Ошибка обмена Управление торговли 11.2 с битриксом сайт | ☑ | ||
sitdv
16.03.17
05:24
Фоновый обмен
15.03.2017 1:01:35 Запуск выгрузки товаров 15.03.2017 1:03:20 Выгрузка на сайт завершилась с ошибками. import0_1.xml: Произошла ошибка на стороне сервера. Получен неизвестный статус импорта. Ответ сервера: <br><font color=#ff0000>MySQL Query Error: select ID from b_xml_tree where (PARENT_ID+0 = 0) and (LEFT_MARGIN = 87051) </font>[Table 'bitrix_88.b_xml_tree' doesn't exist]<br><br> <table cellpadding="1" cellspacing="0" width="35%" bgcolor="#9C9A9C"> <tr> <td><table cellpadding="5" cellspacing="0" width="100%"> <tr> <td bgcolor="#FFFFFF" align="center"> <FONT face="Verdana, Arial, Helvetica, sans-serif" size="-1"> <font color="#FF0000"><b>DB query error.</b></font><br> Please try later. </font><br> </form> <form method="post" action="/bitrix/admin/site_checker.php?tabControl_active_tab=edit5#edit5"> <input type="hidden" name="last_error_query" value="File: /home/bitrix/www/bitrix/modules/main/include/dbquery_error.php Query: select ID from b_xml_tree where (PARENT_ID+0 = 0) and (LEFT_MARGIN = 87051) [Table 'bitrix_88.b_xml_tree' doesn't exist] debug_backtrace: Array ( [0] => Array ( [file] => /home/bitrix/www/bitrix/modules/main/classes/mysql/database.php [line] => 229 [class] => [function] => include [args] => ) [1] => Array ( [file] => /home/bitrix/www/bitrix/modules/iblock/classes/mysql/cml2.php [line] => 608 [class] => CDatabase [function] => Query [args] => Array ( [0] => select ID from b_xml_tree where (PARENT_ID+0 = 0) and (LEFT_MARGIN = 87051) ) ) [2] => Array ( [file] => /home/bitrix/www/bitrix/modules/iblock/classes/general/cml2.php [line] => 3147 [class] => CIBlockXMLFile [function] => GetList [args] => Array ( [0] => Array ( ) [1] => Array ( [PARENT_ID+0] => 0 [LEFT_MARGIN] => 87051 ) [2] => Array ( [0] => ID ) ) ) [3] => Array ( [file] => /home/bitrix/www/bitrix/components/bitrix/catalog.import.1c/component.php [line] => 424 [class] => CIBlockCMLImport [function] => DeactivateElement [args] => Array ( [0] => A [1] => 1489503799 [2] => 30 ) ) [4] => Array ( [file] => /home/bitrix/www/bitrix/modules/main/classes/general/component.php [line] => 443 [class] => [function] => include [args] => Array ( [0] => /home/bitrix/www/bitrix/components/bitrix/catalog.import.1c/component.php ) ) [5] => Array ( [file] => /home/bitrix/www/bitrix/modules/main/classes/general/component.php [line] => 482 [class] => CBitrixComponent [function] => __includeComponent [args] => Array ( ) ) [6] => Array ( [file] => /home/bitrix/www/bitrix/modules/main/classes/general/main.php [line] => 1435 [class] => CBitrixComponent [function] => includeComponent [args] => Array ( [0] => [1] => Array ( [IBLOCK_TYPE] => 1c_catalog [SITE_LIST] => Array ( [0] => s1 ) [INTERVAL] => 30 [GROUP_PERMISSIONS] => Array ( [0] => 1 [1] => 5 [2] => 6 ) [GENERATE_PREVIEW] => Y [PREVIEW_WIDTH] => 100 [PREVIEW_HEIGHT] => 100 [DETAIL_RESIZE] => N [DETAIL_WIDTH] => 300 [DETAIL_HEIGHT] => 300 [ELEMENT_ACTION] => A [SECTION_ACTION] => A [FILE_SIZE_LIMIT] => 2097152 [USE_CRC] => Y [USE_ZIP] => Y [USE_OFFERS] => Y [USE_IBLOCK_TYPE_ID] => N [USE_IBLOCK_PICTURE_SETTINGS] => N [TRANSLIT_ON_ADD] => Y [TRANSLIT_ON_UPDATE] => Y [SKIP_ROOT_SECTION] => Y ) [2] => ) ) [7] => Array ( [file] => /home/bitrix/www/bitrix/modules/sale/admin/1c_exchange.php [line] => 66 [class] => CAllMain [function] => IncludeComponent [args] => Array ( [0] => bitrix:catalog.import.1c [1] => [2] => Array ( [IBLOCK_TYPE] => 1c_catalog [SITE_LIST] => Array ( [0] => s1 ) [INTERVAL] => 30 [GROUP_PERMISSIONS] => Array ( [0] => 1 [1] => 5 [2] => 6 ) [GENERATE_PREVIEW] => Y [PREVIEW_WIDTH] => 100 [PREVIEW_HEIGHT] => 100 [DETAIL_RESIZE] => N [DETAIL_WIDTH] => 300 [DETAIL_HEIGHT] => 300 [ELEMENT_ACTION] => A [SECTION_ACTION] => A [FILE_SIZE_LIMIT] => 2097152 [USE_CRC] => Y [USE_ZIP] => Y [USE_OFFERS] => Y [USE_IBLOCK_TYPE_ID] => N [USE_IBLOCK_PICTURE_SETTINGS] => N [TRANSLIT_ON_ADD] => Y [TRANSLIT_ON_UPDATE] => Y [SKIP_ROOT_SECTION] => Y ) ) ) [8] => Array ( [file] => /home/bitrix/www/bitrix/admin/1c_exchange.php [line] => 2 [class] => [function] => require_once [args] => Array ( [0] => /home/bitrix/www/bitrix/modules/sale/admin/1c_exchange.php ) ) ) "> <input type="hidden" name="sessid" id="sessid" value="f93763d3c6b8c9d828de85712bbff253" /> <input type="submit" value="Send error report to support"> </form> </td> </tr> </table></td> </tr> </table> <br><br><br> 15.03.2017 1:03:20 Завершена выгрузка товаров Вопрос Кто нибудь сталкивался с этим? Сам я с битриксом плохо знаком, но почитав эту ошибку я понял что проблема с таблицой MYSql, и он не может записать в нее данные, Может нужно сделать бэкап и регламентные работы с базой MYSQL? |
mexanik_96
16.03.17
05:43
поймал ограничение на хостинге по числу запросов к бд или место на хостинге кончилось.
