврат Ответ; конецфункции Процедура КнопкаВыполнитьНажатие(Кнопка) Сообщить(стрМД5(Данные)); КонецПроцедуры |
Alex_MA
30.09.11
все, сделал
вот, кому интересно, MD5 v2.2 на js Процедура РассчитатьMD5Нажатие(Элемент) Попытка ScrptCtrl = Новый COMОбъект("MSScriptControl.ScriptControl"); ScrptCtrl.Language = "JScript"; ScrptCtrl.AddCode(" |var hexcase = 0; /* hex output format. 0 - lowercase; 1 - uppercase */ |var b64pad = """"; /* base-64 pad character. ""="" for strict RFC compliance */ | |function hex_md5(s) { return rstr2hex(rstr_md5(str2rstr_utf8(s))); } |function b64_md5(s) { return rstr2b64(rstr_md5(str2rstr_utf8(s))); } |function any_md5(s, e) { return rstr2any(rstr_md5(str2rstr_utf8(s)), e); } |function hex_hmac_md5(k, d) | { return rstr2hex(rstr_hmac_md5(str2rstr_utf8(k), str2rstr_utf8(d))); } |function b64_hmac_md5(k, d) | { return rstr2b64(rstr_hmac_md5(str2rstr_utf8(k), str2rstr_utf8(d))); } |function any_hmac_md5(k, d, e) | { return rstr2any(rstr_hmac_md5(str2rstr_utf8(k), str2rstr_utf8(d)), e); } | |function md5_vm_test() |{ | return hex_md5(""abc"").toLowerCase() == ""900150983cd24fb0d6963f7d28e17f72""; |} | |function rstr_md5(s) |{ | return binl2rstr(binl_md5(rstr2binl(s), s.length * 8)); |} | |function rstr_hmac_md5(key, data) |{ | var bkey = rstr2binl(key); | if(bkey.length > 16) bkey = binl_md5(bkey, key.length * 8); | | var ipad = Array(16), opad = Array(16); | for(var i = 0; i < 16; i++) | { | ipad[i] = bkey[i] ^ 0x36363636; | opad[i] = bkey[i] ^ 0x5C5C5C5C; | } | | var hash = binl_md5(ipad.concat(rstr2binl(data)), 512 + data.length * 8); | return binl2rstr(binl_md5(opad.concat(hash), 512 + 128)); |} | |function rstr2hex(input) |{ | try { hexcase } catch(e) { hexcase=0; } | var hex_tab = hexcase ? ""0123456789ABCDEF"" : ""0123456789abcdef""; | var output = """"; | var x; | for(var i = 0; i < input.length; i++) | { | x = input.charCodeAt(i); | output += hex_tab.charAt((x >>> 4) & 0x0F) | + hex_tab.charAt( x & 0x0F); | } | return output; |} | |function rstr2b64(input) |{ | try { b64pad } catch(e) { b64pad=''; } | var tab = ""ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/""; | var output = """"; | var len = input.length; | for(var i = 0; i < len; i += 3) | { | var triplet = (input.charCodeAt(i) << 16) | | (i + 1 < len ? input.charCodeAt(i+1) << 8 : 0) | | (i + 2 < len ? input.charCodeAt(i+2) : 0); | for(var j = 0; j < 4; j++) | { | if(i * 8 + j * 6 > input.length * 8) output += b64pad; | else output += tab.charAt((triplet >>> 6*(3-j)) & 0x3F); | } | } | return output; |} | |function rstr2any(input, encoding) |{ | var divisor = encoding.length; | var i, j, q, x, quotient; | | var dividend = Array(Math.ceil(input.length / 2)); | for(i = 0; i < dividend.length; i++) | { | dividend[i] = (input.charCodeAt(i * 2) << 8) | input.charCodeAt(i * 2 + 1); | } | | var full_length = Math.ceil(input.length * 8 / | (Math.log(encoding.length) / Math.log(2))); | var remainders = Array(full_length); | for(j = 0; j < full_length; j++) | { | quotient = Array(); | x = 0; | for(i = 0; i < dividend.length; i++) | { | x = (x << 16) + dividend[i]; | q = Math.floor(x / divisor); | x -= q * divisor; | if(quotient.length > 0 || q > 0) | quotient[quotient.length] = q; | } | remainders[j] = x; | dividend = quotient; | } | | var output = """"; | for(i = remainders.length - 1; i >= 0; i--) | output += encoding.charAt(remainders[i]); | | return output; |} | |function str2rstr_utf8(input) |{ | var output = """"; | var i = -1; | var x, y; | | while(++i < input.length) | { | x = input.charCodeAt(i); | y = i + 1 < input.length ? input.charCodeAt(i + 1) : 0; | if(0xD800 <= x && x <= 0xDBFF && 0xDC00 <= y && y <= 0xDFFF) | { | x = 0x10000 + ((x & 0x03FF) << 10) + (y & 0x03FF); | i++; | } | | if(x <= 0x7F) | output += String.fromCharCode(x); | else if(x <= 0x7FF) | output += String.fromCharCode(0xC0 | ((x >>> 6 ) & 0x1F), | 0x80 | ( x & 0x3F)); | else if(x <= 0xFFFF) | output += String.fromCharCode(0xE0 | ((x >>> 12) & 0x0F), | 0x80 | ((x >>> 6 ) & 0x3F), | 0x80 | ( x & 0x3F)); | else if(x <= 0x1FFFFF) | output += String.fromCharCode(0xF0 | ((x >>> 18) & 0x07), | 0x80 | ((x >>> 12) & 0x3F), | 0x80 | ((x >>> 6 ) & 0x3F), | 0x80 | ( x & 0x3F)); | } | return output; |} | |function str2rstr_utf16le(input) |{ | var output = """"; | for(var i = 0; i < input.length; i++) | output += String.fromCharCode( input.charCodeAt(i) & 0xFF, | (input.charCodeAt(i) >>> 8) & 0xFF); | return output; |} | |function str2rstr_utf16be(input) |{ | var output = """"; | for(var i = 0; i < input.length; i++) | output += String.fromCharCode((input.charCodeAt(i) >>> 8) & 0xFF, | input.charCodeAt(i) & 0xFF); | return output; |} | |function rstr2binl(input) |{ | var output = Array(input.length >> 2); | for(var i = 0; i < output.length; i++) | output[i] = 0; | for(var i = 0; i < input.length * 8; i += 8) | output[i>>5] |= (input.charCodeAt(i / 8) & 0xFF) << (i%32); | return output; |} | |function binl2rstr(input) |{ | var output = """"; | for(var i = 0; i < input.length * 32; i += 8) | output += String.fromCharCode((input[i>>5] >>> (i % 32)) & 0xFF); | return output; |} | |function binl_md5(x, len) |{ | x[len >> 5] |= 0x80 << ((len) % 32); | x[(((len + 64) >>> 9) << 4) + 14] = len; | | var a = 1732584193; | var b = -271733879; | var c = -1732584194; | var d = 271733878; | | for(var i = 0; i < x.length; i += 16) | { | var olda = a; | var oldb = b; | var oldc = c; | var oldd = d; | | a = md5_ff(a, b, c, d, x[i+ 0], 7 , -680876936); | d = md5_ff(d, a, b, c, x[i+ 1], 12, -389564586); | c = md5_ff(c, d, a, b, x[i+ 2], 17, 606105819); | b = md5_ff(b, c, d, a, x[i+ 3], 22, -1044525330); | a = md5_ff(a, b, c, d, x[i+ 4], 7 , -176418897); | d = md5_ff(d, a, b, c, x[i+ 5], 12, 1200080426); | c = md5_ff(c, d, a, b, x[i+ 6], 17, -1473231341); | b = md5_ff(b, c, d, a, x[i+ 7], 22, -45705983); | a = md5_ff(a, b, c, d, x[i+ 8], 7 , 1770035416); | d = md5_ff(d, a, b, c, x[i+ 9], 12, -1958414417); | c = md5_ff(c, d, a, b, x[i+10], 17, -42063); | b = md5_ff(b, c, d, a, x[i+11], 22, -1990404162); | a = md5_ff(a, b, c, d, x[i+12], 7 , 1804603682); | d = md5_ff(d, a, b, c, x[i+13], 12, -40341101); | c = md5_ff(c, d, a, b, x[i+14], 17, -1502002290); | b = md5_ff(b, c, d, a, x[i+15], 22, 1236535329); | | a = md5_gg(a, b, c, d, x[i+ 1], 5 , -165796510); | d = md5_gg(d, a, b, c, x[i+ 6], 9 , -1069501632); | c = md5_gg(c, d, a, b, x[i+11], 14, 643717713); | b = md5_gg(b, c, d, a, x[i+ 0], 20, -373897302); | a = md5_gg(a, b, c, d, x[i+ 5], 5 , -701558691); | d = md5_gg(d, a, b, c, x[i+10], 9 , 38016083); | c = md5_gg(c, d, a, b, x[i+15], 14, -660478335); | b = md5_gg(b, c, d, a, x[i+ 4], 20, -405537848); | a = md5_gg(a, b, c, d, x[i+ 9], 5 , 568446438); | d = md5_gg(d, a, b, c, x[i+14], 9 , -1019803690); | c = md5_gg(c, d, a, b, x[i+ 3], 14, -187363961); | b = md5_gg(b, c, d, a, x[i+ 8], 20, 1163531501); | a = md5_gg(a, b, c, d, x[i+13], 5 , -1444681467); | d = md5_gg(d, a, b, c, x[i+ 2], 9 , -51403784); | c = md5_gg(c, d, a, b, x[i+ 7], 14, 1735328473); | b = md5_gg(b, c, d, a, x[i+12], 20, -1926607734); | | a = md5_hh(a, b, c, d, x[i+ 5], 4 , -378558); | d = md5_hh(d, a, b, c, x[i+ 8], 11, -2022574463); | c = md5_hh(c, d, a, b, x[i+11], 16, 1839030562); | b = md5_hh(b, c, d, a, x[i+14], 23, -35309556); | a = md5_hh(a, b, c, d, x[i+ 1], 4 , -1530992060); | d = md5_hh(d, a, b, c, x[i+ 4], 11, 1272893353); | c = md5_hh(c, d, a, b, x[i+ 7], 16, -155497632); | b = md5_hh(b, c, d, a, x[i+10], 23, -1094730640); | a = md5_hh(a, b, c, d, x[i+13], 4 , 681279174); | d = md5_hh(d, a, b, c, x[i+ 0], 11, -358537222); | c = md5_hh(c, d, a, b, x[i+ 3], 16, -722521979); | b = md5_hh(b, c, d, a, x[i+ 6], 23, 76029189); | a = md5_hh(a, b, c, d, x[i+ 9], 4 , -640364487); | d = md5_hh(d, a, b, c, x[i+12], 11, -421815835); | c = md5_hh(c, d, a, b, x[i+15], 16, 530742520); | b = md5_hh(b, c, d, a, x[i+ 2], 23, -995338651); | | a = md5_ii(a, b, c, d, x[i+ 0], 6 , -198630844); | d = md5_ii(d, a, b, c, x[i+ 7], 10, 1126891415); | c = md5_ii(c, d, a, b, x[i+14], 15, -1416354905); | b = md5_ii(b, c, d, a, x[i+ 5], 21, -57434055); | a = md5_ii(a, b, c, d, x[i+12], 6 , 1700485571); | d = md5_ii(d, a, b, c, x[i+ 3], 10, -1894986606); | c = md5_ii(c, d, a, b, x[i+10], 15, -1051523); | b = md5_ii(b, c, d, a, x[i+ 1], 21, -2054922799); | a = md5_ii(a, b, c, d, x[i+ 8], 6 , 1873313359); | d = md5_ii(d, a, b, c, x[i+15], 10, -30611744); | c = md5_ii(c, d, a, b, x[i+ 6], 15, -1560198380); | b = md5_ii(b, c, d, a, x[i+13], 21, 1309151649); | a = md5_ii(a, b, c, d, x[i+ 4], 6 , -145523070); | d = md5_ii(d, a, b, c, x[i+11], 10, -1120210379); | c = md5_ii(c, d, a, b, x[i+ 2], 15, 718787259); | b = md5_ii(b, c, d, a, x[i+ 9], 21, -343485551); | | a = safe_add(a, olda); | b = safe_add(b, oldb); | c = safe_add(c, oldc); | d = safe_add(d, oldd); | } | return Array(a, b, c, d); |} | |function md5_cmn(q, a, b, x, s, t) |{ | return safe_add(bit_rol(safe_add(safe_add(a, q), safe_add(x, t)), s),b); |} |function md5_ff(a, b, c, d, x, s, t) |{ | return md5_cmn((b & c) | ((~b) & d), a, b, x, s, t); |} |function md5_gg(a, b, c, d, x, s, t) |{ | return md5_cmn((b & d) | (c & (~d)), a, b, x, s, t); |} |function md5_hh(a, b, c, d, x, s, t) |{ | return md5_cmn(b ^ c ^ d, a, b, x, s, t); |} |function md5_ii(a, b, c, d, x, s, t) |{ | return md5_cmn(c ^ (b | (~d)), a, b, x, s, t); |} | |function safe_add(x, y) |{ | var lsw = (x & 0xFFFF) + (y & 0xFFFF); | var msw = (x >> 16) + (y >> 16) + (lsw >> 16); | return (msw << 16) | (lsw & 0xFFFF); |} | |function bit_rol(num, cnt) |{ | return (num << cnt) | (num >>> (32 - cnt)) |};"); Хэш = ""; Хэш = ScrptCtrl.Run("hex_md5", КодируемаяСтрока); Исключение Сообщить(ОписаниеОшибки(), СтатусСообщения.ОченьВажное); Возврат; КонецПопытки; Сообщить(Хэш); КонецПроцедуры |
Alex_MA
30.09.11
(36)сходитсья с php- шной ф-ей
