Помогите транслировать/найти запрос t-sql в 1с | ☑ | ||
zharkin
06.05.13
Помогите найти место в конфигурации 1с, откуда может вызываться подобный запрос!
Вот текст запроса в t-sql exec sp_executesql N'SELECT ISNULL(CAST(T2._Q_000_F_001 AS NUMERIC(27, 2)),P1), T2._Q_000_F_000RRef, T1._Q_001_F_000_TYPE, T1._Q_001_F_000_RTRef, T1._Q_001_F_000_RRRef FROM #tt3 T1 WITH(NOLOCK) LEFT OUTER JOIN #tt2 T2 WITH(NOLOCK) LEFT OUTER JOIN _Document125 T3 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P3 AND T2._Q_000_F_002_RRRef = T3._IDRRef LEFT OUTER JOIN _Document87 T4 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P4 AND T2._Q_000_F_002_RRRef = T4._IDRRef LEFT OUTER JOIN _Document116 T5 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P5 AND T2._Q_000_F_002_RRRef = T5._IDRRef LEFT OUTER JOIN _Document131 T6 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P6 AND T2._Q_000_F_002_RRRef = T6._IDRRef LEFT OUTER JOIN _Document117 T7 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P7 AND T2._Q_000_F_002_RRRef = T7._IDRRef LEFT OUTER JOIN _Document61 T8 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P8 AND T2._Q_000_F_002_RRRef = T8._IDRRef LEFT OUTER JOIN _Document86 T9 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = @P9 AND T2._Q_000_F_002_RRRef = T9._IDRRef LEFT OUTER JOIN _Document120 T10 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = P10 AND T2._Q_000_F_002_RRRef = T10._IDRRef LEFT OUTER JOIN _Document115 T11 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = P11 AND T2._Q_000_F_002_RRRef = T11._IDRRef LEFT OUTER JOIN _Document62 T12 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = P12 AND T2._Q_000_F_002_RRRef = T12._IDRRef LEFT OUTER JOIN _Document118 T13 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = P13 AND T2._Q_000_F_002_RRRef = T13._IDRRef LEFT OUTER JOIN _Document119 T14 WITH(NOLOCK) ON T2._Q_000_F_002_TYPE = @P2 AND T2._Q_000_F_002_RTRef = P14 AND T2._Q_000_F_002_RRRef = T14._IDRRef ON ((T2._Q_000_F_002_TYPE = T1._Q_001_F_000_TYPE AND T2._Q_000_F_002_RTRef = T1._Q_001_F_000_RTRef AND T2._Q_000_F_002_RRRef = T1._Q_001_F_000_RRRef) OR (CASE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000007D THEN T3._Fld2891_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000057 THEN T4._Fld1639_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000074 THEN T5._Fld2429_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000083 THEN T6._Fld3052_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000075 THEN T7._Fld2483_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000003D THEN T8._Fld775_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000056 THEN T9._Fld1586_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000078 THEN T10._Fld2633_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000073 THEN T11._Fld2379_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000003E THEN T12._Fld832_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000076 THEN T13._Fld2539_TYPE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000077 THEN T14._Fld2589_TYPE ELSE CAST(NULL AS BINARY(1)) END = T1._Q_001_F_000_TYPE AND CASE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000007D THEN T3._Fld2891_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000057 THEN T4._Fld1639_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000074 THEN T5._Fld2429_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000083 THEN T6._Fld3052_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000075 THEN T7._Fld2483_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000003D THEN T8._Fld775_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000056 THEN T9._Fld1586_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000078 THEN T10._Fld2633_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000073 THEN T11._Fld2379_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000003E THEN T12._Fld832_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000076 THEN T13._Fld2539_RTRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000077 THEN T14._Fld2589_RTRef ELSE CAST(NULL AS BINARY(4)) END = T1._Q_001_F_000_RTRef AND CASE WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000007D THEN T3._Fld2891_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000057 THEN T4._Fld1639_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000074 THEN T5._Fld2429_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000083 THEN T6._Fld3052_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000075 THEN T7._Fld2483_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000003D THEN T8._Fld775_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000056 THEN T9._Fld1586_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000078 THEN T10._Fld2633_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000073 THEN T11._Fld2379_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x0000003E THEN T12._Fld832_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000076 THEN T13._Fld2539_RRRef WHEN T2._Q_000_F_002_TYPE = 0x08 AND T2._Q_000_F_002_RTRef = 0x00000077 THEN T14._Fld2589_RRRef ELSE CAST(NULL AS BINARY(16)) END = T1._Q_001_F_000_RRRef)) WHERE (ISNULL(CAST(T2._Q_000_F_001 AS NUMERIC(27, 2)),P1) > P1)', N'P1 numeric(1,0),@P2 varbinary(1),@P3 varbinary(4),@P4 varbinary(4),@P5 varbinary(4),@P6 varbinary(4),@P7 varbinary(4),@P8 varbinary(4),@P9 varbinary(4),P10 varbinary(4),P11 varbinary(4),P12 varbinary(4),P13 varbinary(4),P14 varbinary(4)', 0, 0x08, 0x0000007D, 0x00000057, 0x00000074, 0x00000083, 0x00000075, 0x0000003D, 0x00000056, 0x00000078, 0x00000073, 0x0000003E, 0x00000076, 0x00000077 |
бомболюк
06.05.13
по мне так это показ формы списка какого то журнала документов.
zharkin
06.05.13
не могу понять, откуда такой запрос вызывается. конфа УТ 10.2
zharkin
06.05.13
(2) у меня тоже закралось подозрение, что это какой то список документов
piter3
06.05.13
сначала выяснить, что есть documentsxxx
shuhard
06.05.13
(3)[не могу понять, откуда такой запрос вызывается]
ну уж форум точно не может угадать что стоит за Fld2891 в твоем экземпляре УТ 10.2 |
zharkin
06.05.13
все документы _Document я выяснил - это ПКО, РКО и все банковские доки. Не понятно вот это FROM #tt3 T1 WITH(NOLOCK)
SherifSP
06.05.13
ТС, тебе на битву экстрасенсов нужно, там тебе точно скажут откуда вызывается данный код)
mikecool
06.05.13
#tt3 это временная таблица
ищи ПОМЕСТИТЬ |
1Сергей
06.05.13
(9) = INTO
Sammo
06.05.13
1. Откуда взят запрос?
2. Зачем оно надо? Попробуй поискать - обращение к реквизиту составного типа, который имеет тип 125 и т.д. |
zharkin
06.05.13
1. запрос взят из профайлера - этот запрос очень грузит процессор 2. найти и оптимизировать этот запрос или вообще от него отказаться |
Sammo
06.05.13
Выбрать
ЕстьNULL(числовой реквизит, 0), Ссылка, Ссылка из |
Sammo
06.05.13
(12) Включить технологический журнал и там смотреть долго выполняемые запросы 1с. После этого по времени и тесту свести со скулевым.
GANR
06.05.13
(0) Принцип деления пополам понимаешь? Делишь участок кода, на котором выполняется это запрос на 2 и тот, на котором запроса нет, отбрасываешь - и так, пока интервал не сведется к одной строчке кода, где и выполняется этот самый запрос. Все понятно???
GANR
06.05.13
Вот пример http://eco.sutd.ru/Study/Informat/mpd.html, только в нем идет речь о точке пересечения функции с осью Х, а у нас - о строчке кода в 1С, где выполняется запрос.
GANR
06.05.13
Есть, конечно, неприятный момент - в коде могу быть циклы.
Speshuric
06.05.13
1. Это запрос в котором соединяется 2 временные таблицы по реквизиту от поля составного типа. В нём есть что-то вроде: ИЗ ВременнаяТаблица1 ЛЕВОЕ СОЕДИНЕНИЕ ВременнаяТаблица2 ПО ВременнаяТаблица1.Док.Основание = ВременнаяТаблица2.Док (может там и не основание, а какой-то другой рекивзит - это легко посмотреть, например по "_Fld2589_RRRef" ) 2. Составные типы - зло, а временными таблицами надо уметь пользоваться. |
zharkin
06.05.13
(18) составные типы к сожалению повсеместно используются в типовых конфигурациях.
zharkin
06.05.13
(18) да, это реквизит ДокументОснование из документа ПлатежныйОрдерПоступлениеДенежныхСредств
Speshuric
06.05.13
(19) Вот не надо лишнего на типовые наговаривать. Да, составные типы там используются, но условий соединения типа того что приведено выше там не встречается.
(20) Ну и искать по коду где есть "ПО " и через две точки "ДокументОснование". Можно глазами, можно выгрузить d MXL |
Infsams654
06.05.13
(0) а для чего это нужно искать? Не нравится этот запрос t-sql, нужно предъявить 1С, что из этого места должно выглядеть по-другому ?
Speshuric
06.05.13
(14) Глупость сказал. Если ТЖ включить, то нафига сопоставлять? ТЖ и сам всё скажет.
Sammo
07.05.13
07:07
(23) Полуглупость. Имхо, про включение ТЖ - прав.
vde69
07.05.13
07:45
это RLS ...
"exec sp_executesql " - этим отличается рельса от прямого запроса |
vde69
07.05.13
07:56
(25)+
а таблица #tt3 - это результат прямого запроса на который накладывается уже сама рельса. ИХМО накладывание происходит внутри ХП из-за некоторых нюансов с правами. |
zharkin
07.05.13
помогло включение ТЖ.
сделал такой файл настройки logcfg.xml <?xml version="1.0" encoding="utf-8"?> <config xmlns="http://v8.1c.ru/v8/tech-log"> <dump create="false" /> <log location="D:\1Clog\" history="168"> <event> <eq property="Name" value="DBMSSQL"/> <ge property="Duration" value="40000"/> </event> <property name="Context"/> </log> </config> |
zharkin
07.05.13
получил текст модуля, который создавал запрос.
vde69
07.05.13
(28) и реально в модуле нашел этот запрос???
zharkin
07.05.13
(29)да. только он на языке 1С очень сильно отличается от t-sql
zharkin
07.05.13
оказалось не rls....
Speshuric
07.05.13
(28) Покажи хоть проблемное место в виде 1С-ного запроса.
Fragster
Где-то раньше есть определение Insert #tt3 Select..., вот в его сторону надо копать
TormozIT
Технологический журнал спасет.
ILM
Вопрос зачем уже задавали?
zharkin
13.05.13
(32) вот кусок проблемного запроса, особенно условие "Расчеты.Сделка.ДокументОснование = СведенияДок.КПКДокумент"
ВЫБРАТЬ ЕСТЬNULL(Расчеты.СуммаВзаиморасчетовОстаток, 0) КАК СуммаВзаиморасчетовОстаток, Расчеты.Контрагент, СведенияДок.КПКДокумент ИЗ СведенияДок КАК СведенияДок ЛЕВОЕ СОЕДИНЕНИЕ Расчеты КАК Расчеты ПО (Расчеты.Сделка = СведенияДок.КПКДокумент ИЛИ Расчеты.Сделка.ДокументОснование = СведенияДок.КПКДокумент) ГДЕ ЕСТЬNULL(Расчеты.СуммаВзаиморасчетовОстаток, 0) > 0 |
