DD-WRT OpenVPN
0 Trotter
04.04.14
Доброго времени суток.
#!/bin/sh
#USERNAME="MyUsername"
#PASSWORD="MyPassword" # Your HMA_USER_PASSWORD not PPTP password
PROTOCOL="udp" # udp / tcp MUST BE lower case
# Add - delete - edit servers between ##BB## and ##EE##
REMOTE_SERVERS="
##BB##
# Atlanta - UDP
remote Мой IP порт
##EE##
#### DO NOT CHANGE below this line ####
CA_CRT='-----BEGIN CERTIFICATE-----
ключик
-----END CERTIFICATE-----
CLIENT_CRT='Ключик
CLIENT_KEY='Ключик'
OPVPNENABLE=`nvram get openvpncl_enable | awk '$1 == "0" {print $1}'`
if [ "$OPVPNENABLE" != 0 ]
then
   nvram set openvpncl_enable=0
   nvram commit
fi
sleep 30
mkdir /tmp/hmavpncl; cd /tmp/hmavpncl
#echo -e "$USERNAME\n$PASSWORD" > userpass.conf
echo "$CA_CRT" > ca.crt; echo "$CLIENT_CRT" > client.crt; echo "$CLIENT_KEY" > client.key
echo "#!/bin/sh" > route-up.sh; echo -e "#!/bin/sh\nsleep 2" > route-down.sh
echo "#!/bin/sh
iptables -I FORWARD -i br0 -o tun0 -j ACCEPT
iptables -I FORWARD -i tun0 -o br0 -j ACCEPT
iptables -I INPUT -i tun0 -j REJECT
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE" > /tmp/.rc_firewall
chmod 644 ca.crt client.crt; chmod 600 client.key userpass.conf; chmod 700 route-up.sh route-down.sh
chmod 700 /tmp/.rc_firewall
sleep 30
echo "client
proto $PROTOCOL
tls-client
client
dev tun
#proto udp
tun-mtu 1400
remote-random
cipher BF-CBC
comp-lzo
verb 3
ns-cert-type server
ca ca.crt
cert client.crt
key client.key
daemon
#auth-user-pass userpass.conf
#remote-random
$REMOTE_SERVERS" > openvpn.conf
ln -s /tmp/hmavpncl/hmavpn.log /tmp/hmavpn.log
(killall openvpn; openvpn --config /tmp/hmavpncl/openvpn.conf --route-up /tmp/hmavpncl/route-up.sh --down-pre /tmp/hmavpncl/route-down.sh) &
exit 0
Стоит ли добавлять вот это ?
iptables -I INPUT 3 -i tun0 -p icmp -j ACCEPT
iptables -I INPUT 1 -i tun0 -p tcp --dport 80 -j ACCEPT
Вот не подключается он с этим конфигом, хоть тресни (((
Добавил в Sava Start Up
Ребутнул роутер, смотрю лог в центральном офисе на роутер сервере, а он пустой, он даже не пытается стукнутся
