Помогите со скриптом!!!
0 mzelensky
30.11.12
Вот функция
взял здесь:
http://www.1c-galaxy.ru/forum4/topic375656/
Функция ___обMD5(КодируемаяСтрока)
   ЗначениеВозврата = Истина;
   Попытка
       //http://pajhome.org.uk/crypt/md5/index.html
       ScrptCtrl = Новый COMОбъект("MSScriptControl.ScriptControl");
       ScrptCtrl.Language = "JScript";
       ScrptCtrl.AddCode("
       | * A JavaScript implementation of the RSA Data Security, Inc. MD5 Message
      | * Digest Algorithm, as defined in RFC 1321.
      | * Version 2.1 Copyright © Paul Johnston 1999 - 2002.
       | * Other contributors: Greg Holt, Andrew Kepert, Ydnar, Lostinet
       | * Distributed under the BSD License
       | * See http://pajhome.org.uk/crypt/md5   http://pajhome.org.uk/crypt/md5 for more info.
       | * Configurable variables. You may need to tweak these to be compatible with
       | * the server-side, but the defaults work in most cases.
       |var hexcase = 0;  /* hex output format. 0 - lowercase; 1 - uppercase        */
      |var b64pad  = """"; /* base-64 pad character. ""="" for strict RFC compliance   */
       |var chrsz   = 8;  /* bits per input character. 8 - ASCII; 16 - Unicode      */
       | * These are the functions you'll usually want to call
       | * They take string arguments and return either hex or base-64 encoded strings
       |function hex_md5(s){ return binl2hex(core_md5(str2binl(s), s.length * chrsz));}
       |function b64_md5(s){ return binl2b64(core_md5(str2binl(s), s.length * chrsz));}
       |function str_md5(s){ return binl2str(core_md5(str2binl(s), s.length * chrsz));}
       |function hex_hmac_md5(key, data) { return binl2hex(core_hmac_md5(key, data)); }
       |function b64_hmac_md5(key, data) { return binl2b64(core_hmac_md5(key, data)); }
       |function str_hmac_md5(key, data) { return binl2str(core_hmac_md5(key, data)); }
       | * Perform a simple self-test to see if the VM is working
       |function md5_vm_test()
       |  return hex_md5(""abc"") == ""900150983cd24fb0d6963f7d28e17f72"";
       | * Calculate the MD5 of an array of little-endian words, and a bit length
       |function core_md5(x, len)
       |  /* append padding */
       |  x[len >> 5] |= 0x80 >> 9) 16) bkey = core_md5(bkey, key.length * chrsz);
       |  var ipad = Array(16), opad = Array(16);
       |  for(var i = 0; i < 16; i++)
       |    ipad[i] = bkey[i] ^ 0x36363636;
       |    opad[i] = bkey[i] ^ 0x5C5C5C5C;
       |  var hash = core_md5(ipad.concat(str2binl(data)), 512 + data.length * chrsz);
       |  return core_md5(opad.concat(hash), 512 + 128);
       | * Add integers, wrapping at 2^32. This uses 16-bit operations internally
       | * to work around bugs in some JS interpreters.
       |function safe_add(x, y)
       |  var lsw = (x & 0xFFFF) + (y & 0xFFFF);
       |  var msw = (x >> 16) + (y >> 16) + (lsw >> 16);
       |  return (msw > (32 - cnt));
       | * Convert a string to an array of little-endian words
       | * If chrsz is ASCII, characters >255 have their hi-byte silently ignored.
       |function str2binl(str)
       |  var bin = Array();
       |  var mask = (1 >5] |= (str.charCodeAt(i / chrsz) & mask) 5] >>> (i % 32)) & mask);
       |  return str;
       | * Convert an array of little-endian words to a hex string.
       |function binl2hex(binarray)
       |  var hex_tab = hexcase ? ""0123456789ABCDEF"" : ""0123456789abcdef"";
       |  var str = """";
       |  for(var i = 0; i < binarray.length * 4; i++)
       |    str += hex_tab.charAt((binarray[i>>2] >> ((i%4)*8+4)) & 0xF) +
       |           hex_tab.charAt((binarray[i>>2] >> ((i%4)*8  )) & 0xF);
       |  return str;
       | * Convert an array of little-endian words to a base-64 string
       |function binl2b64(binarray)
       |  var tab = ""ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"";
       |  var str = """";
       |  for(var i = 0; i < binarray.length * 4; i += 3)
       |    var triplet = (((binarray[i   >> 2] >> 8 * ( i   %4)) & 0xFF) > 2] >> 8 * ((i+1)%4)) & 0xFF) > 2] >> 8 * ((i+2)%4)) & 0xFF);
       |    for(var j = 0; j < 4; j++)
       |      if(i * 8 + j * 6 > binarray.length * 32) str += b64pad;
       |      else str += tab.charAt((triplet >> 6*(3-j)) & 0x3F);
       |  return str;
       ЗначениеВозврата = "";
       ЗначениеВозврата = ScrptCtrl.Run("hex_md5", КодируемаяСтрока);
   Исключение
       ЗначениеВозврата = Неопределено;
       Сообщить(ОписаниеОшибки(), СтатусСообщения.ОченьВажное);
   КонецПопытки;
   ScrptCtrl = "";
   Возврат ЗначениеВозврата;
КонецФункции // MD5()
У меня вылетает с ошибкой (падает в попытку) с пояснением:
{Документ.Рейс.Форма.ФормаДокумента.Форма(305)}: Ошибка при вызове метода контекста (AddCode)
       ScrptCtrl.AddCode("/*
по причине:
Произошла исключительная ситуация (Ошибка компиляции Microsoft JScript): Предполагается наличие ';'
Не могу найти косяк в том коде :(
1 mzelensky
30.11.12
апну
2 Ёпрст
Функция MD5(КодируемаяСтрока)
   Хеш="";
   Попытка
       ScrptCtrl.AddCode("
       |  x[len >> 5] |= 0x80 << ((len) % 32);
       |  x[(((len + 64) >>> 9) << 4) + 14] = len;
       |  var a =  1732584193;
       |  var b = -271733879;
       |  var c = -1732584194;
       |  var d =  271733878;
       |  for(var i = 0; i < x.length; i += 16)
       |    var olda = a;
       |    var oldb = b;
       |    var oldc = c;
       |    var oldd = d;
       |    a = md5_ff(a, b, c, d, x[i+ 0], 7 , -680876936);
       |    d = md5_ff(d, a, b, c, x[i+ 1], 12, -389564586);
       |    c = md5_ff(c, d, a, b, x[i+ 2], 17,  606105819);
       |    b = md5_ff(b, c, d, a, x[i+ 3], 22, -1044525330);
       |    a = md5_ff(a, b, c, d, x[i+ 4], 7 , -176418897);
       |    d = md5_ff(d, a, b, c, x[i+ 5], 12,  1200080426);
       |    c = md5_ff(c, d, a, b, x[i+ 6], 17, -1473231341);
       |    b = md5_ff(b, c, d, a, x[i+ 7], 22, -45705983);
       |    a = md5_ff(a, b, c, d, x[i+ 8], 7 ,  1770035416);
       |    d = md5_ff(d, a, b, c, x[i+ 9], 12, -1958414417);
       |    c = md5_ff(c, d, a, b, x[i+10], 17, -42063);
       |    b = md5_ff(b, c, d, a, x[i+11], 22, -1990404162);
       |    a = md5_ff(a, b, c, d, x[i+12], 7 ,  1804603682);
       |    d = md5_ff(d, a, b, c, x[i+13], 12, -40341101);
       |    c = md5_ff(c, d, a, b, x[i+14], 17, -1502002290);
       |    b = md5_ff(b, c, d, a, x[i+15], 22,  1236535329);
       |    a = md5_gg(a, b, c, d, x[i+ 1], 5 , -165796510);
       |    d = md5_gg(d, a, b, c, x[i+ 6], 9 , -1069501632);
       |    c = md5_gg(c, d, a, b, x[i+11], 14,  643717713);
       |    b = md5_gg(b, c, d, a, x[i+ 0], 20, -373897302);
       |    a = md5_gg(a, b, c, d, x[i+ 5], 5 , -701558691);
       |    d = md5_gg(d, a, b, c, x[i+10], 9 ,  38016083);
       |    c = md5_gg(c, d, a, b, x[i+15], 14, -660478335);
       |    b = md5_gg(b, c, d, a, x[i+ 4], 20, -405537848);
       |    a = md5_gg(a, b, c, d, x[i+ 9], 5 ,  568446438);
       |    d = md5_gg(d, a, b, c, x[i+14], 9 , -1019803690);
       |    c = md5_gg(c, d, a, b, x[i+ 3], 14, -187363961);
       |    b = md5_gg(b, c, d, a, x[i+ 8], 20,  1163531501);
       |    a = md5_gg(a, b, c, d, x[i+13], 5 , -1444681467);
       |    d = md5_gg(d, a, b, c, x[i+ 2], 9 , -51403784);
       |    c = md5_gg(c, d, a, b, x[i+ 7], 14,  1735328473);
       |    b = md5_gg(b, c, d, a, x[i+12], 20, -1926607734);
       |    a = md5_hh(a, b, c, d, x[i+ 5], 4 , -378558);
       |    d = md5_hh(d, a, b, c, x[i+ 8], 11, -2022574463);
       |    c = md5_hh(c, d, a, b, x[i+11], 16,  1839030562);
       |    b = md5_hh(b, c, d, a, x[i+14], 23, -35309556);
       |    a = md5_hh(a, b, c, d, x[i+ 1], 4 , -1530992060);
       |    d = md5_hh(d, a, b, c, x[i+ 4], 11,  1272893353);
       |    c = md5_hh(c, d, a, b, x[i+ 7], 16, -155497632);
       |    b = md5_hh(b, c, d, a, x[i+10], 23, -1094730640);
       |    a = md5_hh(a, b, c, d, x[i+13], 4 ,  681279174);
       |    d = md5_hh(d, a, b, c, x[i+ 0], 11, -358537222);
       |    c = md5_hh(c, d, a, b, x[i+ 3], 16, -722521979);
       |    b = md5_hh(b, c, d, a, x[i+ 6], 23,  76029189);
       |    a = md5_hh(a, b, c, d, x[i+ 9], 4 , -640364487);
       |    d = md5_hh(d, a, b, c, x[i+12], 11, -421815835);
       |    c = md5_hh(c, d, a, b, x[i+15], 16,  530742520);
       |    b = md5_hh(b, c, d, a, x[i+ 2], 23, -995338651);
       |    a = md5_ii(a, b, c, d, x[i+ 0], 6 , -198630844);
       |    d = md5_ii(d, a, b, c, x[i+ 7], 10,  1126891415);
       |    c = md5_ii(c, d, a, b, x[i+14], 15, -1416354905);
       |    b = md5_ii(b, c, d, a, x[i+ 5], 21, -57434055);
       |    a = md5_ii(a, b, c, d, x[i+12], 6 ,  1700485571);
       |    d = md5_ii(d, a, b, c, x[i+ 3], 10, -1894986606);
       |    c = md5_ii(c, d, a, b, x[i+10], 15, -1051523);
       |    b = md5_ii(b, c, d, a, x[i+ 1], 21, -2054922799);
       |    a = md5_ii(a, b, c, d, x[i+ 8], 6 ,  1873313359);
       |    d = md5_ii(d, a, b, c, x[i+15], 10, -30611744);
       |    c = md5_ii(c, d, a, b, x[i+ 6], 15, -1560198380);
       |    b = md5_ii(b, c, d, a, x[i+13], 21,  1309151649);
       |    a = md5_ii(a, b, c, d, x[i+ 4], 6 , -145523070);
       |    d = md5_ii(d, a, b, c, x[i+11], 10, -1120210379);
       |    c = md5_ii(c, d, a, b, x[i+ 2], 15,  718787259);
       |    b = md5_ii(b, c, d, a, x[i+ 9], 21, -343485551);
       |    a = safe_add(a, olda);
       |    b = safe_add(b, oldb);
       |    c = safe_add(c, oldc);
       |    d = safe_add(d, oldd);
       |  return Array(a, b, c, d);
       |function md5_cmn(q, a, b, x, s, t)
       |  return safe_add(bit_rol(safe_add(safe_add(a, q), safe_add(x, t)), s),b);
       |function md5_ff(a, b, c, d, x, s, t)
       |  return md5_cmn((b & c) | ((~b) & d), a, b, x, s, t);
       |function md5_gg(a, b, c, d, x, s, t)
       |  return md5_cmn((b & d) | (c & (~d)), a, b, x, s, t);
       |function md5_hh(a, b, c, d, x, s, t)
       |  return md5_cmn(b ^ c ^ d, a, b, x, s, t);
       |function md5_ii(a, b, c, d, x, s, t)
       |  return md5_cmn(c ^ (b | (~d)), a, b, x, s, t);
       |function core_hmac_md5(key, data)
       |  var bkey = str2binl(key);
       |  if(bkey.length > 16) bkey = core_md5(bkey, key.length * chrsz);
       |  return (msw << 16) | (lsw & 0xFFFF);
       | * Bitwise rotate a 32-bit number to the left.
       |function bit_rol(num, cnt)
       |  return (num << cnt) | (num >>> (32 - cnt));
       |  var mask = (1 << chrsz) - 1;
       |  for(var i = 0; i < str.length * chrsz; i += chrsz)
       |    bin[i>>5] |= (str.charCodeAt(i / chrsz) & mask) << (i%32);
       |  return bin;
       |function binl2str(bin)
       |  var str = """";
       |  for(var i = 0; i < bin.length * 32; i += chrsz)
       |    str += String.fromCharCode((bin[i>>5] >>> (i % 32)) & mask);
       |  return str;
       |  var str = """";
       |  return str;
       |  var str = """";
       |    var triplet = (((binarray[i   >> 2] >> 8 * ( i   %4)) & 0xFF) << 16)
       |                | (((binarray[i+1 >> 2] >> 8 * ((i+1)%4)) & 0xFF) << 8 )
       |                |  ((binarray[i+2 >> 2] >> 8 * ((i+2)%4)) & 0xFF);
       |  return str;
       Хэш = ScrptCtrl.Run("hex_md5", КодируемаяСтрока);
   Исключение
       Сообщить(ОписаниеОшибки(), );
   КонецПопытки;
   ScrptCtrl = "";
   Возврат Хэш;
3 mzelensky
30.11.12
(2) Спасибо!!!
4 mzelensky
30.11.12
(3) + а где взял?!
5 Лефмихалыч
30.11.12
(0) ну, начнем с того, что сабж ты взял вот отсюда на самом деле v8: Получение MD5 хеша строки
6 zulu_mix
30.11.12
7 mzelensky
30.11.12
(5) нет, я взял от туда откуда написал.
А откуда на самом деле ноги растут...я уж не знаю.
8 Ёпрст
(4) с рабочей конфы.. а где стырил - не помню.
9 mzelensky
30.11.12
(8) кстати, в (6) тож хороший варик!
10 mzelensky
30.11.12
будет время - попробую на SHА-1 сделать :)
11 zulu_mix
30.11.12
ХЭШ=Прав(СохраняемоеЗначениеСтрокиПароля(НашаСтрока),28);
Функция СохраняемоеЗначениеСтрокиПароля(Знач Пароль,
                                       Знач ИдентификаторПользователяИБ = Неопределено,
                                       Совпадает = Ложь) Экспорт
   УстановитьПривилегированныйРежим(Истина);
   НачатьТранзакцию();
   Попытка
       ВременныйПользовательИБ = ПользователиИнформационнойБазы.СоздатьПользователя();
       ВременныйПользовательИБ.АутентификацияСтандартная = Истина;
       ВременныйПользовательИБ.Пароль = Пароль;
       ВременныйПользовательИБ.Имя = СтроковыеФункцииКлиентСервер.ПодставитьПараметрыВСтроку(
           НСтр("ru = 'Временный пользователь (%1)'"),
           Новый УникальныйИдентификатор);
       ВременныйПользовательИБ.Записать();
       ВременныйПользовательИБ = ПользователиИнформационнойБазы.НайтиПоУникальномуИдентификатору(
           ВременныйПользовательИБ.УникальныйИдентификатор);
       СохраняемоеЗначениеПароля = ВременныйПользовательИБ.СохраняемоеЗначениеПароля;
       ОтменитьТранзакцию();
   Исключение
       ВызватьИсключение;
   КонецПопытки;
   Если ТипЗнч(ИдентификаторПользователяИБ) = Тип("УникальныйИдентификатор") Тогда
           ИдентификаторПользователяИБ);
       Если ТипЗнч(ПользовательИБ) = Тип("ПользовательИнформационнойБазы") Тогда
           Совпадает = (СохраняемоеЗначениеПароля = ПользовательИБ.СохраняемоеЗначениеПароля);
   Возврат СохраняемоеЗначениеПароля;
КонецФункции
