УТ 10.3 при печати из реализации ошибка 133 ☑
0 Uragan_a
16.03.20
02:28
2020.03.16 09:53:18.343 T:000011CC ERROR [FiscalPrinter] Код ошибки ККТ - 00E7h
2020.03.16 09:53:18.343 T:000011CC ERROR [FiscalPrinter] Объекту 0x1B82A8E0 присвоен код ошибки 133 [Некорректное значение параметров команды ФН]
2020.03.16 09:53:18.343 T:000011CC INFO  [FiscalPrinter] libfptr_check_document_closed()
2020.03.16 09:53:18.343 T:000011CC INFO  [Transport] send 3F (1 bytes total)
2020.03.16 09:53:18.375 T:000011CC INFO  [Transport] recv 44 30 01 20 03 16 09 54 17 5F 00 62 22 03 3D 33 30 01 25 07 01 79 00 00 00 00 00 00 02 04 (30 bytes total)
2020.03.16 09:53:18.375 T:000011CC INFO  [Transport] send 91 34 00 00 (4 bytes total)
2020.03.16 09:53:18.406 T:000011CC INFO  [Transport] recv 55 00 00 00 00 28 66 16 03 20 09 54 31 87 38 49 65 (17 bytes total)
2020.03.16 09:53:18.406 T:000011CC INFO  [FiscalPrinter] < LIBFPTR_PARAM_DOCUMENT_CLOSED (65644) = false
2020.03.16 09:53:18.406 T:000011CC INFO  [FiscalPrinter] < LIBFPTR_PARAM_DOCUMENT_PRINTED (65709) = false
2020.03.16 09:53:18.406 T:000011CC INFO  [FiscalPrinter] libfptr_cancel_receipt()
2020.03.16 09:53:18.406 T:000011CC INFO  [Transport] send 45 (1 bytes total)
2020.03.16 09:53:18.421 T:000011CC INFO  [Transport] recv 55 01 00 (3 bytes total)
2020.03.16 09:53:18.421 T:000011CC INFO  [Transport] send 59 (1 bytes total)
2020.03.16 09:53:18.437 T:000011CC INFO  [Transport] recv 55 9A 00 (3 bytes total)
2020.03.16 09:53:18.437 T:000011CC ERROR [FiscalPrinter] Код ошибки ККТ - 009Ah
2020.03.16 09:53:18.437 T:000011CC ERROR [FiscalPrinter] Объекту 0x1B82A8E0 присвоен код ошибки 81 [Чек закрыт - операция невозможна]
2020.03.16 09:53:18.437 T:000011CC INFO  [FiscalPrinter] < LIBFPTR_PARAM_JSON_DATA (65645) = ""
2020.03.16 09:53:18.437 T:000011CC ERROR [FiscalPrinter] Объекту 0x1B82A8E0 присвоен код ошибки 133 [Некорректное значение параметров команды ФН]
2020.03.16 09:54:14.968 T:000011CC INFO  [FiscalPrinter] libfptr_destroy()
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] libfptr_create()
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] Информация о системе
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] Версия ОС: Win NT 6.1.7601 Service Pack 1
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] Центральный процессор: Intel(R) Xeon(R) CPU E3-1220 v3 @ 3.10GHz (% MHz)
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] Оперативная память: Phys: 6151/3644, PageFile: 12301/5823, Virtual: 8388607/8388507
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] Сборка библиотеки: x64; собрана с помощью MSVS 190024215.01
2020.03.16 10:00:22.593 T:00002AEC INFO  [FiscalPrinter] Версия библиотеки: 10.5.0.0
2020.03.16 10:00:22.640 T:00002AEC INFO  [FiscalPrinter] libfptr_set_settings()
1 Uragan_a
16.03.20
02:28
Может кто сталкивался? Из чека норм печатает, без ошибок.
2 Сияющий в темноте
16.03.20
некорректные значения параметров,нужно внимательно сраанивать,что и как передается.
вполне возможно,что система налогообложения меняется.
3 Kigo_Kigo
16.03.20
(2) Мне кажется там что то с услугами или авансами
