помогите восстановить работу локального sql-сервера ☑
0 yanejsh
18.09.12
SQl Server 2005, с утра комп два раза сам перезагружался. фиг знает почему, бесперебойник стоит - не помог. Видимо что-то с блоком питания. Ну да фиг с ним.
После этого перестала стартовать служба MSSQLServer.
В логах такое вижу:
Сначала вроде стартует, потом
2012-09-18 10:37:44.78 spid12s     Starting up database 'msdb'.
2012-09-18 10:37:44.79 spid16s     Starting up database 'TestBase'.
2012-09-18 10:37:45.96 spid12s     Error: 9003, Severity: 20, State: 1.
2012-09-18 10:37:45.96 spid12s     The log scan number (118:408:34) passed to log scan in database 'msdb' is not valid. This error may indicate data corruption or that the log file (.ldf) does not match the data file (.mdf). If this error occurred during replication, re-create the publication. Otherwise, restore from backup if the problem results in a failure during startup.
2012-09-18 10:37:45.96 spid12s     Error: 3414, Severity: 21, State: 1.
2012-09-18 10:37:45.96 spid12s     An error occurred during recovery, preventing the database 'msdb' (database ID 4) from restarting. Diagnose the recovery errors and fix them, or restore from a known good backup. If errors are not corrected or expected, contact Technical Support.
2012-09-18 10:37:46.02 spid16s     1 transactions rolled forward in database 'TestBase' (8). This is an informational message only. No user action is required.
2012-09-18 10:37:46.23 spid5s      0 transactions rolled back in database 'TestBase' (8). This is an informational message only. No user action is required.
2012-09-18 10:37:46.23 spid5s      Recovery is writing a checkpoint in database 'TestBase' (8). This is an informational message only. No user action is required.
2012-09-18 10:37:46.33 spid9s      Error: 824, Severity: 24, State: 2.
2012-09-18 10:37:46.33 spid9s      SQL Server detected a logical consistency-based I/O error: incorrect checksum (expected: 0x2fc01ada; actual: 0x2fc01986). It occurred during a read of page (2:0) in database ID 3 at offset 0000000000000000 in file 'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\modellog.ldf'.  Additional messages in the SQL Server error log or system event log may provide more detail. This is a severe error condition that threatens database integrity and must be corrected immediately. Complete a full database consistency check (DBCC CHECKDB). This error can be caused by many factors; for more information, see SQL Server Books Online.
2012-09-18 10:37:46.34 spid12s     Error: 926, Severity: 14, State: 1.
2012-09-18 10:37:46.34 spid12s     Database 'msdb' cannot be opened. It has been marked SUSPECT by recovery. See the SQL Server errorlog for more information.
2012-09-18 10:37:46.34 spid12s     Problems recording information in the msdb..suspect_pages table were encountered. This error does not interfere with any activity except maintenance of the suspect_pages table. Check the error log for more information.
2012-09-18 10:37:46.34 spid9s      Could not create tempdb. You may not have enough disk space available. Free additional disk space by deleting other files on the tempdb drive and then restart SQL Server. Check for additional errors in the event log that may indicate why the tempdb files could not be initialized.
2012-09-18 10:37:46.34 spid9s      SQL Trace was stopped due to server shutdown. Trace ID = '1'. This is an informational message only; no user action is required.
ничерта не понятно, что делать то?
все локально у меня на компе, помогите...
1 Mikeware
18.09.12
msdb в suspect'е
2 Жан Пердежон
18.09.12
(0) лог msdb прибей/скопируй в другое место
3 yanejsh
18.09.12
(1)это я понял, исправить то как?
(2) переместил - так все равно не запускается.
2012-09-18 11:14:00.88 spid13s     FileMgr::StartLogFiles: Operating system error 2(Не удается найти указанный файл.) occurred while creating or opening file 'C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\MSDBLog.ldf'. Diagnose and correct the operating system error, and retry the operation.
2012-09-18 11:14:00.93 spid13s     File activation failure. The physical file name "C:\Program Files\Microsoft SQL Server\MSSQL.1\MSSQL\DATA\MSDBLog.ldf" may be incorrect.
4 Mikeware
18.09.12
боюсь, что поднять что-то без восстановления резервной копии мсдб не получится.
5 yanejsh
18.09.12
да откуда резервная копия на тестовом компе. могу только переустановить сиквел
6 пипец
18.09.12
переставить скуль - приатачить базы
