Ошибка запуска службы sql SQL Server (MSSQLSERVER) ошибка 1814?
0 gabd_marat
25.04.21
Добрый вечер! Подскажите , кто сталкивался Ошибка запуска службы sql SQL Server (MSSQLSERVER) ошибка 1814. В интернете пишут что места на диске нет. Проверили место есть на с 70 гб , на d 100 гб, на е 100 гб. Ситуация после выключения электричества планового. Сервер заранее выключили.
лог файлы
2021-04-25 22:02:30.15 Server      Microsoft SQL Server 2008 R2 (SP3-GDR) (KB4057113) - 10.50.6560.0 (X64)
                Dec 28 2017 15:03:48
                Copyright (c) Microsoft Corporation
                Enterprise Edition (64-bit) on Windows NT 6.1 <X64> (Build 7601: Service Pack 1)
2021-04-25 22:02:30.15 Server      (c) Microsoft Corporation.
2021-04-25 22:02:30.15 Server      All rights reserved.
2021-04-25 22:02:30.15 Server      Server process ID is 576.
2021-04-25 22:02:30.15 Server      System Manufacturer: 'HP', System Model: 'ProLiant DL380 G7'.
2021-04-25 22:02:30.15 Server      Authentication mode is MIXED.
2021-04-25 22:02:30.15 Server      Logging SQL Server messages in file 'C:\Program Files\Microsoft SQL Server\MSSQL10_50.MSSQLSERVER\MSSQL\Log\ERRORLOG'.
2021-04-25 22:02:30.15 Server      This instance of SQL Server last reported using a process ID of 5580 at 25.04.2021 21:54:14 (local) 25.04.2021 18:54:14 (UTC). This is an informational message only; no user action is required.
2021-04-25 22:02:30.15 Server      Registry startup parameters:
                 -d C:\Program Files\Microsoft SQL Server\MSSQL10_50.MSSQLSERVER\MSSQL\DATA\master.mdf
                -e C:\Program Files\Microsoft SQL Server\MSSQL10_50.MSSQLSERVER\MSSQL\Log\ERRORLOG
                -l C:\Program Files\Microsoft SQL Server\MSSQL10_50.MSSQLSERVER\MSSQL\DATA\mastlog.ldf
2021-04-25 22:02:30.16 Сервер      SQL Server is starting at high priority base (=13). This is an informational message only. No user action is required.
2021-04-25 22:02:30.16 Сервер      Detected 24 CPUs. This is an informational message; no user action is required.
2021-04-25 22:02:30.16 Server      Cannot use Large Page Extensions:  lock memory privilege was not granted.
2021-04-25 22:02:30.66 Сервер      Using dynamic lock allocation.  Initial allocation of 2500 Lock blocks and 5000 Lock Owner blocks per node.  This is an informational message only.  No user action is required.
2021-04-25 22:02:30.66 Сервер      Lock partitioning is enabled.  This is an informational message only. No user action is required.
2021-04-25 22:02:30.72 Сервер      Node configuration: node 0: CPU mask: 0x0000000000fff000:0 Active CPU mask: 0x0000000000fff000:0. This message provides a description of the NUMA configuration for this computer. This is an informational message only. No user action is required.
2021-04-25 22:02:30.72 Сервер      Node configuration: node 1: CPU mask: 0x0000000000000fff:0 Active CPU mask: 0x0000000000000fff:0. This message provides a description of the NUMA configuration for this computer. This is an informational message only. No user action is required.
2021-04-25 22:02:30.75 spid9s      Starting up database 'master'.
2021-04-25 22:02:30.83 spid9s      1 transactions rolled forward in database 'master' (1). This is an informational message only. No user action is required.
2021-04-25 22:02:30.83 spid9s      0 transactions rolled back in database 'master' (1). This is an informational message only. No user action is required.
2021-04-25 22:02:30.83 spid9s      Recovery is writing a checkpoint in database 'master' (1). This is an informational message only. No user action is required.
2021-04-25 22:02:30.89 spid9s      CHECKDB for database 'master' finished without errors on 2017-09-09 04:54:36.283 (local time). This is an informational message only; no user action is required.
2021-04-25 22:02:30.90 spid9s      Resource governor reconfiguration succeeded.
2021-04-25 22:02:30.90 spid9s      SQL Server Audit is starting the audits. This is an informational message. No user action is required.
2021-04-25 22:02:30.90 spid9s      SQL Server Audit has started the audits. This is an informational message. No user action is required.
2021-04-25 22:02:30.91 spid9s      FILESTREAM: effective level = 0, configured level = 0, file system access share name = 'MSSQLSERVER'.
2021-04-25 22:02:30.94 spid9s      SQL Trace ID 1 was started by login "sa".
2021-04-25 22:02:30.94 spid9s      Starting up database 'mssqlsystemresource'.
2021-04-25 22:02:30.95 spid9s      The resource database build version is 10.50.6000. This is an informational message only. No user action is required.
2021-04-25 22:02:31.07 spid9s      Server name is 'SERVER4'. This is an informational message only. No user action is required.
2021-04-25 22:02:31.07 spid13s     Starting up database 'model'.
2021-04-25 22:02:31.09 spid13s     The database 'model' is marked RESTORING and is in a state that does not allow recovery to be run.
2021-04-25 22:02:31.09 spid13s     Ошибка: 927, серьезность: 14, состояние: 2.
2021-04-25 22:02:31.09 spid13s     Не удалось открыть базу данных "model". Она находится в процессе восстановления.
2021-04-25 22:02:31.09 spid13s     Could not create tempdb. You may not have enough disk space available. Free additional disk space by deleting other files on the tempdb drive and then restart SQL Server. Check for additional errors in the event log that may indicate why the tempdb files could not be initialized.
2021-04-25 22:02:31.09 spid13s     SQL Trace was stopped due to server shutdown. Trace ID = '1'. This is an informational message only; no user action is required.
1 gabd_marat
25.04.21
22:51
Запускали под локальной учеткой, под учеткой администратора домена , не работает
2 IVAL
25.04.21
База model сломалась, а все остальные базы из нее создаются. Возможно tempDB тоже (хотя немного странно, т.к. ее настройки отдельно хранятся).
Попробуйте подложить гарантированно корректные файлы для базы model - может быть исправится. Только надо от той же версии SQL сервера взять.
3 gabd_marat
25.04.21
(2) Понятно, спасибо , есть бекап на среду , хотим с админами попытаться восстановить полностью папку скуля на диске с. Как понимаю файл модели базы храниться именно там?
4 IVAL
25.04.21
(3) Да, обычно там лежит
5 МихаилМ
25.04.21
6 gabd_marat
25.04.21
23:23
У нас база и файл транзакций лежит отдельно, можт ли и файл модели лежать не в папке sql на диске с? (4)
7 gabd_marat
26.04.21
00:27
(5) не представляю как это делать
8 gabd_marat
26.04.21
00:32
(4) (6) как можно узнать откуда файл модели скуль подтягивает?
9 gabd_marat
26.04.21
00:50
возможно ли пользователем в рабочем режиме случайно удалить файл model при этом что бы скуль работал норм до след перезапуска?
10 rphosts
26.04.21
02:32
(6) может
(7) это не сложно, по ссылке есть пошаговое описание
11 rphosts
26.04.21
02:32
(9) вроде как файл должен быть сиквелом занят, поэтому вряд-ли
12 ДенисЧ
26.04.21
06:04
(9) (11) unlocker вполне справится )))
13 DrZombi
07:49
(9) Что у вас там за беспредел, если любой может удалять файлы :)
(0) Если у вас сиквель из коробки (почти), то проще возможно поставить его по новой и базы подцепить :) (0)
И еще, родной, вы там где места проверяли? :)
Код ошибки SQL-сервера 1814
SQL-сервер не может создать базу данных tempdb. Убедитесь, что на выделенном под нее диске достаточно места и что у учетной записи хватает прав для записи в указанную директорию.25 июл. 2018 г.
tempdb, смотри туда
14 DrZombi
07:50
+ А у вас диск существует?
Возможно вы его переименовали, или удалили (админ так решил) :)
15 gabd_marat
26.04.21
(14) (13) Пользователи имею ввиду админы, место чистили , но не на диске с , а там где база, базу не трогали
16 gabd_marat
26.04.21
(14) (13) (11) солько весит эта база model ? Она здесь должна лежать
C:\Program Files\Microsoft SQL Server\110\LocalDB\Binn\Templates
17 gabd_marat
26.04.21
Можно ли изменить пути рассположения системных баз данных  sql ?
18 rphosts
26.04.21
(17) в живой базе - да.
19 rphosts
26.04.21
(12) ну это если рассматривать саботаж
