Откуда вызывается запрос
0 1nvertex
03.05.18
Сервер периодически начинает тормозить.
Вижу в SQL Profiler странные вызовы вроде того что ниже - количество чтений (Reads) больше миллиона.
Нашел Document404 - это счет на оплату покупателя, но как найти откуда сам вызов запроса?
____________
exec sp_executesql
SELECT TOP 25
T1._IDRRef,
T1._Marked,
T1._Number,
T1._Date_Time,
T1._Posted,
T1._Fld11855RRef,
T1._Fld11858RRef,
T1._Fld11859RRef,
T1._Fld11864,
T1._Fld11865RRef,
T1._Fld11869,
CASE WHEN CASE WHEN T2._Fld22142_TYPE IS NULL THEN 0x08 ELSE T2._Fld22142_TYPE END = 0x08 AND CASE WHEN T2._Fld22142_TYPE IS NULL THEN 0x000002DD ELSE T2._Fld22142_RTRef END = 0x000002DD THEN CASE WHEN T2._Fld22142_TYPE IS NULL THEN P1 ELSE T2._Fld22142_RRRef END END,
CASE WHEN CASE WHEN T2._Fld27894_TYPE IS NULL THEN 0x08 ELSE T2._Fld27894_TYPE END = 0x08 AND CASE WHEN T2._Fld27894_TYPE IS NULL THEN 0x000068D1 ELSE T2._Fld27894_RTRef END = 0x000068D1 THEN CASE WHEN T2._Fld27894_TYPE IS NULL THEN @P2 ELSE T2._Fld27894_RRRef END END
FROM dbo._Document404 T1
LEFT OUTER JOIN dbo._InfoRg22139 T2
ON (((T1._Fld11855RRef = T2._Fld22140RRef) AND (0x08 = T2._Fld22141_TYPE AND 0x00000194 = T2._Fld22141_RTRef AND T1._IDRRef = T2._Fld22141_RRRef))) AND (T2._Fld872 = @P3)
LEFT OUTER JOIN dbo._Reference35 T3
ON (T1._Fld11865RRef = T3._IDRRef) AND (T3._Fld872 = @P4)
LEFT OUTER JOIN dbo._Reference63 T4
ON (T1._Fld11859RRef = T4._IDRRef) AND (T4._Fld872 = @P5)
LEFT OUTER JOIN dbo._Reference90 T5
ON (T1._Fld11858RRef = T5._IDRRef) AND (T5._Fld872 = @P6)
LEFT OUTER JOIN dbo._Reference116 T6
ON (T1._Fld11855RRef = T6._IDRRef) AND (T6._Fld872 = @P7)
WHERE ((T1._Fld872 = @P8)) AND ((((((((((T3._Description LIKE @P9 ESCAPE ''/'') OR (T4._Description LIKE P10 ESCAPE ''/'')) OR (T1._Fld11864 LIKE P11 ESCAPE ''/'')) OR (T5._Description LIKE P12 ESCAPE ''/'')) OR (T1._Number LIKE P13 ESCAPE ''/''))) OR (T6._Description LIKE P14 ESCAPE ''/''))) OR ((T1._Fld11869 >= P15) AND (T1._Fld11869 < P16))))
ORDER BY (T1._Number) DESC, (T1._IDRRef) DESC',N'P1 varbinary(16),@P2 varbinary(16),@P3 numeric(10),@P4 numeric(10),@P5 numeric(10),@P6 numeric(10),@P7 numeric(10),@P8 numeric(10),@P9 nvarchar(4000),P10 nvarchar(4000),P11 nvarchar(4000),P12 nvarchar(4000),P13 nvarchar(4000),P14 nvarchar(4000),P15 numeric(10),P16 numeric(10)',0x9FD5C4D9C70C6C184B8C4C9320CF82A8,0x8CB10ED60875165A4F0A4DB47004F61A,0,0,0,0,0,0,N'%2657%',N'%2657%',N'%2657%',N'%2657%',N'%2657%',N'%2657%',2657,2658    1CV83 Server
____________
Как понять
1 RomanYS
03.05.18
Конфигурация какая, формы УФ?
2 Serg_1960
03.05.18
(имхо) Если "Сервер периодически начинает тормозить" - то это, скорее всего, искать в фоновых заданиях - я бы посмотрел в сторону регламентных заданий.
3 1nvertex
03.05.18
(1)БП3, допиленная
4 1nvertex
03.05.18
(2) Да, первым делом отключил все фоновые, легче не стало
5 lapinio
03.05.18
Настрой журнал регистрации. Вставь кусок запроса. Потом посмотри контекст. И поймешь откуда вызывается запрос.
6 lapinio
03.05.18
DBMSQL like Query etc
7 lapinio
03.05.18
Пример можно найти на итс
8 lapinio
03.05.18
Как настроить журнал регистрации
9 lapinio
03.05.18
А так не поймешь контекст запроса
10 D3O
03.05.18
(4) значит ищи по модулям, по имени документа. еще должны быть в этом же запросе какой-то регистр сведений и 3 справочника
вот как найдешь запрос - поймешь, откуда его дергает )
11 RomanYS
03.05.18
А динамический список не может подобное вызывать?
12 D3O
03.05.18
(11) вот, кстати - да. в глобальный поиск тогда еще включить элементы форм
13 xXeNoNx
03.05.18
(0) вангую.., динамический список
14 lapinio
03.05.18
Технологический журнал. опечатался
15 lapinio
03.05.18
Настрой технологический журнал
16 D3O
03.05.18
(14) не нужен тут журнал. больше гемороя, если не знаешь как настраивать.
просто глобальный поиск
17 xXeNoNx
03.05.18
"SELECT TOP 25" что тут непонятного...?
(16) "Глобальный поиск" - в чем, по какому контексту?
18 Serg_1960
03.05.18
(17) Если автор ничего не напутал, то "Документ.СчетНаОплатуПокупателю КАК Т1"
19 xXeNoNx
03.05.18
(18) И..? что там искать, если нет контекста?
20 D3O
03.05.18
(18) не. не будет в коде такого. это при состряпывании скульного запроса платформа такие штуки сама подпихивает.
21 Serg_1960
03.05.18
(19) Тьфу, глобальный поиск не по технологическому журналу, естественно, а в конфигураторе по конфигурации.
22 xXeNoNx
03.05.18
что бы понять что тормозит систему, настраиваем ТЖ, со свойством dbmssql с параметром Durationus(если 8.3) => 20000000, например, и отслеживаем все события.., если ничего в ТЖ не будет, уменьшаем данный параметр.
23 xXeNoNx
03.05.18
(21) а что конкретно в глобальном поиске искать, например?
24 youalex
03.05.18
escape - это скорее всего, "СПЕЦСИМВОЛ".  Можно по нему попробовать поискать, если запрос не динамически, и если в конфе, а не внешник.
25 Вафель
03.05.18
Это автообновление динамического списка
26 xXeNoNx
03.05.18
+(22) если база конечно ms sql
27 Вафель
03.05.18
осталось только определить пользователя
28 lapinio
03.05.18
<?xml version="1.0" encoding="UTF-8"?>
<config xmlns="http://v8.1c.ru/v8/tech-log">;
<dump create="false"/>
<plansql/>
<log location="C:\v82\log" history="168">
  <event>
   <eq property="name" value="dbmssql"/>
   <like property="plansqltext" value="Select tt"/>
  </event>
  <property name="all"/>
</log>
</config>
29 lapinio
03.05.18
Как пример настройки тж
30 lapinio
03.05.18
Вместо select свой запрос ставь и найдешь контектс
31 lapinio
03.05.18
А так гадать где этот запрос вызывается
32 youalex
03.05.18
вот на это походит, навскидку:
ОбработкаПолученияДанныхВыбора()  в менеджере дока
33 lapinio
03.05.18
<plansql/>
  <event>
   <like property="sql" value="Select top 25"/>
  </event>
</log>
</config>
34 lapinio
03.05.18
Более правильный вариант. Предыдущий вариант. По плану запроса ищет
35 Serg_1960
03.05.18
(23) А я, кстати, не спорю насчёт версии динамического списка. Просто глобальный поиск быстрее, чем ТЖ :) одно из двух: или запрос будет найден, или подтвердится версия генерирования запроса платформой.
36 xXeNoNx
03.05.18
(30) плохая идея привязываться к названию таблиц.., они могут быть разными.
Также плохая идея "Select top 25"
Все (или почти все) динамические списки будут сюда попадать..
37 Вафель
03.05.18
(35) Так дс от настроек пользователя зависит. Ты умеешь поиск по таким настройкам?
38 xXeNoNx
03.05.18
(35) отлично, я немного о другом, по какой подстроке будет что-то найдено?
39 Serg_1960
03.05.18
(38) А что (18) не катит?
40 xXeNoNx
03.05.18
(39) Потому что (20).
Этот запрос из профайлера, запрос сформированный платформой, не 1с-ником
41 Serg_1960
03.05.18
(40)  Ладно, не буду упираться...
:) Но, насчет "не 1С-ника" - это не 100% :)
ВЫБРАТЬ ПЕРВЫЕ 25
Т1.Ссылка,
Т1.ПометкаУдаления,
Т1.Номер,
Т1.Дата,
ИЗ
42 Franchiser
03.05.18
это ДС
43 1nvertex
03.05.18
Поиск по конфигурации "ВЫБРАТЬ ПЕРВЫЕ 25" ничего не дал. Настроил ТЖ по (33) lapinio, пусто. Подумал, может фильтр чувствителен к регистру, поменял на value="SELECT TOP 25". Логи замечательно создаются, но они пустые.
Сделал обработку с запросом "ВЫБРАТЬ ПЕРВЫЕ 25" в ТЖ все равно пусто.
44 D3O
03.05.18
(38) например "ВЫБРАТЬ ПЕРВЫЕ 25"
или "Документ.СчетНаОплатуПокупателю КАК"
или разобраться что там за регистр и какие реквизиты документа и регистра и тогда по условию связи
"СчетНаОплатуПокупателю.<ИмяРеквизита> = <ИмяРегистра>.<ИмяРеквизитаРегистра>"
45 D3O
03.05.18
(43) вот с предыдущим глобальным поиском по модулям и элементам форм
46 Franchiser
03.05.18
Пользователь стрелочками листает динамический список, например, журнал банковских документов
47 D3O
03.05.18
а что за регистр _InfoRg22139 ?
48 Вафель
03.05.18
(47) доп свойства наверняка
49 D3O
03.05.18
возможно в запросе он как СрезПоследних шурует, а ограничений никаких не задается. Вот и тормоза
50 xXeNoNx
03.05.18
(44) "Документ.СчетНаОплатуПокупателю КАК" - а если алиас не задан?
"СчетНаОплатуПокупателю.<ИмяРеквизита> = <ИмяРегистра>.<ИмяРеквизитаРегистра>" из-за алиасов может не совпадать!
"ВЫБРАТЬ ПЕРВЫЕ 25" - много видели отборов "ПЕРВЫЕ 25"? (я только в тестовых запросах использую)
51 Franchiser
03.05.18
(50) в профайлере много видел
52 xXeNoNx
03.05.18
(51) Тут в контексте поиска по конфигурации...
53 xXeNoNx
03.05.18
(51) вопрос в том взяли пост (0) и говорят: а почему бы не поискать по (44) глобальным поиском в конфигурации
54 Franchiser
03.05.18
(47) Ну так посмотри:
select top 100 * from dbo._InfoRg22139
Еще можно соответствие структуры таблиц sql получить из 1с.
55 Cyberhawk
03.05.18
Это не только ДС может быть, но и Выбрать() или Следующий()
56 Cyberhawk
03.05.18
(Я про "SELECT TOP 25")
57 D3O
03.05.18
(54) а, что в какой-то версии ПолучитьСтруктуруХраненияБазыДанных уже не работает? )))
58 Franchiser
03.05.18
"Еще можно соответствие структуры таблиц sql получить из 1с." = ПолучитьСтруктуруХраненияБазыДанных()
Есть возможно (системные) таблицы, который этот метод не показывает
59 D3O
03.05.18
(58) это не тот случай
60 xXeNoNx
03.05.18
(58) они по сути не нужны, но о них нужно помнить
61 Franchiser
03.05.18
Для каждого регистра сведений создается таблица движений (_InfoRg<n>) с полями:
    _Period - момент времени движения. Поле присутствует, если значение свойства "Периодичность" отлично от "Непериодический";
    _Recorder<suff> - ссылка на регистратор. Поле присутствует, если значением свойства "Режим записи" является "Подчинение регистратору";
    _LineNo - номер движения по данному регистратору. Поле присутствует, если значением свойства "Режим записи" является "Подчинение регистратору";
    _Active - движение активно (участвует в вычислении среза последних). Поле присутствует, если значением свойства "Режим записи" является "Подчинение регистратору";
    _Fld<n><suff> - измерение, ресурс или реквизит (для каждого измерения, каждого ресурса и каждого реквизита);
    _Fld<n> - общие реквизиты.
Для каждого периодического регистра сведений, с включенным признаком РазрешитьИтогиСрезПоследних создается таблица срез последних (_InfoRgSL<n>) с полями:
    _Period - момент времени движения;
    _Fld<n><suff> - измерение, ресурс или реквизит (для каждого измерения, каждого ресурса и каждого реквизита).
Для каждого периодического регистра сведений, с включенным признаком РазрешитьИтогиСрезПервых создается таблица срез последних (_InfoRgSF<n>) с полями:
Если регистр сведений участвует хотя бы в одном плане обмена, то создается таблица регистрации изменений (_InfoRgChangeRec<n>). Для регистра, у которого свойство Режим записи имеет значение Независимый таблица регистрации изменений имеет следующие поля:
    _Node<suff> - ссылка на узел плана обмена;
    _MessageNo - номер сообщения обмена данными, в которое было выгружено это изменение или NULL, если оно еще не было выгружено;
    _Period - момент времени движения. Поле присутствует, если значение свойства регистра "Периодичность" отлично от "Непериодический" и установлен флаг "Основной отбор по периоду";
    _Fld<n><suff> - измерение регистра, входящее в основной отбор (для каждого изменения с установленным флагом "Основной отбор");
Если значением свойства Режим записи регистра является Подчинение регистратору, то поля таблицы регистрации изменений такие же, какие у таблицы регистрации изменений последовательности.
62 g00d
03.05.18
а потом глобальные поиск по формам с запросов в этом документа и регламентные задания.
63 1nvertex
03.05.18
"ВЫБРАТЬ ПЕРВЫЕ 25" в тексте конфигурации нет.
_InfoRg22139 это рег.сведений "СтатусыДокументов". Справочники это Валюты, Договора, Контрагенты, Организации.
Нашел всего 43 запроса "Документ.СчетНаОплатуПокупателю КАК", просмотрел все, но подходящего не нашел.
64 Franchiser
03.05.18
(63) если запроса нет то это динамический список с какими то фильтрами. частое упоминание "%2657%" говорит о том что кто-то пытается найти номер 2657.
65 Franchiser
03.05.18
что такое _Fld872 ?
66 Franchiser
03.05.18
Единственное общее поле которое есть во всех тобой указанных справочниках это Организация, кроме спр. Валюты. Но причем тут тогда спр. Валюты?
67 xXeNoNx
03.05.18
(63) а я говорил....
68 Franchiser
03.05.18
P1 0x9FD5C4D9C70C6C184B8C4C9320CF82A8,
P2 0x8CB10ED60875165A4F0A4DB47004F61A,
P3 0,
P4 0,
P5 0,
P6 0,
P7 0,
P8 0,
P9 N'%2657%',
P10 N'%2657%',
P11 N'%2657%',
P12 N'%2657%',
P13 N'%2657%',
P14 N'%2657%',
P15 2657,
P16 2658
69 1nvertex
03.05.18
Fld872 - ОбщийРеквизит.ОбластьДанныхОсновныеДанные
70 Franchiser
03.05.18
Это условие "(T1._Fld11869 >= P15) AND (T1._Fld11869 < P16)" говорит о том что считывается порция данных по 2657
71 1nvertex
03.05.18
(66) Вот здесь
72 1nvertex
03.05.18
<log location="C:\1C\1cv8\logs\LongTop25" history="24">
       <event>
         <like property="sql" value="SELECT TOP 25"/>
       </event>
       <property name="All"/>
   </log>
лог пустой
73 Franchiser
03.05.18
(71) понятно @P4 по @P7 = 0, это видимо что то с разделением данных связанное
74 1nvertex
03.05.18
Еще более странно, что вот этот лог тоже пустой
   <log location="C:\1C\1cv8\logs\Long1" history="24">
       <event>
         <eq property="Name" value=""/>
         <ge property="Duration" value="1000"/>
       </event>
   </log>
75 Franchiser
03.05.18
Нужно создать тестовую базу, настроить на нее профайлер и скроллить в ней журналы по этому документу, пытаться получить такой же запрос. Только что это даст, ну определишь ты что запрос в динамическом списке, что дальше?
76 VS-1976
03.05.18
19:00
Это скорее всего список документов. Смотри соответствие объектов 2с и таблиц базы через обработку
77 vs84
03.05.18
19:17
(0) это динсписок с основной таблицей Документ.СчетНаОплатуПокупателю. может быть без явно написанного текста запроса (скорее всего).
отбор вида
"WHERE ((T1._Fld872 = @P8)) AND ((((((((((T3._Description LIKE @P9 ESCAPE ''/'') OR (T4._Description LIKE P10 ESCAPE ''/'')) OR (T1._Fld11864 LIKE P11 ESCAPE ''/'')) OR (T5._Description LIKE P12 ESCAPE ''/'')) OR (T1._Number LIKE P13 ESCAPE ''/''))) OR (T6._Description LIKE P14 ESCAPE ''/''))) OR ((T1._Fld11869 >= P15) AND (T1._Fld11869 < P16)))) "
генерирует платформа (если не ошибаюсь), когда вводишь строку поиска в поле поиска (по ктрл - Ф) - это поле поиска, которое ищет по всем.
ESCAPE ''/'' - не имеет отношение к конструкции Спецсимвол, это прлатформа сама добавляет.
(70)"Это условие "(T1._Fld11869 >= P15) AND (T1._Fld11869 < P16)" говорит о том что считывается порция данных по 2657"
Нет, это говорит о том, что платформа знает что \то поле числовое и поэтому при вводе в поле поиска 2657 она ищет все, у которых целая часть равна 2657.
78 Мыш
03.05.18
20:26
(77) Скорее всего именно произвольный запрос. Левые соединения и множество выбор_когда намекают.
(0) Открой форму списка документа и посмотри, что у динамического списка в свойствах.
79 systemstopper
03.05.18
А с чего все вдруг решили что сервер начинает тормозить из-за запросов в (0)?
80 Мыш
03.05.18
(79) Опыт. Были прецеденты в моей практике.
81 systemstopper
03.05.18
(80) Настоящие 1с-ники вместо того чтобы заюзать DMV, предпочтут положиться на свой однобокий кривой опыт)
82 Мыш
03.05.18
(80) Настоящие 1С-ники вместо того чтобы первым делом проверить наиболее вероятные причины, предпочтут очередной раз пойти тернистым путем изысканий.
83 Мыш
03.05.18
(82) к (81) )
84 Diman000
03.05.18
Ну если речь именно о том "откуда вызывается запрос", то скорее всего это динсписок, как тут уже сказали.
Но анализ источника тормозов начинается не с профайлера.
В чем проявляются тормоза? У всех все медленно работает?
Или какие-нибудь отчеты, другие отдельные операции или формы?
Что говорит консоль сервера приложений (время вызова текущее), обычно по ней можно понять наиболее грустных пользователей и напрямую выяснить с каким функционалом они работают.
Если СУБД и сервер приложений на разных машинах, то что у них с загрузкой процессора и памяти? Если на одной, то что по у их отдельных процессов.
85 systemstopper
03.05.18
(82) Что тернистого в том чтобы вызвать несколько DMV-шек, найти объекты метаданных, настроить по ним фильтр ТЖ и получить контекст? Вместо этого проще полдня методом тыка искать причину которая может быть вообще в другом месте?
86 Мыш
03.05.18
(85) Полдня на посмотреть один запрос - это сильно )
87 systemstopper
03.05.18
(86) в смысле? я имею в виду что чуваку тут уже под сотню советов (основываясь на своем мега-опыте) накидали как проверить методом тыка а воз и ныне там...
88 systemstopper
03.05.18
Методика здесь
https://its.1c.ru/db/metod8dev#content:5813:hdoc
там про IO но принцип тот же и для CPU
89 Tateossian
03.05.18
SELECT TOP 25 - это скролл по динамическому списку, в форме какой-то.
90 zwei
03.05.18
(89) В котором наложен отбор по наименование ревизита содержит 2657. Впрлне достаточно чтобы уже сообразить.
91 xXeNoNx
04.05.18
00:50
а чем метод (85) отличается от (82), если, например, прогибается винт или сетка, при чем не сиквелом - читаем по губам...
Если приводите свои не "криворукий опыт", то приводите до конца, а то он кажется не менее криворуким. На одних dmv не уедешь далеко
92 cons74
04.05.18
07:01
(74) ничего странного, ты же в
указал "где имя события =""" - т.е. система будет записывать только события с пустым именем. И в отбор  ничего не попадает.
Обычно для запросов пишется примерно так:
<event>
    <eq property="Name" value="SDBL"/>
    <ge property="Duration" value="80000"/>
</event>
<event>
    <eq property="Name" value="DBMSSQL"/>
</event>
Автор, тебе уже сто раз написали: это запрос дин.списка, т.е. когда пользователь глядит список документов, причем пользователь вывел еще кучу полей/настроил отборы дикие.
Т.к. опыта у тебя нет в ТЖ - ставь мониторинг долгих запросов Гилева и не парься. 15 минут твоего времени и через час полная картина -кто когда и как часто вызывал этот запрос.
93 xXeNoNx
04.05.18
07:35
(92) ему наверное уже не надо..., воспользовался "глобальным поиском")
