Часто падает Apache | ☑ | ||
Voblhned
07.05.19
Всем привет, почему то на вер сервере часто падает apache, перезапускается и 1С отваливается с ошибкой сеанс удален ...
Я в админстве apach`а вообще с трудом понимаю, может кто подскажет, вот есть error лог. Иногда неделями работает иногда рестартует каждые несколько часов. [Mon May 06 12:17:25.171434 2019] [mpm_winnt:notice] [pid 1212:tid 408] AH00424: Parent: Received restart signal -- Restarting the server. [Mon May 06 12:17:25.233834 2019] [mpm_winnt:notice] [pid 1212:tid 408] AH00455: Apache/2.4.39 (Win64) configured -- resuming normal operations [Mon May 06 12:17:25.233834 2019] [mpm_winnt:notice] [pid 1212:tid 408] AH00456: Apache Lounge VC15 Server built: Mar 28 2019 11:59:33 [Mon May 06 12:17:25.233834 2019] [core:notice] [pid 1212:tid 408] AH00094: Command line: 'C:\\Apache24\\bin\\httpd.exe -d C:/Apache24' [Mon May 06 12:17:25.233834 2019] [mpm_winnt:notice] [pid 1212:tid 408] AH00418: Parent: Created child process 1988 [Mon May 06 12:18:21.502563 2019] [mpm_winnt:notice] [pid 1212:tid 408] AH00422: Parent: Received shutdown signal -- Shutting down the server. [Mon May 06 12:18:51.506856 2019] [mpm_winnt:notice] [pid 1212:tid 408] AH00431: Parent: Forcing termination of child process 1988 [Mon May 06 12:25:34.306159 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00455: Apache/2.4.39 (Win64) configured -- resuming normal operations [Mon May 06 12:25:34.306159 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00456: Apache Lounge VC15 Server built: Mar 28 2019 11:59:33 [Mon May 06 12:25:34.306159 2019] [core:notice] [pid 1676:tid 424] AH00094: Command line: 'C:\\Apache24\\bin\\httpd.exe -d C:/Apache24' [Mon May 06 12:25:34.306159 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00418: Parent: Created child process 3508 [Mon May 06 12:25:34.618162 2019] [mpm_winnt:notice] [pid 3508:tid 292] AH00354: Child: Starting 64 worker threads. [Tue May 07 11:05:21.717196 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00428: Parent: child process 3508 exited with status 1 -- Restarting. [Tue May 07 11:05:21.748395 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00455: Apache/2.4.39 (Win64) configured -- resuming normal operations [Tue May 07 11:05:21.748395 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00456: Apache Lounge VC15 Server built: Mar 28 2019 11:59:33 [Tue May 07 11:05:21.748395 2019] [core:notice] [pid 1676:tid 424] AH00094: Command line: 'C:\\Apache24\\bin\\httpd.exe -d C:/Apache24' [Tue May 07 11:05:21.748395 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00418: Parent: Created child process 1064 [Tue May 07 11:05:22.047991 2019] [mpm_winnt:notice] [pid 1064:tid 240] AH00354: Child: Starting 64 worker threads. [Tue May 07 13:36:38.420999 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00428: Parent: child process 1064 exited with status 1 -- Restarting. [Tue May 07 13:36:38.436597 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00455: Apache/2.4.39 (Win64) configured -- resuming normal operations [Tue May 07 13:36:38.436597 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00456: Apache Lounge VC15 Server built: Mar 28 2019 11:59:33 [Tue May 07 13:36:38.436597 2019] [core:notice] [pid 1676:tid 424] AH00094: Command line: 'C:\\Apache24\\bin\\httpd.exe -d C:/Apache24' [Tue May 07 13:36:38.436597 2019] [mpm_winnt:notice] [pid 1676:tid 424] AH00418: Parent: Created child process 1164 [Tue May 07 13:36:38.670600 2019] [mpm_winnt:notice] [pid 1164:tid 292] AH00354: Child: Starting 64 worker threads. |
Rovan
Лично я после всех танцев с бубном 2 недели назад делал перезапуск службы на сервере 1 раз в сутки в 1:00.
Пока жалоб не было. |
Cyberhawk
07.05.19
Он не падает, это норма. У тебя что-то не так с логикой.
Cyberhawk
07.05.19
Хотя не, если бы норма то код был бы 0.
По памяти возможно падает - поставь сбор счетчика. |
Voblhned
07.05.19
(1) только что ребутнул серв и прошел час и снова перезапуск
(2) в смысле нормально, что он перезапускается самопроизвольно? другой 2.2.4 стоит уже 5й месяц без перезапуска. |
Провинциальный 1сник
07.05.19
(4) Апач сильно староват, вообще-то. Скачай посвежее.
Voblhned
07.05.19
(5) 2.4.39 старый?
Garykom
(0) Апач не как служба установлен?
Лефмихалыч
07.05.19
что в error_log?
Лефмихалыч
07.05.19
127.0.0.1 localhost в hosts есть?
Voblhned
07.05.19
(8) error.log выложил в 1м посте
(7) служба |
Nyoko
07.05.19
сравни логи апача с активностью 1с, ошибками в 1с. Поставь попробуй варик с vc14
Лефмихалыч
07.05.19
виндовый системный лог что говорит в это время?
памяти достаточно? диск живой? |
Voblhned
07.05.19
(12) 3 клиента 1С, памяти 32гб, свободно 25гигов, диск новый.
Лефмихалыч
07.05.19
(13) кроме вот этих строчек в логе, какие еще симптомы?
Voblhned
07.05.19
(14) это полный лог, больше не символа, до этого последняя запись датирована 25.04.2019
Nyoko
07.05.19
https://www.apachehaus.com/cgi-bin/download.plx -vc14 качни, Apache Lounge те еще сборщики
Garykom
(0) Если не секрет апач наружу выставлен или в локалке?
Может кто то ломать пытается вот оно и падает. |
Voblhned
07.05.19
(17) только локалка
Garykom
Тогда меняйте апач, если не поможет то меняйте сервер
Garykom
И лишние модули в апаче отрубите, типа php и прочих.
Файл настроек покажи, может там криво что то |
КнОпка
07.05.19
ОС 32 или 64? apаche 32 или 64?
Voblhned
07.05.19
(21) ОС 64, апач 64, 1с 64
shotsdv2008
08.05.19
Не написал самого главного - какая ОС стоит? Хотя, судя по логам, там винда, а апач, вообще-то, делается для линукса...
palsergeich
08.05.19
(23) нормально апач на винде работает, если не хайлоад.
Средний прод держит |
08.05.19
(6) Я про 2.2.4
pavig
08.05.19
Просто попробуйте ИИС. |
vde69
08.05.19
а зачем тогда вообще он тебе? пусть админы разбираются... а если ты админ - то ставь то, в чем понимаешь |
