1C: SalesForce и 1С интеграция по API / 1С 8 ☑
0 vvf
15.01.18
Есть работающий код, с помощью которого я получаю нужные данные из SalesForce.
HTTPЗапрос = Новый HTTPЗапрос("/services/data/v37.0/query?q=SELECT+Id, IsDeleted, MasterRecordId, Name, Type, ParentId, BillingStreet, BillingCity, BillingState, BillingPostalCode, BillingCountry, BillingLatitude, BillingLongitude, BillingGeocodeAccuracy, BillingAddress, ShippingStreet, ShippingCity, ShippingState, ShippingPostalCode, ShippingCountry, ShippingLatitude, ShippingLongitude, ShippingGeocodeAccuracy, ShippingAddress, Phone, Website, PhotoUrl, Industry, NumberOfEmployees, Description, CurrencyIsoCode, OwnerId, CreatedDate, CreatedById, LastModifiedDate, LastModifiedById, SystemModstamp, LastActivityDate, LastViewedDate, LastReferencedDate, Jigsaw, JigsawCompanyId, AccountSource, SicDesc+from+Account", Соответствие1);
  HTTPОтвет = HTTPСоединение.ВызватьHTTPМетод("get", HTTPЗапрос);
  Token1 = HTTPОтвет.ПолучитьТелоКакСтроку();
  Сообщить(Token1);
А как можно решить обратную задачу, добавлять/менять данные в SalesForce из 1С?
Вот примеры, какие описаны у них в инструкциях
https://developer.salesforce.com/docs/atlas.en-us.api_rest.meta/api_rest/dome_upsert.htm
Upserting New Records
This example uses the PATCH method to insert a new record. It assumes that an external ID field, “customExtIdField__c,” has been added to Account. It also assumes that an Account record with a customExtIdField value of 11999 does not already exist.
Example for upserting a record that does not yet exist
curl https://***yourInstance***.salesforce.com/services/data/v20.0/sobjects/Account/customExtIdField__c/11999 -H "Authorization: Bearer token" -H "Content-Type: application/json" -d @newrecord.json -X PATCH
Example JSON request body newrecord.json file
    "Name" : "California Wheat Corporation",
    "Type" : "New Customer"
Response
Successful response:
    "id" : "00190000001pPvHAAU",
    "errors" : [ ],
    "success" : true
HTTP status code 201 is returned if a new record is created.
Как эту конструкцию преобразовать в код для 1С или есть способ как то отправить данные из моего примера, когда я получаю данные.
1 VS-1976
15.01.18
Использовать метод put
2 VS-1976
15.01.18
HTTPЗапрос
УстановитьТелоИзСтроки( "Сюда Json" );
3 mistеr
15.01.18
(0) SalesForce кушает голый SQL? ни хрена себе "API"!
И DROP TABLE скушает?
4 sitex
Отменно написанное REST API. Все подробно разжевано.
5 mistеr
15.01.18
(4) "q=SELECT..." это ни разу не REST.
Это большая ж.. дырка.
6 sitex
(5) Без авторизации не пройдет.
7 mistеr
15.01.18
(6) ОК, дырка сужается на 1 мм. Теперь она 999 мм.
8 Адинэснег
15.01.18
(6) тут в соседней ветке один уволившийся прог накосячил, так что смотрите, не обидьте торговика какого :-D
9 sitex
(8) ага видел эту ветку.
