1с multipart form-data ☑
0 SuperMario
08.12.19
Друзья, всем доброго времени суток.
Есть код на C Sharp , который отправляет POST запрос на WEB сервер.
public string ImportWriteoffAct(WAI_WriteOffAct Act)
    string str2;
    string input = "";
    try
        string path = FlagmanHelper.AddFinalBackSlash(Application.StartupPath) + @"data\import\";
        if (!Directory.Exists(path))
            Directory.CreateDirectory(path);
        str2 = Path.Combine(path, "Act" + Act.Number.ToString() + ".txt");
        StreamWriter writer = new StreamWriter(str2, false, Encoding.Default);
        writer.WriteLine("Article;Name;Units;Amount;");
        int num = 0;
        while (true)
            if (num >= Act.Products.Count)
                writer.Close();
                break;
            writer.WriteLine(Act.Products[num].ToCsvLine());
            num++;
    catch (Exception exception)
        this.LogManager.AddToErrorLog("Ошибка импорта акта списания " + Act.Number.ToString() + ": " + exception.Message);
        return null;
    FileStream stream = new FileStream(str2, FileMode.Open, FileAccess.Read);
    byte[] buffer = new byte[stream.Length];
    stream.Read(buffer, 0, buffer.Length);
    stream.Close();
    Dictionary<string, object> postParameters = new Dictionary<string, object> {
            "documentType",
            "WriteOffDocument"
            "fileName",
            new WAI_FileParameter(buffer, Path.GetFileName(str2), "application/vnd.ms-excel")
            "dateIncoming",
            Act.Date.ToShortDateString()
            "documentNumber",
            "store",
            Act.StoreId
            "toAccount",
            Act.AccountId
            "action",
            "Import"
    HttpWebResponse response = MultipartFormDataPost("http://"; + this.Host + ":" + this.Port + "/" + this.Server + "/service/import/importDocuments.jsp", "Ghost", postParameters, this.Login, this.Password);
    string str6 = new StreamReader(response.GetResponseStream()).ReadToEnd();
    response.Close();
    input = str6.Replace("\n", "");
    if (input != "")
        if (input.IndexOf("<span") >= 0)
            input = input.Substring(input.IndexOf("<span"));
        else if (input.IndexOf("<pre") >= 0)
            input = input.Substring(input.IndexOf("<pre"));
        input = Regex.Replace(input, "<.*?>", " ");
    return input;
Пытаюсь этот код реализовать на 1С.
Собрал текст в формате multipart form-data
В заголовок добавляю
    Заголовки= Новый Соответствие();
    boundary = СтрЗаменить(Строка(Новый УникальныйИдентификатор()), "-", "");
    Заголовки.Вставить("Content-Type", "multipart/form-data; boundary=" + boundary);
Не пойму, как  передать тело запроса.
В заголовках?
1 Cthulhu
08.12.19
УстановитьТелоИзСтроки
2 Cthulhu
08.12.19
HTTPЗапрос = Новый HTTPЗапрос( <path> , Заголовки );
HTTPЗапрос.УстановитьТелоИзСтроки( СтрJSON , КодировкаТекста.UTF8 );
// ну. например ))
3 SuperMario
08.12.19
(1)Делал.
file is not specified
Я поэтому и выложил код на C Charp
4 Cthulhu
08.12.19
(3): нунэнаюу.. у менф жсон нормально укладывается и работает.
5 Юрий Лазаренко
08.12.19
6 SuperMario
08.12.19
(5) читал.
Там только описания создания составного (multipart) HTTP-сообщения
Вопрос , как передать это все чудо?
7 SuperMario
08.12.19
Поставил Fiddler WEB Debugger  и посмотрел тело запроса.
Оно отличается от того, что шлет C Charp.
Завтра сравню и попробую подстроиться.
8 SuperMario
09.12.19
Нашел ошибку в коде.
Все банально- не так кодировка текста.
Я использовал UTF-8, а методом научного тыка оказалась ANSI
тема закрыта)
