Описание (на английском языке):
LXP file is a MODO Luxology Asset File. MODO is a 3D modeling, animation and rendering program that runs on Windows, Macintosh and Linux computer systems
или :
LXP file is a LXP Source Code. LXP (or mod_lxp) is an Application Server designed as an Apache Module. LXP is used to broker and dynamically format HTML content through a process called server-side inclusion.
(5) Да помог,причем очень странно,на вид там было как структура xml.Но поменяв расширения на .xml, он не открылся....
