Админ
Не найдена процедура SP_DBOPTION ☑
0 BUBU
02.09.15
SQL 2012 + 1c
Выдает ошибку
Может кто знает где ее взять ?
1 ДенисЧ
02.09.15
Её там больше нет
2 Ненавижу 1С
3 Rlogin
02.09.15
USE [master]
GO
/****** Object: StoredProcedure [dbo].[sp_dboption] Script Date: 21.03.2012 7:33:37 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE procedure [dbo].[sp_dboption] -- 1999/08/09 18:25
@dbname sysname = NULL, -- database name to change
@optname varchar(35) = NULL, -- option name to turn on/off
@optvalue varchar(10) = NULL -- true or false
as
set nocount on
declare @dbid int -- dbid of the database
declare @catvalue int -- number of category option
declare @optcount int -- number of options like @optname
declare @allstatopts int -- bit map off all options stored in sysdatqabases.status
-- that can be set by sp_dboption.
declare @alloptopts int -- bit map off all options stored in sysdatqabases.status
declare @allcatopts int -- bit map off all options stored in sysdatqabases.category
declare @exec_stmt nvarchar(max)
declare @fulloptname varchar(35)
declare @alt_optname varchar(50)
declare @alt_optvalue varchar(30)
declare @optnameIn varchar(35)
select @optnameIn = @optname
,@optname = LOWER (@optname collate Latin1_General_CI_AS)
-- If no @dbname given, just list the possible dboptions.
-- Only certain status bits may be set or cleared by sp_dboption.
-- Get bitmap of all options that can be set by sp_dboption.
select @allstatopts=number from master.dbo.spt_values where type = 'D'
and name = 'ALL SETTABLE OPTIONS'
select @allcatopts=number from master.dbo.spt_values where type = 'DC'
select @alloptopts=number from master.dbo.spt_values where type = 'D2'
if @dbname is null
begin
select 'Settable database options:' = name
where (type = 'D'
and number & @allstatopts <> 0
and number not in (0,@allstatopts)) -- Eliminate non-option entries
or (type = 'DC'
and number & @allcatopts <> 0
and number not in (0,@allcatopts))
or (type = 'D2'
and number & @alloptopts <> 0
and number not in (0,@alloptopts))
order by name
return (0)
end
-- Verify the database name and get info
select @dbid = dbid
from master.dbo.sysdatabases
where name = @dbname
-- If @dbname not found, say so and list the databases.
if @dbid is null
begin
raiserror(15010,-1,-1,@dbname)
print ' '
select 'Available databases:' = name
return (1)
end
-- If no option was supplied, display current settings.
if @optname is null
begin
select 'The following options are set:' = v.name
from master.dbo.spt_values v, master.dbo.sysdatabases d
where d.name=@dbname
and ((number & @allstatopts <> 0
and number not in (-1,@allstatopts)
and v.type = 'D'
and (v.number & d.status)=v.number)
or (number & @allcatopts <> 0
and number not in (-1,@allcatopts)
and v.type = 'DC'
and d.category & v.number <> 0)
or (number & @alloptopts <> 0
and number not in (-1,@alloptopts)
and v.type = 'D2'
and d.status2 & v.number <> 0))
return(0)
end
if @optvalue is not null and lower(@optvalue) not in ('true', 'false', 'on', 'off')
begin
raiserror(15241,-1,-1)
return (1)
end
-- Use @optname and try to find the right option.
-- If there isn't just one, print appropriate diagnostics and return.
select @optcount = count(*) ,@fulloptname = min(name)
where lower(name collate Latin1_General_CI_AS) like '%' + @optname + '%'
and ((type = 'D'
and number not in (-1,@allstatopts))
or (type = 'DC'
and number not in (-1,@allcatopts))
or (type = 'D2'
and number not in (-1,@alloptopts)))
-- If no option, show the user what the options are.
if @optcount = 0
begin
raiserror(15011,-1,-1,@optnameIn)
print ' '
where (type = 'D'
and number not in (-1,@allstatopts)) -- Eliminate non-option entries
or (type = 'DC'
or (type = 'D2'
order by name
return (1)
end
-- If more than one option like @optname, show the duplicates and return.
if @optcount > 1
begin
raiserror(15242,-1,-1,@optnameIn)
print ' '
select duplicate_options = name
and ((type = 'D'
or (type = 'DC'
or (type = 'D2'
return (1)
end
-- Just want to see current setting of specified option.
if @optvalue is null
begin
select OptionName = v.name,
CurrentSetting = (case
when ( ((v.number & d.status) = v.number
and v.type = 'D')
or (d.category & v.number <> 0
and v.type = 'DC')
or (d.status2 & v.number <> 0
and v.type = 'D2')
then 'ON'
when not
and v.type = 'D')
and v.type = 'DC')
and v.type = 'D2')
then 'OFF'
end)
and ((v.number & @allstatopts <> 0
and v.number not in (-1,@allstatopts) -- Eliminate non-option entries
and v.type = 'D')
or (v.number & @allcatopts <> 0
and v.number not in (-1,@allcatopts) -- Eliminate non-option entries
and v.type = 'DC')
or (v.number & @alloptopts <> 0
and v.number not in (-1,@alloptopts) -- Eliminate non-option entries
and v.type = 'D2')
and lower(v.name) = lower(@fulloptname)
return (0)
end
select @catvalue = 0
select @catvalue = number
where lower(name) = lower(@fulloptname)
and type = 'DC'
-- if setting replication option, call sp_replicationdboption directly
if (@catvalue <> 0)
begin
select @alt_optvalue = (case lower(@optvalue)
when 'true' then 'true'
when 'on' then 'true'
else 'false'
end)
select @alt_optname = (case @catvalue
when 1 then 'publish'
when 2 then 'subscribe'
when 4 then 'merge publish'
else quotename(@fulloptname, '''')
end)
select @exec_stmt = quotename(@dbname, '[') + '.dbo.sp_replicationdboption'
EXEC @exec_stmt @dbname, @alt_optname, @alt_optvalue
return (0)
end
-- call Alter Database to set options
-- set option value in alter database
when 'true' then 'ON'
when 'on' then 'ON'
else 'OFF'
end)
-- set option name in alter database
select @fulloptname = lower(@fulloptname)
select @alt_optname = (case @fulloptname
when 'auto create statistics' then 'AUTO_CREATE_STATISTICS'
when 'auto update statistics' then 'AUTO_UPDATE_STATISTICS'
when 'autoclose' then 'AUTO_CLOSE'
when 'autoshrink' then 'AUTO_SHRINK'
when 'ansi padding' then 'ANSI_PADDING'
when 'arithabort' then 'ARITHABORT'
when 'numeric roundabort' then 'NUMERIC_ROUNDABORT'
when 'ansi null default' then 'ANSI_NULL_DEFAULT'
when 'ansi nulls' then 'ANSI_NULLS'
when 'ansi warnings' then 'ANSI_WARNINGS'
when 'concat null yields null' then 'CONCAT_NULL_YIELDS_NULL'
when 'cursor close on commit' then 'CURSOR_CLOSE_ON_COMMIT'
when 'torn page detection' then 'TORN_PAGE_DETECTION'
when 'quoted identifier' then 'QUOTED_IDENTIFIER'
when 'recursive triggers' then 'RECURSIVE_TRIGGERS'
when 'default to local cursor' then 'CURSOR_DEFAULT'
when 'offline' then (case @alt_optvalue when 'ON' then 'OFFLINE' else 'ONLINE' end)
when 'read only' then (case @alt_optvalue when 'ON' then 'READ_ONLY' else 'READ_WRITE' end)
when 'dbo use only' then (case @alt_optvalue when 'ON' then 'RESTRICTED_USER' else 'MULTI_USER' end)
when 'single user' then (case @alt_optvalue when 'ON' then 'SINGLE_USER' else 'MULTI_USER' end)
when 'select into/bulkcopy' then 'RECOVERY'
when 'trunc. log on chkpt.' then 'RECOVERY'
when 'db chaining' then 'DB_CHAINING'
else @alt_optname
end)
if @fulloptname = 'dbo use only'
begin
if @alt_optvalue = 'ON'
begin
if databaseproperty(@dbname, 'IsSingleUser') = 1
begin
raiserror(5066,-1,-1);
return (1)
end
end
else
begin
if databaseproperty(@dbname, 'IsDBOOnly') = 0
return (0)
end
end
if @fulloptname = 'single user'
begin
begin
if databaseproperty(@dbname, 'ISDBOOnly') = 1
begin
return (1)
end
end
else
begin
if databaseproperty(@dbname, 'IsSingleUser') = 0
return (0)
end
end
select @alt_optvalue = (case @fulloptname
when 'default to local cursor' then (case @alt_optvalue when 'ON' then 'LOCAL' else 'GLOBAL' end)
when 'offline' then ''
when 'read only' then ''
when 'dbo use only' then ''
when 'single user' then ''
else @alt_optvalue
end)
if lower(@fulloptname) = 'select into/bulkcopy'
begin
begin
if databaseproperty(@dbname, 'IsTrunclog') = 1
select @alt_optvalue = 'RECMODEL_70BACKCOMP'
else
select @alt_optvalue = 'BULK_LOGGED'
end
else
begin
select @alt_optvalue = 'SIMPLE'
else
select @alt_optvalue = 'FULL'
end
end
if lower(@fulloptname) = 'trunc. log on chkpt.'
begin
begin
if databaseproperty(@dbname, 'IsBulkCopy') = 1
else
end
else
begin
else
end
end
-- construct the ALTER DATABASE command string
select @exec_stmt = 'ALTER DATABASE ' + quotename(@dbname) + ' SET ' + @alt_optname + ' ' + @alt_optvalue + ' WITH NO_WAIT'
EXEC (@exec_stmt)
if @@error <> 0
begin
raiserror(15627,-1,-1)
return (1)
end
return (0) -- sp_dboption
GO
4 BUBU
02.09.15
(3) Спасибо, только после переноса в скуль
ошибки лезут. Не так копирую что-ли ?
5 Sammo
02.09.15
Хм. Ну вообще-то эта проблема должна быть решена, т.е. еще как вариант (помимо создания процедуры руками) перейти на тот релиз 1с, который работает с 2012 скулем.
6 Гёдза
02.09.15
может пора и 1с обновить?
