Putty. Как импортировать настройки из файла в реестр? ☑
0 Steel_Wheel
10.05.12
Слетела ОС. Переустановил, но с виндой поломались все настройки. Сейчас обнаружил, что мне очень нужно соединиться с одним компом, но у меня настройки подключения хранятся в файле рядом с программой. А как их можно закинуть в реестр, кто-нибудь знает?
1 pumbaEO
10.05.12
PuTTY does not currently support storing its configuration in a file instead of the Registry. However, you can work around this with a couple of batch files.
You will need a file called (say) PUTTY.BAT which imports the contents of a file into the Registry, then runs PuTTY, exports the contents of the Registry back into the file, and deletes the Registry entries. This can all be done using the Regedit command line options, so it's all automatic. Here is what you need in PUTTY.BAT:
@ECHO OFF
regedit /s putty.reg
regedit /s puttyrnd.reg
start /w putty.exe
regedit /ea new.reg HKEY_CURRENT_USER\Software\SimonTatham\PuTTY
copy new.reg putty.reg
del new.reg
regedit /s puttydel.reg
This batch file needs two auxiliary files: PUTTYRND.REG which sets up an initial safe location for the PUTTY.RND random seed file, and PUTTYDEL.REG which destroys everything in the Registry once it's been successfully saved back to the file.
Here is PUTTYDEL.REG:
REGEDIT4
[-HKEY_CURRENT_USER\Software\SimonTatham\PuTTY]
Here is an example PUTTYRND.REG file:
REGEDIT4
[HKEY_CURRENT_USER\Software\SimonTatham\PuTTY]
"RandSeedFile"="a:\\putty.rnd"
You should replace a:\putty.rnd with the location where you want to store your random number data. If the aim is to carry around PuTTY and its settings on one floppy, you probably want to store it on the floppy.
Из справки putty
2 Steel_Wheel
10.05.12
Спасибо
