Vware ESX 4.1 виртуальной машины на Debian'e+ CMS | ☑ | ||
antistaks
18.06.12
19:17
Пытаюсь снять snapshot с виртуальной машины с помощью veeam backup 4.1.2
в процессе возникает ошибка: 4 of 5 files processed Total VM size: 8,00 GB Processed size: 15,52 KB Processing rate: 0 KB/s Backup mode: SAN/NBD without changed block tracking Start time: 18.06.2012 18:22:11 End time: 18.06.2012 18:24:14 Duration: 0:02:03 Creating snapshot Failed to perform Veeam VSS freeze: guest OS "other26xLinuxGuest" is not supported Verifying changed block tracking... Disk "Hard disk 1" has incorrect changed block tracking configuration. One or more VM disks have incorrect changed block tracking configuration. To resolve this, open VMware vSphere Client, right-click the VM, choose Edit Settings, Options tab, select General, click Configuration Parameters, and set all entries with ‘ctkEnabled’ substring to false. Veeam Backup will then automatically re-enable changed block tracking with the correct settings during the next job run. Backing up file "[SATA-5] WWW/WWW-flat.vmdk" BackupDisk failed Client error: Failed to open VDDK disk [[SATA-5] WWW/WWW.vmdk] ( is read-only mode - [true] ) Failed to open VMDK. Logon attempt with parameters [VC/ESX: [192.168.0.86];Port: 443;Login: [root];VMX Spec: [moref=256];Snapshot mor: [256-snapshot-25];Transports: [san]] failed because of the following errors: Failed to open VMDK. Logon attempt with parameters [VC/ESX: [192.168.0.86];Port: 902;Login: [root];VMX Spec: [moref=256];Snapshot mor: [256-snapshot-25];Transports: [nbd]] failed because of the following errors: Server error: End of file Ладно с этим понятно...Выставил что попросил Вторая ошибка 0 of 0 files processed Total VM size: 8,00 GB Processed size: 0,00 KB Processing rate: 0 KB/s Backup mode: SAN/NBD without changed block tracking Start time: 18.06.2012 19:12:01 End time: 18.06.2012 19:12:11 Duration: 0:00:09 Creating snapshot Failed to perform Veeam VSS freeze: guest OS "other26xLinuxGuest" is not supported |
antistaks
19.06.12
up
antistaks
20.06.12
up
pumbaEO
20.06.12
возможно потому что guest OS "other26xLinuxGuest" is not supported ? У тебя debian, почему не "Debian64_Guest" ?
Midaw
20.06.12
is not supported = неподдерживается
antistaks
21.06.12
Спасибо всем. Все же не понял в чем была ошибка, но точно не в is not supported, т.к., другие аналогичные виртуалки снимает на ура...
Проблема решена. |
Midaw
22.06.12
(5) и оказалось, что другие не "other26xLinuxGuest"? или как бы опытом в ломы поделиться?
