TinyMCE не выводит на управляемой форме ☑
0 Boudybuilder
23.07.14
Нашел обработку на сайте. Пробую перенести функционал на УФ.
Но выводит без стилей , панели редактирования. Только поле редактирования текста.
<HTML><HEAD><meta http-equiv="Content-Type" content="text/html; charset=windows-1251" content="no-cache">
<script type="text/javascript" src="tinyMCE/tinyMCE/jscripts/tiny_mce/tiny_mce.js"></script>
<!-- TinyMCE -->
<script type="text/javascript">
  tinyMCE.init({
    // General options
    mode : "textareas",
    theme : "advanced",
    plugins : "safari,pagebreak,style,layer,table,save,advhr,advimage,advlink,emotions,iespell,inlinepopups,insertdatetime,preview,media,searchreplace,print,contextmenu,paste,directionality,fullscreen,noneditable,visualchars,nonbreaking,xhtmlxtras,template",
    entity_encoding : "raw",
    // Theme options
    theme_advanced_buttons1 : "save,newdocument,|,bold,italic,underline,strikethrough,|,justifyleft,justifycenter,justifyright,justifyfull,styleselect,formatselect,fontselect,fontsizeselect",
    theme_advanced_buttons2 : "cut,copy,paste,pastetext,pasteword,|,search,replace,|,bullist,numlist,|,outdent,indent,blockquote,|,undo,redo,|,link,unlink,anchor,image,cleanup,help,code,|,insertdate,inserttime,preview,|,forecolor,backcolor",
    theme_advanced_buttons3 : "tablecontrols,|,hr,removeformat,visualaid,|,sub,sup,|,charmap,emotions,iespell,media,advhr,|,print,|,ltr,rtl,|,fullscreen",
    theme_advanced_buttons4 : "insertlayer,moveforward,movebackward,absolute,|,styleprops,|,cite,abbr,acronym,del,ins,attribs,|,visualchars,nonbreaking,template,pagebreak",
    theme_advanced_toolbar_location : "top",
    theme_advanced_toolbar_align : "left",
    theme_advanced_statusbar_location : "bottom",
    theme_advanced_resizing : true,
    // Example content CSS (should be your site CSS)
    content_css : "[CSS]",
    // Drop lists for link/image/media/template dialogs
    template_external_list_url : "lists/template_list.js",
    external_link_list_url : "lists/link_list.js",
    external_image_list_url : "lists/image_list.js",
    media_external_list_url : "lists/media_list.js",
    // Replace values for the template plugin
    template_replace_values : {
      username : "Some User",
      staffid : "991234"
</script>
<!-- /TinyMCE -->
</HEAD><BODY><FONT FACE="Arial" SIZE="-1">
<form method="\" action="\" onsubmit="return false;">
<textarea id="elm1" name="elm1" style="width: 100%;height:100%">
</textarea>
</FONT></BODY></HTML>
По этому тексту переходит поле HTML
ВремФайл = КаталогДанных + "temp.html";
    Т.Записать(ВремФайл, КодировкаТекста.ANSI);
    Эксплорер.Перейти(ВремФайл);
У меня же на УФ так :
Эксплорер = Т.ПолучитьТекст();
подозреваю что скрипты не подгружаются.  Как быть ?
Хотя все сохранено аналогично обработке для обычного приложения.
1 Boudybuilder
23.07.14
Вот такое выводит : https://yadi.sk/i/zPoOkoj9XBnQU
2 Boudybuilder
23.07.14
Скорее всего со скриптами таки беда. Проэксперементировал с файликом через веб браузер. И то же самое показало , пока не вставил так <script type="text/javascript" src="file:///C:/Users/vitaliy/AppData/Local/Temp/TinyMCE/tinymce/tinyMCE/jscripts/tiny_mce/tiny_mce.js"></script>
но на 1С это не срабатывает
3 Полотенчик
23.07.14
вставь содержимое tinyMCE/tinyMCE/jscripts/tiny_mce/tiny_mce.js прямо в текст ХТМЛ, без ссылок на внешний файл
4 Boudybuilder
23.07.14
(3) Вот содержимое.
Склеить поможешь с файлом?
А то я в HTML не силен
var tinymce={majorVersion:"3",minorVersion:"2.6",releaseDate:"2009-08-19",_init:function(){var o=this,k=document,l=window,j=navigator,b=j.userAgent,h,a,g,f,e,m;o.isOpera=l.opera&&opera.buildNumber;o.isWebKit=/WebKit/.test(b);o.isIE=!o.isWebKit&&!o.isOpera&&(/MSIE/gi).test(b)&&(/Explorer/gi).test(j.appName);o.isIE6=o.isIE&&/MSIE [56]/.test(b);o.isGecko=!o.isWebKit&&/Gecko/.test(b);o.isMac=b.indexOf("Mac")!=-1;o.isAir=/adobeair/i.test(b);if(l.tinyMCEPreInit){o.suffix=tinyMCEPreInit.suffix;o.baseURL=tinyMCEPreInit.base;o.query=tinyMCEPreInit.query;return}o.suffix="";a=k.getElementsByTagName("base");for(h=0;h<a.length;h++){if(m=a[h].href){if(/^https?:\/\/[^\/]+$/.test(m)){m+="/"}f=m?m.match(/.*\//)[0]:""}}function c(d){if(d.src&&/tiny_mce(|_gzip|_jquery|_prototype)(_dev|_src)?.js/.test(d.src)){if(/_(src|dev)\.js/g.test(d.src)){o.suffix="_src"}if((e=d.src.indexOf("?"))!=-1){o.query=d.src.substring(e+1)}o.baseURL=d.src.substring(0,d.src.lastIndexOf("/"));if(f&&o.baseURL.indexOf("://")==-1&&o.baseURL.indexOf("/")!==0){o.baseURL=f+o.baseURL}return o.baseURL}return null}a=k.getElementsByTagName("script");for(h=0;h<a.length;h++){if(c(a[h])){return}}g=k.getElementsByTagName("head")[0];if(g){a=g.getElementsByTagName("script");for(h=0;h<a.length;h++){if(c(a[h])){return}}}return},is:function(b,a){var c=typeof(b);if(!a){return c!="undefined"}if(a=="array"&&(b.hasOwnProperty&&b instanceof Array)){return true}return c==a},each:function(d,a,c){var e,b;if(!d){return 0}c=c||d;if(typeof(d.length)!="undefined"){for(e=0,b=d.length;e<b;e++){if(a.call(c,d[e],e,d)===false){return 0}}}else{for(e in d){if(d.hasOwnProperty(e)){if(a.call(c,d[e],e,d)===false){return 0}}}}return 1},map:function(b,c){var d=[];tinymce.each(b,function(a){d.push(c(a))});return d},grep:function(b,c){var d=[];tinymce.each(b,function(a){if(!c||c(a)){d.push(a)}});return d},inArray:function(c,d){var e,b;if(c){for(e=0,b=c.length;e<b;e++){if(c[e]===d){return e}}}return -1},extend:function(f,d){var c,b=arguments;for(c=1;c<b.length;c++){d=b[c];tinymce.each(d,function(a,e){if(typeof(a)!=="undefined"){f[e]=a}})}return f},trim:function(a){return(a?""+a:"").replace(/^\s*|\s*$/g,"")},create:function(j,a){var i=this,b,e,f,g,d,h=0;j=/^((static) )?([\w.]+)(:([\w.]+))?/.exec(j);f=j[3].match(/(^|\.)(\w+)$/i)[2];e=i.createNS(j[3].replace(/\.\w+$/,""));if(e[f]){return}if(j[2]=="static"){e[f]=a;if(this.onCreate){this.onCreate(j[2],j[3],e[f])}return}if(!a[f]){a[f]=function(){};h=1}e[f]=a[f];i.extend(e[f].prototype,a);if(j[5]){b=i.resolve(j[5]).prototype;g=j[5].match(/\.(\w+)$/i)[1];d=e[f];if(h){e[f]=function(){return b[g].apply(this,arguments)}}else{e[f]=function(){this.parent=b[g];return d.apply(this,arguments)}}e[f].prototype[f]=e[f];i.each(b,function(c,k){e[f].prototype[k]=b[k]});i.each(a,function(c,k){if(b[k]){e[f].prototype[k]=function(){this.parent=b[k];return c.apply(this,arguments)}}else{if(k!=f){e[f].prototype[k]=c}}})}i.each(a["static"],function(c,k){e[f][k]=c});if(this.onCreate){this.onCreate(j[2],j[3],e[f].prototype)}},walk:function(c,b,d,a){a=a||this;if(c){if(d){c=c[d]}tinymce.each(c,function(f,e){if(b.call(a,f,e,d)===false){return false}tinymce.walk(f,b,d,a)})}},createNS:function(d,c){var b,a;c=c||window;d=d.split(".");for(b=0;b<d.length;b++){a=d[b];if(!c[a]){c[a]={}}c=c[a]}return c},resolve:function(d,c){var b,a;c=c||window;d=d.split(".");for(b=0,a=d.length;b<a;b++){c=c[d[b]];if(!c){break}}return c},addUnload:function(e,d){var c=this,a=window;e={func:e,scope:d||this};if(!c.unloads){function b(){var f=c.unloads,h,i;if(f){for(i in f){h=f[i];if(h&&h.func){h.func.call(h.scope,1)}}if(a.detachEvent){a.detachEvent("onbeforeunload",g);a.detachEvent("onunload",b)}else{if(a.removeEventListener){a.removeEventListener("unload",b,false)}}c.unloads=h=f=a=b=0;if(window.CollectGarbage){window.CollectGarbage()}}}function g(){var h=document;if(h.readyState=="interactive"){function f(){h.detachEvent("onstop",f);if(b){b()}h=0}if(h){h.attachEvent("onstop",f)}window.setTimeout(function(){if(h){h.detachEvent("onstop",f)}},0)}}if(a.attachEvent){a.attachEvent("onunload",b);a.attachEvent("onbeforeunload",g)}else{if(a.addEventListener){a.addEventListener("unload",b,false)}}c.unloads=[e]}else{c.unloads.push(e)}return e},removeUnload:function(c){var a=this.unloads,b=null;tinymce.each(a,function(e,d){if(e&&e.func==c){a.splice(d,1);b=c;return false}});return b},explode:function(a,b){return a?tinymce.map(a.split(b||","),tinymce.trim):a},_addVer:function(b){var a;if(!this.query){return b}a=(b.indexOf("?")==-1?"?":"&")+this.query;if(b.indexOf("#")==-1){return b+a}return b.replace("#",a+"#")}};window.tinymce=tinymce;tinymce._init();tinymce.create("tinymce.util.Dispatcher",{scope:null,listeners:null,Dispatcher:function(a){this.scope=a||this;this.listeners=[]},add:function(a,b){this.listeners.push({cb:a,scope:b||this.scope});return a},addToTop:function(a,b){this.listeners.unshift({cb:a,scope:b||this.scope});return a},remove:function(a){var b=this.listeners,c=null;tinymce.each(b,function(e,d){if(a==e.cb){c=a;b.splice(d,1);return false}});return c},dispatch:function(){var f,d=arguments,e,b=this.listeners,g;for(e=0;e<b.length;e++){g=b[e];f=g.cb.apply(g.scope,d);if(f===false){break}}return f}});(function(){var a=tinymce.each;tinymce.create("tinymce.util.URI",{URI:function(e,g){var f=this,h,d,c;e=tinymce.trim(e);g=f.settings=g||{};if(/^(mailto|tel|news|javascript|about|data):/i.test(e)||/^\s*#/.test(e)){f.source=e;return}if(e.indexOf("/")===0&&e.indexOf("//")!==0){e=(g.base_uri?g.base_uri.protocol||"http":"http")+"://mce_host"+e}if(!/^\w*:?\/\//.test(e)){e=(g.base_uri.protocol||"http")+"://mce_host"+f.toAbsPath(g.base_uri.path,e)}e=e.replace(/@@/g,"(mce_at)");e=/^(?:(?![^:@]+:[^:@\/]*@)([^:\/?#.]+):)?(?:\/\/)?((?:(([^:@]*):?([^:@]*))?@)?([^:\/?#]*)(?::(\d*))?)(((\/(?:[^?#](?![^?#\/]*\.[^?#\/.]+(?:[?#]|$)))*\/?)?([^?#\/]*))(?:\?([^#]*))?(?:#(.*))?)/.exec(e);a(["source","protocol","authority","userInfo","user","password","host","port","relative","path","directory","file","query","anchor"],function(b,j){var k=e[j];if(k){k=k.replace(/\(mce_at\)/g,"@@")}f[b]=k});if(c=g.base_uri){if(!f.protocol){f.protocol=c.protocol}if(!f.userInfo){f.userInfo=c.userInfo}if(!f.port&&f.host=="mce_host"){f.port=c.port}if(!f.host||f.host=="mce_host"){f.host=c.host}f.source=""}},setPath:function(c){var b=this;c=/^(.*?)\/?(\w+)?$/.exec(c);b.path=c[0];b.directory=c[1];b.file=c[2];b.source="";b.getURI()},toRelative:function(b){var c=this,d;if(b==="./"){return b}b=new tinymce.util.URI(b,{base_uri:c});if((b.host!="mce_host"&&c.host!=b.host&&b.host)||c.port!=b.port||c.protocol!=b.protocol){return b.getURI()}d=c.toRelPath(c.path,b.path);if(b.query){d+="?"+b.query}if(b.anchor){d+="#"+b.anchor}return d},toAbsolute:function(b,c){var b=new tinymce.util.URI(b,{base_uri:this});return b.getURI(this.host==b.host?c:0)},toRelPath:function(g,h){var c,f=0,d="",e,b;g=g.substring(0,g.lastIndexOf("/"));g=g.split("/");c=h.split("/");if(g.length>=c.length){for(e=0,b=g.length;e<b;e++){if(e>=c.length||g[e]!=c[e]){f=e+1;break}}}if(g.length<c.length){for(e=0,b=c.length;e<b;e++){if(e>=g.length||g[e]!=c[e]){f=e+1;break}}}if(f==1){return h}for(e=0,b=g.length-(f-1);e<b;e++){d+="../"}for(e=f-1,b=c.length;e<b;e++){if(e!=f-1){d+="/"+c[e]}else{d+=c[e]}}return d},toAbsPath:function(e,f){var c,b=0,g=[],d;d=/\/$/.test(f)?"/":"";e=e.split("/");f=f.split("/");a(e,function(h){if(h){g.push(h)}});e=g;for(c=f.length-1,g=[];c>=0;c--){if(f[c].length==0||f[c]=="."){continue}if(f[c]==".."){b++;continue}if(b>0){b--;continue}g.push(f[c])}c=e.length-b;if(c<=0){return"/"+g.reverse().join("/")+d}return"/"+e.slice(0,c).join("/")+"/"+g.reverse().join("/")+d},getURI:function(d){var c,b=this;if(!b.source||d){c="";if(!d){if(b.protocol){c+=b.protocol+"://"}if(b.userInfo){c+=b.userInfo+"@"}if(b.host){c+=b.host}if(b.port){c+=":"+b.port}}if(b.path){c+=b.path}if(b.query){c+="?"+b.query}if(b.anchor){c+="#"+b.anchor}b.source=c}return b.source}})})();(function(){var a=tinymce.each;tinymce.create("static tinymce.util.Cookie",{getHash:function(d){var b=this.get(d),c;if(b){a(b.split("&"),function(e){e=e.split("=");c=c||{};c[unescape(e[0])]=unescape(e[1])})}return c},setHash:function(j,b,g,f,i,c){var h="";a(b,function(e,d){h+=(!h?"":"&")+escape(d)+"="+escape(e)});this.set(j,h,g,f,i,c)},get:function(i){var h=document.cookie,g,f=i+"=",d;if(!h){return}d=h.indexOf("; "+f);if(d==-1){d=h.indexOf(f);if(d!=0){return null}}else{d+=2}g=h.indexOf(";",d);if(g==-1){g=h.length}return unescape(h.substring(d+f.length,g))},set:function(i,b,g,f,h,c){document.cookie=i+"="+escape(b)+((g)?"; expires="+g.toGMTString():"")+((f)?"; path="+escape(f):"")+((h)?"; domain="+h:"")+((c)?"; secure":"")},remove:function(e,b){var c=new Date();c.setTime(c.getTime()-1000);this.set(e,"",c,b,c)}})})();tinymce.create("static tinymce.util.JSON",{serialize:function(e){var c,a,d=tinymce.util.JSON.serialize,b;if(e==null){return"null"}b=typeof e;if(b=="string"){a="\bb\tt\nn\ff\rr\"\"''\\\\";return'"'+e.replace(/([\u0080-\uFFFF\x00-\x1f\"])/g,function(g,f){c=a.indexOf(f);if(c+1){return"\\"+a.charAt(c+1)}g=f.charCodeAt().toString(16);return"\\u"+"0000".substring(g.length)+g})+'"'}if(b=="object"){if(e.hasOwnProperty&&e instanceof Array){for(c=0,a="[";c<e.length;c++){a+=(c>0?",":"")+d(e[c])}return a+"]"}a="{";for(c in e){a+=typeof e[c]!="function"?(a.length>1?',"':'"')+c+'":'+d(e[c]):""}return a+"}"}return""+e},parse:function(s){try{return eval("("+s+")")}catch(ex){}}});tinymce.create("static tinymce.util.XHR",{send:function(g){var a,e,b=window,h=0;g.scope=g.scope||this;g.success_scope=g.success_scope||g.scope;g.error_scope=g.error_scope||g.scope;g.async=g.async===false?false:true;g.data=g.data||"";function d(i){a=0;try{a=new ActiveXObject(i)}catch(c){}return a}a=b.XMLHttpRequest?new XMLHttpRequest():d("Microsoft.XMLHTTP")||d("Msxml2.XMLHTTP");if(a){if(a.overrideMimeType){a.overrideMimeType(g.content_type)}a.open(g.type||(g.data?"POST":"GET"),g.url,g.async);if(g.content_type){a.setRequestHeader("Content-Type",g.content_type)}a.setRequestHeader("X-Requested-With","XMLHttpRequest");a.send(g.data);function f(){if(!g.async||a.readyState==4||h++>10000){if(g.success&&h<10000&&a.status==200){g.success.call(g.success_scope,""+a.responseText,a,g)}else{if(g.error){g.error.call(g.error_scope,h>10000?"TIMED_OUT":"GENERAL",a,g)}}a=null}else{b.setTimeout(f,10)}}if(!g.async){return f()}e=b.setTimeout(f,10)}}});(function(){var c=tinymce.extend,b=tinymce.util.JSON,a=tinymce.util.XHR;tinymce.create("tinymce.util.JSONRequest",{JSONRequest:function(d){this.settings=c({},d);this.count=0},send:function(f){var e=f.error,d=f.success;f=c(this.settings,f);f.success=function(h,g){h=b.parse(h);if(typeof(h)=="undefined"){h={error:"JSON Parse error."}}if(h.error){e.call(f.error_scope||f.scope,h.error,g)}else{d.call(f.success_scope||f.scope,h.result)}};f.error=function(h,g){e.call(f.error_scope||f.scope,h,g)};f.data=b.serialize({id:f.id||"c"+(this.count++),method:f.method,params:f.params});f.content_type="application/json";a.send(f)},"static":{sendRPC:function(d){return new tinymce.util.JSONRequest().send(d)}}})}());(function(c){var e=c.each,b=c.is;var d=c.isWebKit,a=c.isIE;c.create("tinymce.dom.DOMUtils",{doc:null,root:null,files:null,pixelStyles:/^(top|left|bottom|right|width|height|borderWidth)$/,props:{"for":"htmlFor","class":"className",className:"className",checked:"checked",disabled:"disabled",maxlength:"maxLength",readonly:"readOnly",selected:"selected",value:"value",id:"id",name:"name",type:"type"},DOMUtils:function(i,g){var f=this;f.doc=i;f.win=window;f.files={};f.cssFlicker=false;f.counter=0;f.boxModel=!c.isIE||i.compatMode=="CSS1Compat";f.stdMode=i.documentMode===8;f.settings=g=c.extend({keep_values:false,hex_colors:1,process_html:1},g);if(c.isIE6){try{i.execCommand("BackgroundImageCache",false,true)}catch(h){f.cssFlicker=true}}c.addUnload(f.destroy,f)},getRoot:function(){var f=this,g=f.settings;return(g&&f.get(g.root_element))||f.doc.body},getViewPort:function(g){var h,f;g=!g?this.win:g;h=g.document;f=this.boxModel?h.documentElement:h.body;return{x:g.pageXOffset||f.scrollLeft,y:g.pageYOffset||f.scrollTop,w:g.innerWidth||f.clientWidth,h:g.innerHeight||f.clientHeight}},getRect:function(i){var h,f=this,g;i=f.get(i);h=f.getPos(i);g=f.getSize(i);return{x:h.x,y:h.y,w:g.w,h:g.h}},getSize:function(j){var g=this,f,i;j=g.get(j);f=g.getStyle(j,"width");i=g.getStyle(j,"height");if(f.indexOf("px")===-1){f=0}if(i.indexOf("px")===-1){i=0}return{w:parseInt(f)||j.offsetWidth||j.clientWidth,h:parseInt(i)||j.offsetHeight||j.clientHeight}},getParent:function(i,h,g){return this.getParents(i,h,g,false)},getParents:function(p,k,i,m){var h=this,g,j=h.settings,l=[];p=h.get(p);m=m===undefined;if(j.strict_root){i=i||h.getRoot()}if(b(k,"string")){g=k;if(k==="*"){k=function(f){return f.nodeType==1}}else{k=function(f){return h.is(f,g)}}}while(p){if(p==i||!p.nodeType||p.nodeType===9){break}if(!k||k(p)){if(m){l.push(p)}else{return p}}p=p.parentNode}return m?l:null},get:function(f){var g;if(f&&this.doc&&typeof(f)=="string"){g=f;f=this.doc.getElementById(f);if(f&&f.id!==g){return this.doc.getElementsByName(g)[1]}}return f},getNext:function(g,f){return this._findSib(g,f,"nextSibling")},getPrev:function(g,f){return this._findSib(g,f,"previousSibling")},select:function(h,g){var f=this;return c.dom.Sizzle(h,f.get(g)||f.get(f.settings.root_element)||f.doc,[])},is:function(g,f){return c.dom.Sizzle.matches(f,g.nodeType?[g]:g).length>0},add:function(j,l,f,i,k){var g=this;return this.run(j,function(n){var m,h;m=b(l,"string")?g.doc.createElement(l):l;g.setAttribs(m,f);if(i){if(i.nodeType){m.appendChild(i)}else{g.setHTML(m,i)}}return !k?n.appendChild(m):m})},create:function(i,f,g){return this.add(this.doc.createElement(i),i,f,g,1)},createHTML:function(m,f,j){var l="",i=this,g;l+="<"+m;for(g in f){if(f.hasOwnProperty(g)){l+=" "+g+'="'+i.encode(f[g])+'"'}}if(c.is(j)){return l+">"+j+"</"+m+">"}return l+" />"},remove:function(h,f){var g=this;return this.run(h,function(m){var l,k,j;l=m.parentNode;if(!l){return null}if(f){for(j=m.childNodes.length-1;j>=0;j--){g.insertAfter(m.childNodes[j],m)}}if(g.fixPsuedoLeaks){l=m.cloneNode(true);f="IELeakGarbageBin";k=g.get(f)||g.add(g.doc.body,"div",{id:f,style:"display:none"});k.appendChild(m);k.innerHTML="";return l}return l.removeChild(m)})},setStyle:function(i,f,g){var h=this;return h.run(i,function(l){var k,j;k=l.style;f=f.replace(/-(\D)/g,function(n,m){return m.toUpperCase()});if(h.pixelStyles.test(f)&&(c.is(g,"number")||/^[\-0-9\.]+$/.test(g))){g+="px"}switch(f){case"opacity":if(a){k.filter=g===""?"":"alpha(opacity="+(g*100)+")";if(!i.currentStyle||!i.currentStyle.hasLayout){k.display="inline-block"}}k[f]=k["-moz-opacity"]=k["-khtml-opacity"]=g||"";break;case"float":a?k.styleFloat=g:k.cssFloat=g;break;default:k[f]=g||""}if(h.settings.update_styles){h.setAttrib(l,"mce_style")}})},getStyle:function(i,f,h){i=this.get(i);if(!i){return false}if(this.doc.defaultView&&h){f=f.replace(/[A-Z]/g,function(j){return"-"+j});try{return this.doc.defaultView.getComputedStyle(i,null).getPropertyValue(f)}catch(g){return null}}f=f.replace(/-(\D)/g,function(k,j){return j.toUpperCase()});if(f=="float"){f=a?"styleFloat":"cssFloat"}if(i.currentStyle&&h){return i.currentStyle[f]}return i.style[f]},setStyles:function(i,j){var g=this,h=g.settings,f;f=h.update_styles;h.update_styles=0;e(j,function(k,l){g.setStyle(i,l,k)});h.update_styles=f;if(h.update_styles){g.setAttrib(i,h.cssText)}},setAttrib:function(h,i,f){var g=this;if(!h||!i){return}if(g.settings.strict){i=i.toLowerCase()}return this.run(h,function(k){var j=g.settings;switch(i){case"style":if(!b(f,"string")){e(f,function(l,m){g.setStyle(k,m,l)});return}if(j.keep_values){if(f&&!g._isRes(f)){k.setAttribute("mce_style",f,2)}else{k.removeAttribute("mce_style",2)}}k.style.cssText=f;break;case"class":k.className=f||"";break;case"src":case"href":if(j.keep_values){if(j.url_converter){f=j.url_converter.call(j.url_converter_scope||g,f,i,k)}g.setAttrib(k,"mce_"+i,f,2)}break;case"shape":k.setAttribute("mce_style",f);break}if(b(f)&&f!==null&&f.length!==0){k.setAttribute(i,""+f,2)}else{k.removeAttribute(i,2)}})},setAttribs:function(g,h){var f=this;return this.run(g,function(i){e(h,function(j,k){f.setAttrib(i,k,j)})})},getAttrib:function(i,j,h){var f,g=this;i=g.get(i);if(!i||i.nodeType!==1){return false}if(!b(h)){h=""}if(/^(src|href|style|coords|shape)$/.test(j)){f=i.getAttribute("mce_"+j);if(f){return f}}if(a&&g.props[j]){f=i[g.props[j]];f=f&&f.nodeValue?f.nodeValue:f}if(!f){f=i.getAttribute(j,2)}if(j==="style"){f=f||i.style.cssText;if(f){f=g.serializeStyle(g.parseStyle(f));if(g.settings.keep_values&&!g._isRes(f)){i.setAttribute("mce_style",f)}}}if(d&&j==="class"&&f){f=f.replace(/(apple|webkit)\-[a-z\-]+/gi,"")}if(a){switch(j){case"rowspan":case"colspan":if(f===1){f=""}break;case"size":if(f==="+0"||f===20||f===0){f=""}break;case"width":case"height":case"vspace":case"checked":case"disabled":case"readonly":if(f===0){f=""}break;case"hspace":if(f===-1){f=""}break;case"maxlength":case"tabindex":if(f===32768||f===2147483647||f==="32768"){f=""}break;case"multiple":case"compact":case"noshade":case"nowrap":if(f===65535){return j}return h;case"shape":f=f.toLowerCase();break;default:if(j.indexOf("on")===0&&f){f=(""+f).replace(/^function\s+\w+\(\)\s+\{\s+(.*)\s+\}$/,"$1")}}}return(f!==undefined&&f!==null&&f!=="")?""+f:h},getPos:function(m,i){var g=this,f=0,l=0,j,k=g.doc,h;m=g.get(m);i=i||k.body;if(m){if(a&&!g.stdMode){m=m.getBoundingClientRect();j=g.boxModel?k.documentElement:k.body;f=g.getStyle(g.select("html")[0],"borderWidth");f=(f=="medium"||g.boxModel&&!g.isIE6)&&2||f;m.top+=g.win.self!=g.win.top?2:0;return{x:m.left+j.scrollLeft-f,y:m.top+j.scrollTop-f}}h=m;while(h&&h!=i&&h.nodeType){f+=h.offsetLeft||0;l+=h.offsetTop||0;h=h.offsetParent}h=m.parentNode;while(h&&h!=i&&h.nodeType){f-=h.scrollLeft||0;l-=h.scrollTop||0;h=h.parentNode}}return{x:f,y:l}},parseStyle:function(h){var i=this,j=i.settings,k={};if(!h){return k}function f(w,q,v){var o,u,m,n;o=k[w+"-top"+q];if(!o){return}u=k[w+"-right"+q];if(o!=u){return}m=k[w+"-bottom"+q];if(u!=m){return}n=k[w+"-left"+q];if(m!=n){return}k[v]=n;delete k[w+"-top"+q];delete k[w+"-right"+q];delete k[w+"-bottom"+q];delete k[w+"-left"+q]}function g(n,m,l,p){var o;o=k[m];if(!o){return}o=k[l];if(!o){return}o=k[p];if(!o){return}k[n]=k[m]+" "+k[l]+" "+k[p];delete k[m];delete k[l];delete k[p]}h=h.replace(/&(#?[a-z0-9]+);/g,"&$1_MCE_SEMI_");e(h.split(";"),function(m){var l,n=[];if(m){m=m.replace(/_MCE_SEMI_/g,";");m=m.replace(/url\([^\)]+\)/g,function(o){n.push(o);return"url("+n.length+")"});m=m.split(":");l=c.trim(m[1]);l=l.replace(/url\(([^\)]+)\)/g,function(p,o){return n[parseInt(o)-1]});l=l.replace(/rgb\([^\)]+\)/g,function(o){return i.toHex(o)});if(j.url_converter){l=l.replace(/url\([\'\"]?([^\)\'\"]+)[\'\"]?\)/g,function(o,p){return"url("+j.url_converter.call(j.url_converter_scope||i,i.decode(p),"style",null)+")"})}k[c.trim(m[0]).toLowerCase()]=l}});f("border","","border");f("border","-width","border-width");f("border","-color","border-color");f("border","-style","border-style");f("padding","","padding");f("margin","","margin");g("border","border-width","border-style","border-color");if(a){if(k.border=="medium none"){k.border=""}}return k},serializeStyle:function(g){var f="";e(g,function(i,h){if(h&&i){if(c.isGecko&&h.indexOf("-moz-")===0){return}switch(h){case"color":case"background-color":i=i.toLowerCase();break}f+=(f?" ":"")+h+": "+i+";"}});return f},loadCSS:function(f){var h=this,i=h.doc,g;if(!f){f=""}g=h.select("head")[0];e(f.split(","),function(j){var k;if(h.files[j]){return}h.files[j]=true;k=h.create("link",{rel:"stylesheet",href:c._addVer(j)});if(a&&i.documentMode){k.onload=function(){i.recalc();k.onload=null}}g.appendChild(k)})},addClass:function(f,g){return this.run(f,function(h){var i;if(!g){return 0}if(this.hasClass(h,g)){return h.className}i=this.removeClass(h,g);return h.className=(i!=""?(i+" "):"")+g})},removeClass:function(h,i){var f=this,g;return f.run(h,function(k){var j;if(f.hasClass(k,i)){if(!g){g=new RegExp("(^|\\s+)"+i+"(\\s+|$)","g")}j=k.className.replace(g," ");return k.className=c.trim(j!=" "?j:"")}return k.className})},hasClass:function(g,f){g=this.get(g);if(!g||!f){return false}return(" "+g.className+" ").indexOf(" "+f+" ")!==-1},show:function(f){return this.setStyle(f,"display","block")},hide:function(f){return this.setStyle(f,"display","none")},isHidden:function(f){f=this.get(f);return !f||f.style.display=="none"||this.getStyle(f,"display")=="none"},uniqueId:function(f){return(!f?"mce_":f)+(this.counter++)},setHTML:function(i,g){var f=this;return this.run(i,function(m){var h,k,j,q,l,h;g=f.processHTML(g);if(a){function o(){try{m.innerHTML="<br />"+g;m.removeChild(m.firstChild)}catch(n){while(m.firstChild){m.firstChild.removeNode()}h=f.create("div");h.innerHTML="<br />"+g;e(h.childNodes,function(r,p){if(p){m.appendChild(r)}})}}if(f.settings.fix_ie_paragraphs){g=g.replace(/<p><\/p>|<p([^>]+)><\/p>|<p[^\/+]\/>/gi,'<p$1 mce_keep="true">&nbsp;</p>')}o();if(f.settings.fix_ie_paragraphs){j=m.getElementsByTagName("p");for(k=j.length-1,h=0;k>=0;k--){q=j[k];if(!q.hasChildNodes()){if(!q.mce_keep){h=1;break}q.removeAttribute("mce_keep")}}}if(h){g=g.replace(/<p ([^>]+)>|<p>/g,'<div $1 mce_tmp="1">');g=g.replace(/<\/p>/g,"</div>");o();if(f.settings.fix_ie_paragraphs){j=m.getElementsByTagName("DIV");for(k=j.length-1;k>=0;k--){q=j[k];if(q.mce_tmp){l=f.doc.createElement("p");q.cloneNode(false).outerHTML.replace(/([a-z0-9\-_]+)=/gi,function(p,n){var r;if(n!=="mce_tmp"){r=q.getAttribute(n);if(!r&&n==="class"){r=q.className}l.setAttribute(n,r)}});for(h=0;h<q.childNodes.length;h++){l.appendChild(q.childNodes[h].cloneNode(true))}q.swapNode(l)}}}}}else{m.innerHTML=g}return g})},processHTML:function(j){var g=this,i=g.settings;if(!i.process_html){return j}if(c.isGecko){j=j.replace(/<(\/?)strong>|<strong( [^>]+)>/gi,"<$1b$2>");j=j.replace(/<(\/?)em>|<em( [^>]+)>/gi,"<$1i$2>")}else{if(a){j=j.replace(/&apos;/g,"&#39;");j=j.replace(/\s+(disabled|checked|readonly|selected)\s*=\s*[\"\']?(false|0)[\"\']?/gi,"")}}j=j.replace(/<a( )([^>]+)\/>|<a\/>/gi,"<a$1$2></a>");if(i.keep_values){if(/<script|noscript|style/i.test(j)){function f(h){h=h.replace(/(<!--\[CDATA\[|\]\]-->)/g,"\n");h=h.replace(/^[\r\n]*|[\r\n]*$/g,"");h=h.replace(/^\s*(\/\/\s*<!--|\/\/\s*<!\[CDATA\[|<!--|<!\[CDATA\[)[\r\n]*/g,"");h=h.replace(/\s*(\/\/\s*\]\]>|\/\/\s*-->|\]\]>|-->|\]\]-->)\s*$/g,"");return h}j=j.replace(/<script([^>]+|)>([\s\S]*?)<\/script>/gi,function(h,l,k){if(!l){l=' type="text/javascript"'}l=l.replace(/src=\"([^\"]+)\"?/i,function(m,n){if(i.url_converter){n=g.encode(i.url_converter.call(i.url_converter_scope||g,g.decode(n),"src","script"))}return'mce_src="'+n+'"'});if(c.trim(k)){k="<!--\n"+f(k)+"\n// -->"}return"<mce:script"+l+">"+k+"</mce:script>"});j=j.replace(/<style([^>]+|)>([\s\S]*?)<\/style>/gi,function(h,l,k){if(k){k="<!--\n"+f(k)+"\n-->"}return"<mce:style"+l+">"+k+"</mce:style><style "+l+' mce_bogus="1">'+k+"</style>"});j=j.replace(/<noscript([^>]+|)>([\s\S]*?)<\/noscript>/g,function(h,l,k){return"<mce:noscript"+l+"><!--"+g.encode(k).replace(/--/g,"&#45;&#45;")+"--></mce:noscript>"})}j=j.replace(/<!\[CDATA\[([\s\S]+)\]\]>/g,"<!--[CDATA[$1]]-->");j=j.replace(/<([\w:]+) [^>]*(src|href|style|shape|coords)[^>]*>/gi,function(h,l){function k(o,n,q){var p=q;if(h.indexOf("mce_"+n)!=-1){return o}if(n=="style"){if(g._isRes(q)){return o}if(i.hex_colors){p=p.replace(/rgb\([^\)]+\)/g,function(m){return g.toHex(m)})}if(i.url_converter){p=p.replace(/url\([\'\"]?([^\)\'\"]+)\)/g,function(m,r){return"url("+g.encode(i.url_converter.call(i.url_converter_scope||g,g.decode(r),n,l))+")"})}}else{if(n!="coords"&&n!="shape"){if(i.url_converter){p=g.encode(i.url_converter.call(i.url_converter_scope||g,g.decode(q),n,l))}}}return" "+n+'="'+q+'" mce_'+n+'="'+p+'"'}h=h.replace(/ (src|href|style|coords|shape)=[\"]([^\"]+)[\"]/gi,k);h=h.replace(/ (src|href|style|coords|shape)=[\']([^\']+)[\']/gi,k);return h.replace(/ (src|href|style|coords|shape)=([^\s\"\'>]+)/gi,k)})}return j},getOuterHTML:function(f){var g;f=this.get(f);if(!f){return null}if(f.outerHTML!==undefined){return f.outerHTML}g=(f.ownerDocument||this.doc).createElement("body");g.appendChild(f.cloneNode(true));return g.innerHTML},setOuterHTML:function(j,g,k){var f=this;function i(m,l,p){var q,o;o=p.createElement("body");o.innerHTML=l;q=o.lastChild;while(q){f.insertAfter(q.cloneNode(true),m);q=q.previousSibling}f.remove(m)}return this.run(j,function(l){l=f.get(l);if(l.nodeType==1){k=k||l.ownerDocument||f.doc;if(a){try{if(a&&l.nodeType==1){l.outerHTML=g}else{i(l,g,k)}}catch(h){i(l,g,k)}}else{i(l,g,k)}}})},decode:function(g){var h,i,f;if(/&[^;]+;/.test(g)){h=this.doc.createElement("div");h.innerHTML=g;i=h.firstChild;f="";if(i){do{f+=i.nodeValue}while(i.nextSibling)}return f||g}return g},encode:function(f){return f?(""+f).replace(/[<>&\"]/g,function(h,g){switch(h){case"&":return"&amp;";case'"':return"&quot;";case"<":return"&lt;";case">":return"&gt;"}return h}):f},insertAfter:function(h,g){var f=this;g=f.get(g);return this.run(h,function(k){var j,i;j=g.parentNode;i=g.nextSibling;if(i){j.insertBefore(k,i)}else{j.appendChild(k)}return k})},isBlock:function(f){if(f.nodeType&&f.nodeType!==1){return false}f=f.nodeName||f;return/^(H[1-6]|HR|P|DIV|ADDRESS|PRE|FORM|TABLE|LI|OL|UL|TR|TD|CAPTION|BLOCKQUOTE|CENTER|DL|DT|DD|DIR|FIELDSET|NOSCRIPT|NOFRAMES|MENU|ISINDEX|SAMP)$/.test(f)},replace:function(i,h,f){var g=this;if(b(h,"array")){i=i.cloneNode(true)}return g.run(h,function(j){if(f){e(j.childNodes,function(k){i.appendChild(k.cloneNode(true))})}if(g.fixPsuedoLeaks&&j.nodeType===1){j.parentNode.insertBefore(i,j);g.remove(j);return i}return j.parentNode.replaceChild(i,j)})},findCommonAncestor:function(h,f){var i=h,g;while(i){g=f;while(g&&i!=g){g=g.parentNode}if(i==g){break}i=i.parentNode}if(!i&&h.ownerDocument){return h.ownerDocument.documentElement}return i},toHex:function(f){var h=/^\s*rgb\s*?\(\s*?([0-9]+)\s*?,\s*?([0-9]+)\s*?,\s*?([0-9]+)\s*?\)\s*$/i.exec(f);function g(i){i=parseInt(i).toString(16);return i.length>1?i:"0"+i}if(h){f="#"+g(h[1])+g(h[2])+g(h[3]);return f}return f},getClasses:function(){var l=this,g=[],k,m={},n=l.settings.class_filter,j;if(l.classes){return l.classes}function o(f){e(f.imports,function(i){o(i)});e(f.cssRules||f.rules,function(i){switch(i.type||1){case 1:if(i.selectorText){e(i.selectorText.split(","),function(p){p=p.replace(/^\s*|\s*$|^\s\./g,"");if(/\.mce/.test(p)||!/\.[\w\-]+$/.test(p)){return}j=p;p=p.replace(/.*\.([a-z0-9_\-]+).*/i,"$1");if(n&&!(p=n(p,j))){return}if(!m[p]){g.push({"class":p});m[p]=1}})}break;case 3:o(i.styleSheet);break}})}try{e(l.doc.styleSheets,o)}catch(h){}if(g.length>0){l.classes=g}return g},run:function(j,i,h){var g=this,k;if(g.doc&&typeof(j)==="string"){j=g.get(j)}if(!j){return false}h=h||this;if(!j.nodeType&&(j.length||j.length===0)){k=[];e(j,function(l,f){if(l){if(typeof(l)=="string"){l=g.doc.getElementById(l)}k.push(i.call(h,l,f))}});return k}return i.call(h,j)},getAttribs:function(g){var f;g=this.get(g);if(!g){return[]}if(a){f=[];if(g.nodeName=="OBJECT"){return g.attributes}g.cloneNode(false).outerHTML.replace(/([a-z0-9\:\-_]+)=/gi,function(i,h){f.push({specified:1,nodeName:h})});return f}return g.attributes},destroy:function(g){var f=this;if(f.events){f.events.destroy()}f.win=f.doc=f.root=f.events=null;if(!g){c.removeUnload(f.destroy)}},createRng:function(){var f=this.doc;return f.createRange?f.createRange():new c.dom.Range(this)},split:function(k,j,n){var o=this,f=o.createRng(),l,i,m;function g(q,p){q=q[p];if(q&&q[p]&&q[p].nodeType==1&&h(q[p])){o.remove(q[p])}}function h(p){p=o.getOuterHTML(p);p=p.replace(/<(img|hr|table)/gi,"-");p=p.replace(/<[^>]+>/g,"");return p.replace(/[ \t\r\n]+|&nbsp;|&#160;/g,"")==""}if(k&&j){f.setStartBefore(k);f.setEndBefore(j);l=f.extractContents();f=o.createRng();f.setStartAfter(j);f.setEndAfter(k);i=f.extractContents();m=k.parentNode;g(l,"lastChild");if(!h(l)){m.insertBefore(l,k)}if(n){m.replaceChild(n,j)}else{m.insertBefore(j,k)}g(i,"firstChild");if(!h(i)){m.insertBefore(i,k)}o.remove(k);return n||j}},bind:function(j,f,i,h){var g=this;if(!g.events){g.events=new c.dom.EventUtils()}return g.events.add(j,f,i,h||this)},unbind:function(i,f,h){var g=this;if(!g.events){g.events=new c.dom.EventUtils()}return g.events.remove(i,f,h)},_findSib:function(j,g,h){var i=this,k=g;if(j){if(b(k,"string")){k=function(f){return i.is(f,g)}}for(j=j[h];j;j=j[h]){if(k(j)){return j}}}return null},_isRes:function(f){return/^(top|left|bottom|right|width|height)/i.test(f)||/;\s*(top|left|bottom|right|width|height)/i.test(f)}});c.DOM=new c.dom.DOMUtils(document,{process_html:0})})(tinymce);(function(f){var h=0,c=1,e=2,d=tinymce.extend;function g(m,k){var j,l;if(m.parentNode!=k){return -1}for(l=k.firstChild,j=0;l!=m;l=l.nextSibling){j++}return j}function b(k){var j=0;while(k.previousSibling){j++;k=k.previousSibling}return j}function i(j,k){var l;if(j.nodeType==3){return j}if(k<0){return j}l=j.firstChild;while(l!=null&&k>0){--k;l=l.nextSibling}if(l!=null){return l}return j}function a(k){var j=k.doc;d(this,{dom:k,startContainer:j,startOffset:0,endContainer:j,endOffset:0,collapsed:true,commonAncestorContainer:j,START_TO_START:0,START_TO_END:1,END_TO_END:2,END_TO_START:3})}d(a.prototype,{setStart:function(k,j){this._setEndPoint(true,k,j)},setEnd:function(k,j){this._setEndPoint(false,k,j)},setStartBefore:function(j){this.setStart(j.parentNode,b(j))},setStartAfter:function(j){this.setStart(j.parentNode,b(j)+1)},setEndBefore:function(j){this.setEnd(j.parentNode,b(j))},setEndAfter:function(j){this.setEnd(j.parentNode,b(j)+1)},collapse:function(k){var j=this;if(k){j.endContainer=j.startContainer;j.endOffset=j.startOffset}else{j.startContainer=j.endContainer;j.startOffset=j.endOffset}j.collapsed=true},selectNode:function(j){this.setStartBefore(j);this.setEndAfter(j)},selectNodeContents:function(j){this.setStart(j,0);this.setEnd(j,j.nodeType===1?j.childNodes.length:j.nodeValue.length)},compareBoundaryPoints:function(m,n){
5 Boudybuilder
23.07.14
19:13
что то получается.
вставил содержимое <script type="text/javascript"> сюда </script>
6 Boudybuilder
23.07.14
19:13
тоесть что то не получается... запарился я уже
7 Asmody
23.07.14
19:46
(4) еще раз такую простыню запостишь, введу платный доступ для Украины
8 Asmody
23.07.14
В поле HTML выведи <iframe src="тут имя временного файла с исходным html-кодом" width="100%" style="border:0;"></iframe>
9 Boudybuilder
23.07.14
(8) Спасибо , но не помогло. Bing открывается
10 Boudybuilder
23.07.14
ВремФайл = ЭтаФорма.КаталогДанных + "temp.html";
    Эксплорер =  ВремФайл;
Вот так заработало в тонком клиенте , что уже радует. Но в веб - не работает :(
11 kokamoonga
23.07.14
(0) с TinyMCE бывает проблема из-за размера. На сайтах, в качестве костыля, можно ставить отсрочку инициализации.
То есть
  tinyMCE.init({ ... });
</script>
Лучше поместить не в <head>, а в конце <body>, и установить ему через setTimeout например 200-300 mc задержки.
Сработает ли с 1С не в курсе.
12 Boudybuilder
24.07.14
00:50
(11) можете код написать для вставки?
13 Boudybuilder
24.07.14
00:51
Оно у меня по сети на другом компе и через тонкий тоже не отображается. А на локальном всьо ок. Кроме веб  ,конечно.
14 Boudybuilder
24.07.14
Ребята, кто поможет?
15 kokamoonga
24.07.14
(13) Каша какая-то тут.
Скрипт подгружается на удаленных машинах? В Google Chrome F12, вкладка Sources.
Хотя ответ довольно предсказуем. Пути-то для скриптов указываются относительные. А tiny_mce.js это только ядро, он еще кучу всего подтаскивает в процессе работы.
Скрипты должен отдавать web-сервер. Ересь с прописыванием локальных путей как в (2) годится только для тестирования и то не всегда.
