ошибка после установки asterisk и freepbx
0 avyub
23.05.19
Установил CentOS7, затем астериск и freepbx
при открытии страницы freepbx (127.0.0.1) выбает сверху ошибку: Cannot Connect To Asterisk
в терминале по команде:
[root@elasterisk ~]# systemctl status asterisk -l
asterisk.service - LSB: Asterisk PBX
   Loaded: loaded (/etc/rc.d/init.d/asterisk; bad; vendor preset: disabled)
   Active: active (running) since Сб 2019-05-18 21:44:34 MSK; 4 days ago
     Docs: man:systemd-sysv-generator(8)
Main PID: 16104 (asterisk)
    Tasks: 72
   CGroup: /system.slice/asterisk.service
           ├─16102 /bin/sh /usr/sbin/safe_asterisk
           └─16104 /usr/sbin/asterisk -f -U asterisk -vvvg -c
май 18 21:44:34 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
май 18 21:44:34 elasterisk systemd[1]: Started LSB: Asterisk PBX.
май 18 21:44:35 elasterisk asterisk[16104]: radcli: rc_read_config: rc_read_config: can't open /etc/radiusclient-ng/radiusclient.conf: No such file or directory
май 18 22:09:27 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
май 18 22:12:25 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
май 18 23:09:15 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
май 18 23:09:36 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
май 21 19:59:57 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
май 21 20:13:22 elasterisk systemd[1]: asterisk.service: Supervising process 16104 which is not our child. We'll most likely not notice when it exits.
Что это значит?
1 shotsdv2008
23.05.19
Я сильно сомневаюсь, что на этом форуме вы получите внятный ответ по астериксу...
2 Garykom
20:40
(0) Для начала у тебя на радиус ругается, проверь его
3 Garykom
(1) В линуксе нет ничего особо сложного, надо иметь базовые знания и уметь читать и искать инфу в инете.
Даже 1Сник может наверно прочить и перевести "can't open /etc/radiusclient-ng/radiusclient.conf: No such file or directory "
4 Fram
25.05.19
20:40
А готовый дистр freepbx чем не устроил?
5 Fram
25.05.19
Никогда freepbx не ставил отдельно, но полагаю он ющает AGI AMI и файловый доступ к conf файлам. Проверяй что все это открыто в конфиге астериска и правильно прописано в конфиге freepbx
