Помогите расшифровать лог
0 kuromanlich
14.05.12
WinServ R2 x64
An account failed to log on.
Subject:
   Security ID:        NULL SID
   Account Name:        -
   Account Domain:        -
   Logon ID:        0x0
Logon Type:            3
Account For Which Logon Failed:
   Account Name:        Administrator
   Account Domain:        oper4
Failure Information:
   Failure Reason:        Unknown user name or bad password.
   Status:            0xc000006d
   Sub Status:        0xc000006a
Process Information:
   Caller Process ID:    0x0
   Caller Process Name:    -
Network Information:
   Workstation Name:    OPER4
   Source Network Address:    172.31.4.136
   Source Port:        49903
Detailed Authentication Information:
   Logon Process:        NtLmSsp
   Authentication Package:    NTLM
   Transited Services:    -
   Package Name (NTLM only):    -
   Key Length:        0
This event is generated when a logon request fails. It is generated on the computer where access was attempted.
The Subject fields indicate the account on the local system which requested the logon. This is most commonly a service such as the Server service, or a local process such as Winlogon.exe or Services.exe.
The Logon Type field indicates the kind of logon that was requested. The most common types are 2 (interactive) and 3 (network).
The Process Information fields indicate which account and process on the system requested the logon.
The Network Information fields indicate where a remote logon request originated. Workstation name is not always available and may be left blank in some cases.
The authentication information fields provide detailed information about this specific logon request.
   - Transited services indicate which intermediate services have participated in this logon request.
   - Package name indicates which sub-protocol was used among the NTLM protocols.
   - Key length indicates the length of the generated session key. This will be 0 if no session key was requested.
1 kuromanlich
14.05.12
т.е. получается что не пускает потому, что юзер не указывается при обращении?
2 kuromanlich
14.05.12
(1) разобрался, есть данные для подключения.
