Админ
запуск сервера 1с на Ubuntu 18.04 ☑
0 Djonny
01.06.20
srv1cv83.service - LSB: Starts and stops the 1C:Enterprise daemons
Loaded: loaded (/etc/init.d/srv1cv83; generated)
Active: active (exited) since Mon 2020-06-01 08:51:27 MSK; 2h 40min ago
Docs: man:systemd-sysv-generator(8)
Tasks: 0 (limit: 4915)
CGroup: /system.slice/srv1cv83.service
июн 01 08:51:20 server systemd[1]: Starting LSB: Starts and stops the 1C:Enterprise daemons...
июн 01 08:51:20 server su[1857]: Successful su for usr1cv8 by root
июн 01 08:51:20 server su[1857]: + ??? root:usr1cv8
июн 01 08:51:20 server su[1857]: pam_unix(su:session): session opened for user usr1cv8 by (uid=0)
июн 01 08:51:21 server su[1857]: pam_unix(su:session): session closed for user usr1cv8
июн 01 08:51:27 server srv1cv83[1734]: Starting 1C:Enterprise 8.3 server: OK
июн 01 08:51:27 server systemd[1]: Started LSB: Starts and stops the 1C:Enterprise daemons.
postgresql.service - PostgreSQL RDBMS
Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled)
Active: active (exited) since Mon 2020-06-01 08:51:27 MSK; 2h 42min ago
Main PID: 3662 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/postgresql.service
июн 01 08:51:27 server systemd[1]: Starting PostgreSQL RDBMS...
июн 01 08:51:27 server systemd[1]: Started PostgreSQL RDBMS.
● haspd.service - LSB: Hasp keys support
Loaded: loaded (/etc/init.d/haspd; generated)
Active: active (running) since Mon 2020-06-01 08:51:19 MSK; 2h 45min ago
Tasks: 11 (limit: 4915)
CGroup: /system.slice/haspd.service
├─1003 aksusbd
├─1040 winehasp
├─1062 hasplm -c /etc/haspd/hasplm.conf
└─1090 hasplmd -s
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 0.0.0.0:1540 0.0.0.0:* LISTEN 999 24354 2448/ragent
tcp 0 0 0.0.0.0:1545 0.0.0.0:* LISTEN 1000 100954 8873/ras
tcp 0 0 0.0.0.0:5432 0.0.0.0:* LISTEN 127 29281 1769/postgres
ps aux|grep 1c
usr1cv8 2205 0.0 0.0 76764 7760 ? Ss 08:51 0:00 /lib/systemd/systemd --user
usr1cv8 2254 0.0 0.0 114304 2908 ? S 08:51 0:00 (sd-pam)
usr1cv8 2448 0.0 0.1 165424 48232 ? Ssl 08:51 0:06 /opt/1C/v8.3/x86_64/ragent -daemon
evgen 5737 0.9 0.4 651372 140292 tty2 Sl+ 09:16 1:27 /opt/1C/v8.3/x86_64/1cv8s
evgen 11223 0.0 0.0 14356 1052 pts/0 S+ 11:44 0:00 grep --color=auto 1c
не запущен rmngr на 1541.. не могу понять, что делаю не так.
предполагаю, что дело в правах.. но не очень силен в линуксе.. помогите разобраться..
версия 1с:8_3_17_1386
1 PloAl
01.06.20
Попробуйте дать прав:
chown -R usr1cv8:grp1cv8 /opt/1C
2 Djonny
01.06.20
почистил папку /home/usr1cv8 - и все заработало))
